[PATCH] improved error checking in ticks per timeslice
Sat Feb 17 17:35:01 UTC 2024
On 17.02.24 18:11, Joel Sherrill wrote:
> On Wed, Feb 14, 2024, 9:54 PM zack leung <zakthertemsdev at gmail.com
> <mailto:zakthertemsdev at gmail.com>> wrote:
>     > This file is generated from something in rtems-central. This was at the
>     > top of the file:
>     >   * This file is part of the RTEMS quality process and was automatically
>     >   * generated.  If you find something that needs to be fixed or
>     >   * worded better please post a report or patch to an RTEMS mailing list
>     No, problem. I can fix this before I check in the patch.
>     re: this do you need me to change it to something?
> I'm hoping Sebastian has some guidance for you on what to edit for this
> and how to propagate it dull.
Just for this patch it would be a bit of on overkill. I will take care
of this when I check in the patch.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
