[Tools] rtemstoolkit/libierty: Add missing file
Tue Feb 27 10:56:20 UTC 2024
This fixes the following build error for --host=x86_64-w64-mingw32:
rtemstoolkit/libiberty.a(pex-win32.c.18.o): in function `win32_spawn':
rtemstoolkit/libiberty/pex-win32.c:643: undefined reference to `writeargv'
Update #4969.
 rtemstoolkit/libiberty/argv.c | 568 ++++++++++++++++++++++++++++++++++
 rtemstoolkit/wscript          |   3 +-
 2 files changed, 570 insertions(+), 1 deletion(-)
 create mode 100644 rtemstoolkit/libiberty/argv.c
diff --git a/rtemstoolkit/libiberty/argv.c b/rtemstoolkit/libiberty/argv.c
new file mode 100644
index 0000000..a95a10e
--- /dev/null
+++ b/rtemstoolkit/libiberty/argv.c
@@ -0,0 +1,568 @@
+/* Create and destroy argument vectors (argv's)
+   Copyright (C) 1992-2023 Free Software Foundation, Inc.
+   Written by Fred Fish @ Cygnus Support
+This file is part of the libiberty library.
+Libiberty is free software; you can redistribute it and/or
+modify it under the terms of the GNU Library General Public
+License as published by the Free Software Foundation; either
+version 2 of the License, or (at your option) any later version.
+Libiberty is distributed in the hope that it will be useful,
+but WITHOUT ANY WARRANTY; without even the implied warranty of
+MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
+Library General Public License for more details.
+You should have received a copy of the GNU Library General Public
+License along with libiberty; see the file COPYING.LIB.  If
+not, write to the Free Software Foundation, Inc., 51 Franklin Street - Fifth Floor,
+Boston, MA 02110-1301, USA.  */
+/*  Create and destroy argument vectors.  An argument vector is simply an
+    array of string pointers, terminated by a NULL pointer. */
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include "ansidecl.h"
+#include "libiberty.h"
+#include "safe-ctype.h"
+/*  Routines imported from standard C runtime libraries. */
+#include <stddef.h>
+#include <string.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <sys/types.h>
+#ifdef HAVE_UNISTD_H
+#include <unistd.h>
+#endif
+#if HAVE_SYS_STAT_H
+#include <sys/stat.h>
+#endif
+#ifndef NULL
+#define NULL 0
+#endif
+#ifndef EOS
+#define EOS '\0'
+#endif
+#define INITIAL_MAXARGC 8	/* Number of args + NULL in initial argv */
+ at deftypefn Extension char** dupargv (char * const *@var{vector})
+Duplicate an argument vector.  Simply scans through @var{vector},
+duplicating each argument until the terminating @code{NULL} is found.
+Returns a pointer to the argument vector if successful.  Returns
+ at code{NULL} if there is insufficient memory to complete building the
+argument vector.
+ at end deftypefn
+char **
+dupargv (char * const *argv)
+  int argc;
+  char **copy;
+  if (argv == NULL)
+    return NULL;
+  /* the vector */
+  for (argc = 0; argv[argc] != NULL; argc++);
+  copy = (char **) xmalloc ((argc + 1) * sizeof (char *));
+  /* the strings */
+    copy[argc] = xstrdup (argv[argc]);
+  copy[argc] = NULL;
+  return copy;
+ at deftypefn Extension void freeargv (char **@var{vector})
+Free an argument vector that was built using @code{buildargv}.  Simply
+scans through @var{vector}, freeing the memory for each argument until
+the terminating @code{NULL} is found, and then frees @var{vector}
+itself.
+ at end deftypefn
+void freeargv (char **vector)
+  register char **scan;
+  if (vector != NULL)
+      for (scan = vector; *scan != NULL; scan++)
+	  free (*scan);
+      free (vector);
+static void
+consume_whitespace (const char **input)
+  while (ISSPACE (**input))
+      (*input)++;
+static int
+only_whitespace (const char* input)
+  while (*input != EOS && ISSPACE (*input))
+    input++;
+  return (*input == EOS);
+ at deftypefn Extension char** buildargv (char *@var{sp})
+Given a pointer to a string, parse the string extracting fields
+separated by whitespace and optionally enclosed within either single
+or double quotes (which are stripped off), and build a vector of
+pointers to copies of the string for each field.  The input string
+remains unchanged.  The last element of the vector is followed by a
+ at code{NULL} element.
+All of the memory for the pointer array and copies of the string
+is obtained from @code{xmalloc}.  All of the memory can be returned to the
+system with the single function call @code{freeargv}, which takes the
+returned result of @code{buildargv}, as it's argument.
+ at code{NULL} if @var{sp} is @code{NULL} or if there is insufficient
+memory to complete building the argument vector.
+If the input is a null string (as opposed to a @code{NULL} pointer),
+then buildarg returns an argument vector that has one arg, a null
+string.
+ at end deftypefn
+The memory for the argv array is dynamically expanded as necessary.
+In order to provide a working buffer for extracting arguments into,
+with appropriate stripping of quotes and translation of backslash
+sequences, we allocate a working buffer at least as long as the input
+string.  This ensures that we always have enough space in which to
+work, since the extracted arg is never larger than the input string.
+The argument vector is always kept terminated with a @code{NULL} arg
+pointer, so it can be passed to @code{freeargv} at any time, or
+returned, as appropriate.
+char **buildargv (const char *input)
+  char *arg;
+  char *copybuf;
+  int squote = 0;
+  int dquote = 0;
+  int bsquote = 0;
+  int argc = 0;
+  int maxargc = 0;
+  char **argv = NULL;
+  char **nargv;
+  if (input != NULL)
+      copybuf = (char *) xmalloc (strlen (input) + 1);
+      /* Is a do{}while to always execute the loop once.  Always return an
+	 argv, even for null strings.  See NOTES above, test case below. */
+      do
+	  /* Pick off argv[argc] */
+	  consume_whitespace (&input);
+	  if ((maxargc == 0) || (argc >= (maxargc - 1)))
+	      /* argv needs initialization, or expansion */
+	      if (argv == NULL)
+		  maxargc = INITIAL_MAXARGC;
+		  nargv = (char **) xmalloc (maxargc * sizeof (char *));
+	      else
+		  maxargc *= 2;
+		  nargv = (char **) xrealloc (argv, maxargc * sizeof (char *));
+	      argv = nargv;
+	      argv[argc] = NULL;
+	  /* Begin scanning arg */
+	  arg = copybuf;
+	  while (*input != EOS)
+	      if (ISSPACE (*input) && !squote && !dquote && !bsquote)
+		  break;
+	      else
+		  if (bsquote)
+		      bsquote = 0;
+		      *arg++ = *input;
+		  else if (*input == '\\')
+		      bsquote = 1;
+		  else if (squote)
+		      if (*input == '\'')
+			  squote = 0;
+		      else
+			  *arg++ = *input;
+		  else if (dquote)
+		      if (*input == '"')
+			  dquote = 0;
+		      else
+			  *arg++ = *input;
+		  else
+			  squote = 1;
+		      else if (*input == '"')
+			  dquote = 1;
+		      else
+			  *arg++ = *input;
+		  input++;
+	  *arg = EOS;
+	  argv[argc] = xstrdup (copybuf);
+	  argc++;
+      while (*input != EOS);
+      free (copybuf);
+  return (argv);
+ at deftypefn Extension int writeargv (char * const *@var{argv}, FILE *@var{file})
+Write each member of ARGV, handling all necessary quoting, to the file
+named by FILE, separated by whitespace.  Return 0 on success, non-zero
+if an error occurred while writing to FILE.
+ at end deftypefn
+int
+writeargv (char * const *argv, FILE *f)
+  int status = 0;
+  if (f == NULL)
+    return 1;
+  while (*argv != NULL)
+      const char *arg = *argv;
+      while (*arg != EOS)
+          char c = *arg;
+          if (ISSPACE(c) || c == '\\' || c == '\'' || c == '"')
+            if (EOF == fputc ('\\', f))
+                status = 1;
+                goto done;
+          if (EOF == fputc (c, f))
+              status = 1;
+              goto done;
+          arg++;
+      /* Write out a pair of quotes for an empty argument.  */
+      if (arg == *argv)
+	if (EOF == fputs ("\"\"", f))
+	    status = 1;
+	    goto done;
+      if (EOF == fputc ('\n', f))
+          status = 1;
+          goto done;
+      argv++;
+ done:
+  return status;
+ at deftypefn Extension void expandargv (int *@var{argcp}, char ***@var{argvp})
+The @var{argcp} and @code{argvp} arguments are pointers to the usual
+ at code{argc} and @code{argv} arguments to @code{main}.  This function
+looks for arguments that begin with the character @samp{@@}.  Any such
+arguments are interpreted as ``response files''.  The contents of the
+response file are interpreted as additional command line options.  In
+particular, the file is separated into whitespace-separated strings;
+each such string is taken as a command-line option.  The new options
+are inserted in place of the option naming the response file, and
+ at code{*argcp} and @code{*argvp} will be updated.  If the value of
+ at code{*argvp} is modified by this function, then the new value has
+been dynamically allocated and can be deallocated by the caller with
+ at code{freeargv}.  However, most callers will simply call
+ at code{expandargv} near the beginning of @code{main} and allow the
+operating system to free the memory when the program exits.
+ at end deftypefn
+void
+expandargv (int *argcp, char ***argvp)
+  /* The argument we are currently processing.  */
+  int i = 0;
+  /* To check if ***argvp has been dynamically allocated.  */
+  char ** const original_argv = *argvp;
+  /* Limit the number of response files that we parse in order
+     to prevent infinite recursion.  */
+  unsigned int iteration_limit = 2000;
+  /* Loop over the arguments, handling response files.  We always skip
+     ARGVP[0], as that is the name of the program being run.  */
+  while (++i < *argcp)
+      /* The name of the response file.  */
+      const char *filename;
+      /* The response file.  */
+      FILE *f;
+      /* An upper bound on the number of characters in the response
+	 file.  */
+      long pos;
+      /* The number of characters in the response file, when actually
+	 read.  */
+      size_t len;
+      /* A dynamically allocated buffer used to hold options read from a
+	 response file.  */
+      char *buffer;
+      /* Dynamically allocated storage for the options read from the
+	 response file.  */
+      char **file_argv;
+      /* The number of options read from the response file, if any.  */
+      size_t file_argc;
+#ifdef S_ISDIR
+      struct stat sb;
+#endif
+      /* We are only interested in options of the form "@file".  */
+      filename = (*argvp)[i];
+      if (filename[0] != '@')
+	continue;
+      /* If we have iterated too many times then stop.  */
+      if (-- iteration_limit == 0)
+	  fprintf (stderr, "%s: error: too many @-files encountered\n", (*argvp)[0]);
+	  xexit (1);
+#ifdef S_ISDIR
+      if (stat (filename+1, &sb) < 0)
+	continue;
+      if (S_ISDIR(sb.st_mode))
+	  fprintf (stderr, "%s: error: @-file refers to a directory\n", (*argvp)[0]);
+	  xexit (1);
+#endif
+      /* Read the contents of the file.  */
+      f = fopen (++filename, "r");
+      if (!f)
+	continue;
+      if (fseek (f, 0L, SEEK_END) == -1)
+	goto error;
+      pos = ftell (f);
+      if (pos == -1)
+	goto error;
+      if (fseek (f, 0L, SEEK_SET) == -1)
+	goto error;
+      buffer = (char *) xmalloc (pos * sizeof (char) + 1);
+      len = fread (buffer, sizeof (char), pos, f);
+      if (len != (size_t) pos
+	  /* On Windows, fread may return a value smaller than POS,
+	     due to CR/LF->CR translation when reading text files.
+	     That does not in-and-of itself indicate failure.  */
+	  && ferror (f))
+	  free (buffer);
+	  goto error;
+      /* Add a NUL terminator.  */
+      buffer[len] = '\0';
+      /* If the file is empty or contains only whitespace, buildargv would
+	 return a single empty argument.  In this context we want no arguments,
+	 instead.  */
+      if (only_whitespace (buffer))
+	  file_argv = (char **) xmalloc (sizeof (char *));
+	  file_argv[0] = NULL;
+      else
+	/* Parse the string.  */
+	file_argv = buildargv (buffer);
+      /* If *ARGVP is not already dynamically allocated, copy it.  */
+      if (*argvp == original_argv)
+	*argvp = dupargv (*argvp);
+      /* Count the number of arguments.  */
+      file_argc = 0;
+      while (file_argv[file_argc])
+	++file_argc;
+      /* Free the original option's memory.  */
+      free ((*argvp)[i]);
+      /* Now, insert FILE_ARGV into ARGV.  The "+1" below handles the
+	 NULL terminator at the end of ARGV.  */
+      *argvp = ((char **)
+		xrealloc (*argvp,
+			  (*argcp + file_argc + 1) * sizeof (char *)));
+      memmove (*argvp + i + file_argc, *argvp + i + 1,
+	       (*argcp - i) * sizeof (char *));
+      memcpy (*argvp + i, file_argv, file_argc * sizeof (char *));
+      /* The original option has been replaced by all the new
+	 options.  */
+      *argcp += file_argc - 1;
+      /* Free up memory allocated to process the response file.  We do
+	 not use freeargv because the individual options in FILE_ARGV
+	 are now in the main ARGV.  */
+      free (file_argv);
+      free (buffer);
+      /* Rescan all of the arguments just read to support response
+	 files that include other response files.  */
+      --i;
+    error:
+      /* We're all done with the file now.  */
+      fclose (f);
+ at deftypefn Extension int countargv (char * const *@var{argv})
+Return the number of elements in @var{argv}.
+Returns zero if @var{argv} is NULL.
+ at end deftypefn
+int
+countargv (char * const *argv)
+  int argc;
+  if (argv == NULL)
+    return 0;
+    continue;
+  return argc;
+#ifdef MAIN
+/* Simple little test driver. */
+static const char *const tests[] =
+  "a simple command line",
+  "arg 'foo' is single quoted",
+  "arg \"bar\" is double quoted",
+  "arg \"foo bar\" has embedded whitespace",
+  "arg 'Jack said \\'hi\\'' has single quotes",
+  "arg 'Jack said \\\"hi\\\"' has double quotes",
+  "a b c d e f g h i j k l m n o p q r s t u v w x y z 1 2 3 4 5 6 7 8 9",
+  /* This should be expanded into only one argument.  */
+  "trailing-whitespace ",
+  NULL
+int
+main (void)
+  char **argv;
+  const char *const *test;
+  char **targs;
+  for (test = tests; *test != NULL; test++)
+      printf ("buildargv(\"%s\")\n", *test);
+      if ((argv = buildargv (*test)) == NULL)
+	  printf ("failed!\n\n");
+      else
+	  for (targs = argv; *targs != NULL; targs++)
+	      printf ("\t\"%s\"\n", *targs);
+	  printf ("\n");
+      freeargv (argv);
+  return 0;
+#endif	/* MAIN */
diff --git a/rtemstoolkit/wscript b/rtemstoolkit/wscript
index d1d5127..20b1047 100644
--- a/rtemstoolkit/wscript
+++ b/rtemstoolkit/wscript
@@ -410,7 +410,8 @@ def bld_libiberty(bld, conf):
               includes = ['libiberty'],
               cflags = conf['cflags'],
               defines = defines,
-              source =['libiberty/concat.c',
+              source =['libiberty/argv.c',
+                       'libiberty/concat.c',
                        'libiberty/cplus-dem.c',
                        'libiberty/cp-demangle.c',
                        'libiberty/d-demangle.c',
2.35.3
