[PATCH] testsuites/dl11: Test TLS on a secondary thread
Mon Feb 19 05:50:17 UTC 2024
I think this is ok also.
On Sun, Feb 18, 2024, 10:20 PM Chris Johns <chrisj at rtems.org> wrote:
> Looks good. Thanks
> Chris
> On 19/2/2024 3:16 pm, Kinsey Moore wrote:
> > This adds a pthread that runs the test as well to increase test
> > coverage. The original test would have passed if all threads returned
> > the address of the Init task's errno since no additional threads or
> > tasks were checked.
> >  testsuites/libtests/dl11/dl-load.c | 72 +++++++++++++++++++++++-------
> >  testsuites/libtests/dl11/init.c    |  2 +
> >  2 files changed, 59 insertions(+), 15 deletions(-)
> > diff --git a/testsuites/libtests/dl11/dl-load.c
> b/testsuites/libtests/dl11/dl-load.c
> > index 70d7bf1c65..b09128acdf 100644
> > --- a/testsuites/libtests/dl11/dl-load.c
> > +++ b/testsuites/libtests/dl11/dl-load.c
> > @@ -27,6 +27,8 @@
> >  #include <errno.h>
> >  #include <stdio.h>
> > +#include "tmacros.h"
> > +#include <pthread.h>
> >  #include <dlfcn.h>
> > @@ -79,13 +81,60 @@ typedef int* (*ptr_call_t)(void);
> >  void* get_errno_ptr(void);
> >  int get_errno(void);
> > -int dl_load_test(void)
> > +int_call_t int_call;
> > +ptr_call_t ptr_call;
> > +static int perform_test(void)
> > -  void*  handle;
> > -  int_call_t int_call;
> > -  ptr_call_t ptr_call;
> >    int    int_call_ret;
> >    int*   ptr_call_ret;
> > +  ptr_call_ret = ptr_call ();
> > +  if (ptr_call_ret != get_errno_ptr())
> > +    printf("dlsym ptr_call failed: ret value bad\n");
> > +    return 1;
> > +  errno = 12345;
> > +  int_call_ret = int_call ();
> > +  if (int_call_ret != get_errno())
> > +    printf("dlsym int_call failed: ret value bad\n");
> > +    return 1;
> > +  errno = 0;
> > +  return 0;
> > +static void *secondary_thread(void *arg)
> > +  printf("Running test on secondary thread\n");
> > +  if (perform_test()) {
> > +    printf("Test failed on secondary task\n");
> > +    return (void *) 1;
> > +  return NULL;
> > +static void start_secondary(void)
> > +  /* Run the test on a secondary thread */
> > +  pthread_t threadId;
> > +  int status;
> > +  void *ret;
> > +  status = pthread_create( &threadId, NULL, secondary_thread, NULL );
> > +  rtems_test_assert( !status );
> > +  /* Wait on thread to exit */
> > +  status = pthread_join(threadId, &ret);
> > +  rtems_test_assert( ret == NULL );
> > +int dl_load_test(void)
> > +  void*  handle;
> >    int    unresolved;
> >    char*  message = "loaded";
> > @@ -125,20 +174,13 @@ int dl_load_test(void)
> >      return 1;
> > -  ptr_call_ret = ptr_call ();
> > -  if (ptr_call_ret != get_errno_ptr())
> > -    printf("dlsym ptr_call failed: ret value bad\n");
> > +  /* Run the test on the init thread */
> > +  printf("Running test on init task\n");
> >      return 1;
> > -  errno = 12345;
> > -  int_call_ret = int_call ();
> > -  if (int_call_ret != get_errno())
> > -    printf("dlsym int_call failed: ret value bad\n");
> > -    return 1;
> > +  start_secondary();
> >    if (dlclose (handle) < 0)
> > diff --git a/testsuites/libtests/dl11/init.c
> b/testsuites/libtests/dl11/init.c
> > index 91f529b055..0ff4557421 100644
> > --- a/testsuites/libtests/dl11/init.c
> > +++ b/testsuites/libtests/dl11/init.c
> > @@ -86,6 +86,8 @@ static void Init(rtems_task_argument arg)
> >  #define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 4
> > +#define CONFIGURE_MAXIMUM_POSIX_THREADS 1
> >  #define CONFIGURE_MAXIMUM_TASKS 1
> >  #define CONFIGURE_MAXIMUM_SEMAPHORES 1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240218/6b235f30/attachment.htm>
