[PATCH] testsuites/dl11: Test TLS on a secondary thread
Mon Feb 19 04:20:26 UTC 2024
Looks good. Thanks
On 19/2/2024 3:16 pm, Kinsey Moore wrote:
> This adds a pthread that runs the test as well to increase test
> coverage. The original test would have passed if all threads returned
> the address of the Init task's errno since no additional threads or
> tasks were checked.
>  testsuites/libtests/dl11/dl-load.c | 72 +++++++++++++++++++++++-------
>  testsuites/libtests/dl11/init.c    |  2 +
>  2 files changed, 59 insertions(+), 15 deletions(-)
> diff --git a/testsuites/libtests/dl11/dl-load.c b/testsuites/libtests/dl11/dl-load.c
> index 70d7bf1c65..b09128acdf 100644
> --- a/testsuites/libtests/dl11/dl-load.c
> +++ b/testsuites/libtests/dl11/dl-load.c
> @@ -27,6 +27,8 @@
>  #include <errno.h>
>  #include <stdio.h>
> +#include "tmacros.h"
> +#include <pthread.h>
>  #include <dlfcn.h>
> @@ -79,13 +81,60 @@ typedef int* (*ptr_call_t)(void);
>  void* get_errno_ptr(void);
>  int get_errno(void);
> -int dl_load_test(void)
> +int_call_t int_call;
> +ptr_call_t ptr_call;
> +static int perform_test(void)
> -  void*  handle;
> -  int_call_t int_call;
> -  ptr_call_t ptr_call;
>    int    int_call_ret;
>    int*   ptr_call_ret;
> +  ptr_call_ret = ptr_call ();
> +  if (ptr_call_ret != get_errno_ptr())
> +    printf("dlsym ptr_call failed: ret value bad\n");
> +    return 1;
> +  errno = 12345;
> +  int_call_ret = int_call ();
> +  if (int_call_ret != get_errno())
> +    printf("dlsym int_call failed: ret value bad\n");
> +    return 1;
> +  errno = 0;
> +  return 0;
> +static void *secondary_thread(void *arg)
> +  printf("Running test on secondary thread\n");
> +  if (perform_test()) {
> +    printf("Test failed on secondary task\n");
> +    return (void *) 1;
> +  return NULL;
> +static void start_secondary(void)
> +  /* Run the test on a secondary thread */
> +  pthread_t threadId;
> +  int status;
> +  void *ret;
> +  status = pthread_create( &threadId, NULL, secondary_thread, NULL );
> +  rtems_test_assert( !status );
> +  /* Wait on thread to exit */
> +  status = pthread_join(threadId, &ret);
> +  rtems_test_assert( ret == NULL );
> +int dl_load_test(void)
> +  void*  handle;
>    int    unresolved;
>    char*  message = "loaded";
> @@ -125,20 +174,13 @@ int dl_load_test(void)
>      return 1;
> -  ptr_call_ret = ptr_call ();
> -  if (ptr_call_ret != get_errno_ptr())
> -    printf("dlsym ptr_call failed: ret value bad\n");
> +  /* Run the test on the init thread */
> +  printf("Running test on init task\n");
>      return 1;
> -  errno = 12345;
> -  int_call_ret = int_call ();
> -  if (int_call_ret != get_errno())
> -    printf("dlsym int_call failed: ret value bad\n");
> -    return 1;
> +  start_secondary();
>    if (dlclose (handle) < 0)
> diff --git a/testsuites/libtests/dl11/init.c b/testsuites/libtests/dl11/init.c
> index 91f529b055..0ff4557421 100644
> --- a/testsuites/libtests/dl11/init.c
> +++ b/testsuites/libtests/dl11/init.c
> @@ -86,6 +86,8 @@ static void Init(rtems_task_argument arg)
>  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
> +#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
>  #define CONFIGURE_MAXIMUM_TASKS 1
>  #define CONFIGURE_MAXIMUM_SEMAPHORES 1
