[Patch] bsp/tms570/sci: fix bug in tms570_sci_read_received_chars()
Adrien Chardon Adrien at reflexaerospace.com
Mon Feb 5 11:20:20 UTC 2024
Hi Sebastian, Chris,
> I am not sure about this patch. It changes the initialization. The code
> you remove was added by:
> commit 691d0edd34f25a883c5dd0a56051d087b88e4fa4
> Author: Chris Johns <chrisj at rtems.org>
> Date:   Tue Aug 17 17:57:41 2021 +1000
>      arm/xilinx: Fix zynq-uart interrupt receive
>      - Trigger on a single character entering the RX FIFO
>      - Disable the RX timeout
>      - Send up to a FIFO full of data
As I wrote in the commit message, I think that a UART driver should not send any characters without being explicitely told so. The protocol that I'm using gets confused as it does not expect these bytes.
I've indeed seen the commit you reference, and the call to `zynq_uart_reset_tx_flush()` which sends these bytes seems to me unrelated to the bug the commit fixes, which is about the receive interrupt. As such, I believe that my patch should be merged (at least from a functionality point of view, I don't have any feelings about the implementation. For ex, passing a flag "text"/"raw" or having a global variable "char *initialization_tx_bytes" could also work, although that might not be compatible with the TERMIOS/POSIX way of doing things).
That being said, I'm only arguing my particular case, and you as maintainers have the final word.
I'm available if you need anything else from me.
Best regards,
Adrien Chardon
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
Sent: 01 February 2024 08:03
To: devel at rtems.org <devel at rtems.org>
Cc: Chris Johns <chrisj at rtems.org>; Adrien Chardon <Adrien at reflexaerospace.com>
Subject: Re: [Patch] bsp/tms570/sci: fix bug in tms570_sci_read_received_chars()
[You don't often get email from sebastian.huber at embedded-brains.de. Learn why this is important at https://aka.ms/LearnAboutSenderIdentification ]
Hello Adrien,
On 31.01.24 18:35, Adrien Chardon wrote:
> While testing the counterpart of my protocol on a Zynq, I found a
> similar issue
> where the UART is assumed to be used for printable text only. The second
> patch
> fixes it.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240205/4f10f3e5/attachment-0001.htm>
