Documentation theme update
Wed Feb 21 16:53:50 UTC 2024
Based on Christian saying it works and me confirming that, I pushed this.
Thanks a lot Chris! <no sarcasm on that at all>
--joel
On Wed, Feb 21, 2024 at 2:22 AM Christian MAUDERER <
christian.mauderer at embedded-brains.de> wrote:
> Hello Chris,
> On 2024-02-21 06:16, Chris Johns wrote:
> > Hi,
> > I have a patch for rtems-docs.git to move us to the pip installed
> > sphinx-rtd-theme removing the custom theme based on sphinx-rtd-theme we
> > currently use.
> I think reducing RTEMS specific adaptions is a great idea. So thank you
> for that.
> > The ticket is #4994.
> > The patch is over 4M in size as it deletes
> common/sphinx_rtd_theme_rtems. YOu
> > can download it from:
> https://ftp.rtems.org/pub/rtems/people/chrisj/0001-sphinx-Use-the-pip-installed-sphinx-rtd-theme.patch
> > What I am not sure about is how old Sphinx can be to build the
> documentation. My
> > versions are:
> >   Sphinx                        7.2.6
> >   sphinx-rtd-theme              2.0.0
> >   sphinxcontrib-applehelp       1.0.7
> >   sphinxcontrib-bibtex          2.6.1
> >   sphinxcontrib-devhelp         1.0.5
> >   sphinxcontrib-htmlhelp        2.0.4
> >   sphinxcontrib-jquery          4.1
> >   sphinxcontrib-jsmath          1.0.1
> >   sphinxcontrib-qthelp          1.0.6
> >   sphinxcontrib-serializinghtml 1.1.9
> > Is it OK to push?
> I tried building the manuals with your patches on OpenSUSE. It's
> basically the same procedure as without the patch except that the
> sphinx-rtd-theme is now necessary. The result looks as expected.
> With the patch, the search seems to work again. That hasn't been the
> case with the old version.
> So from my point of view, the patch is a great improvement and OK.
> Best regards
> Christian
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240221/2bd1ff89/attachment.htm>
