[Tools] rtemstoolkit/libierty: Add missing file
Wed Feb 28 05:49:52 UTC 2024
OK and thanks
On 27/2/2024 9:56 pm, Sebastian Huber wrote:
> This fixes the following build error for --host=x86_64-w64-mingw32:
> rtemstoolkit/libiberty.a(pex-win32.c.18.o): in function `win32_spawn':
> rtemstoolkit/libiberty/pex-win32.c:643: undefined reference to `writeargv'
> Update #4969.
>  rtemstoolkit/libiberty/argv.c | 568 ++++++++++++++++++++++++++++++++++
>  rtemstoolkit/wscript          |   3 +-
>  2 files changed, 570 insertions(+), 1 deletion(-)
>  create mode 100644 rtemstoolkit/libiberty/argv.c
> diff --git a/rtemstoolkit/libiberty/argv.c b/rtemstoolkit/libiberty/argv.c
> new file mode 100644
> index 0000000..a95a10e
> --- /dev/null
> +++ b/rtemstoolkit/libiberty/argv.c
> @@ -0,0 +1,568 @@
> +/* Create and destroy argument vectors (argv's)
> +   Copyright (C) 1992-2023 Free Software Foundation, Inc.
> +   Written by Fred Fish @ Cygnus Support
> +This file is part of the libiberty library.
> +Libiberty is free software; you can redistribute it and/or
> +modify it under the terms of the GNU Library General Public
> +License as published by the Free Software Foundation; either
> +version 2 of the License, or (at your option) any later version.
> +Libiberty is distributed in the hope that it will be useful,
> +but WITHOUT ANY WARRANTY; without even the implied warranty of
> +MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
> +Library General Public License for more details.
> +You should have received a copy of the GNU Library General Public
> +License along with libiberty; see the file COPYING.LIB.  If
> +not, write to the Free Software Foundation, Inc., 51 Franklin Street - Fifth Floor,
> +Boston, MA 02110-1301, USA.  */
> +/*  Create and destroy argument vectors.  An argument vector is simply an
> +    array of string pointers, terminated by a NULL pointer. */
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include "ansidecl.h"
> +#include "libiberty.h"
> +#include "safe-ctype.h"
> +/*  Routines imported from standard C runtime libraries. */
> +#include <stddef.h>
> +#include <string.h>
> +#include <stdlib.h>
> +#include <stdio.h>
> +#include <sys/types.h>
> +#ifdef HAVE_UNISTD_H
> +#include <unistd.h>
> +#endif
> +#if HAVE_SYS_STAT_H
> +#include <sys/stat.h>
> +#endif
> +#ifndef NULL
> +#define NULL 0
> +#endif
> +#ifndef EOS
> +#define EOS '\0'
> +#endif
> +#define INITIAL_MAXARGC 8	/* Number of args + NULL in initial argv */
> + at deftypefn Extension char** dupargv (char * const *@var{vector})
> +Duplicate an argument vector.  Simply scans through @var{vector},
> +duplicating each argument until the terminating @code{NULL} is found.
> +Returns a pointer to the argument vector if successful.  Returns
> + at code{NULL} if there is insufficient memory to complete building the
> +argument vector.
> + at end deftypefn
> +char **
> +dupargv (char * const *argv)
> +  int argc;
> +  char **copy;
> +  if (argv == NULL)
> +    return NULL;
> +  /* the vector */
> +  for (argc = 0; argv[argc] != NULL; argc++);
> +  copy = (char **) xmalloc ((argc + 1) * sizeof (char *));
> +  /* the strings */
> +    copy[argc] = xstrdup (argv[argc]);
> +  copy[argc] = NULL;
> +  return copy;
> + at deftypefn Extension void freeargv (char **@var{vector})
> +Free an argument vector that was built using @code{buildargv}.  Simply
> +scans through @var{vector}, freeing the memory for each argument until
> +the terminating @code{NULL} is found, and then frees @var{vector}
> +itself.
> + at end deftypefn
> +void freeargv (char **vector)
> +  register char **scan;
> +  if (vector != NULL)
> +      for (scan = vector; *scan != NULL; scan++)
> +	  free (*scan);
> +      free (vector);
> +static void
> +consume_whitespace (const char **input)
> +  while (ISSPACE (**input))
> +      (*input)++;
> +static int
> +only_whitespace (const char* input)
> +  while (*input != EOS && ISSPACE (*input))
> +    input++;
> +  return (*input == EOS);
> + at deftypefn Extension char** buildargv (char *@var{sp})
> +Given a pointer to a string, parse the string extracting fields
> +separated by whitespace and optionally enclosed within either single
> +or double quotes (which are stripped off), and build a vector of
> +pointers to copies of the string for each field.  The input string
> +remains unchanged.  The last element of the vector is followed by a
> + at code{NULL} element.
> +All of the memory for the pointer array and copies of the string
> +is obtained from @code{xmalloc}.  All of the memory can be returned to the
> +system with the single function call @code{freeargv}, which takes the
> +returned result of @code{buildargv}, as it's argument.
> + at code{NULL} if @var{sp} is @code{NULL} or if there is insufficient
> +memory to complete building the argument vector.
> +If the input is a null string (as opposed to a @code{NULL} pointer),
> +then buildarg returns an argument vector that has one arg, a null
> +string.
> + at end deftypefn
> +The memory for the argv array is dynamically expanded as necessary.
> +In order to provide a working buffer for extracting arguments into,
> +with appropriate stripping of quotes and translation of backslash
> +sequences, we allocate a working buffer at least as long as the input
> +string.  This ensures that we always have enough space in which to
> +work, since the extracted arg is never larger than the input string.
> +The argument vector is always kept terminated with a @code{NULL} arg
> +pointer, so it can be passed to @code{freeargv} at any time, or
> +returned, as appropriate.
> +char **buildargv (const char *input)
> +  char *arg;
> +  char *copybuf;
> +  int squote = 0;
> +  int dquote = 0;
> +  int bsquote = 0;
> +  int argc = 0;
> +  int maxargc = 0;
> +  char **argv = NULL;
> +  char **nargv;
> +  if (input != NULL)
> +      copybuf = (char *) xmalloc (strlen (input) + 1);
> +      /* Is a do{}while to always execute the loop once.  Always return an
> +	 argv, even for null strings.  See NOTES above, test case below. */
> +      do
> +	  /* Pick off argv[argc] */
> +	  consume_whitespace (&input);
> +	  if ((maxargc == 0) || (argc >= (maxargc - 1)))
> +	      /* argv needs initialization, or expansion */
> +	      if (argv == NULL)
> +		  maxargc = INITIAL_MAXARGC;
> +		  nargv = (char **) xmalloc (maxargc * sizeof (char *));
> +	      else
> +		  maxargc *= 2;
> +		  nargv = (char **) xrealloc (argv, maxargc * sizeof (char *));
> +	      argv = nargv;
> +	      argv[argc] = NULL;
> +	  /* Begin scanning arg */
> +	  arg = copybuf;
> +	  while (*input != EOS)
> +	      if (ISSPACE (*input) && !squote && !dquote && !bsquote)
> +		  break;
> +	      else
> +		  if (bsquote)
> +		      bsquote = 0;
> +		      *arg++ = *input;
> +		  else if (*input == '\\')
> +		      bsquote = 1;
> +		  else if (squote)
> +		      if (*input == '\'')
> +			  squote = 0;
> +		      else
> +			  *arg++ = *input;
> +		  else if (dquote)
> +		      if (*input == '"')
> +			  dquote = 0;
> +		      else
> +			  *arg++ = *input;
> +		  else
> +			  squote = 1;
> +		      else if (*input == '"')
> +			  dquote = 1;
> +		      else
> +			  *arg++ = *input;
> +		  input++;
> +	  *arg = EOS;
> +	  argv[argc] = xstrdup (copybuf);
> +	  argc++;
> +      while (*input != EOS);
> +      free (copybuf);
> +  return (argv);
> + at deftypefn Extension int writeargv (char * const *@var{argv}, FILE *@var{file})
> +Write each member of ARGV, handling all necessary quoting, to the file
> +named by FILE, separated by whitespace.  Return 0 on success, non-zero
> +if an error occurred while writing to FILE.
> + at end deftypefn
> +int
> +writeargv (char * const *argv, FILE *f)
> +  int status = 0;
> +  if (f == NULL)
> +    return 1;
> +  while (*argv != NULL)
> +      const char *arg = *argv;
> +      while (*arg != EOS)
> +          char c = *arg;
> +          if (ISSPACE(c) || c == '\\' || c == '\'' || c == '"')
> +            if (EOF == fputc ('\\', f))
> +                status = 1;
> +                goto done;
> +          if (EOF == fputc (c, f))
> +              status = 1;
> +              goto done;
> +          arg++;
> +      /* Write out a pair of quotes for an empty argument.  */
> +      if (arg == *argv)
> +	if (EOF == fputs ("\"\"", f))
> +	    status = 1;
> +	    goto done;
> +      if (EOF == fputc ('\n', f))
> +          status = 1;
> +          goto done;
> +      argv++;
> + done:
> +  return status;
> + at deftypefn Extension void expandargv (int *@var{argcp}, char ***@var{argvp})
> +The @var{argcp} and @code{argvp} arguments are pointers to the usual
> + at code{argc} and @code{argv} arguments to @code{main}.  This function
> +looks for arguments that begin with the character @samp{@@}.  Any such
> +arguments are interpreted as ``response files''.  The contents of the
> +response file are interpreted as additional command line options.  In
> +particular, the file is separated into whitespace-separated strings;
> +each such string is taken as a command-line option.  The new options
> +are inserted in place of the option naming the response file, and
> + at code{*argcp} and @code{*argvp} will be updated.  If the value of
> + at code{*argvp} is modified by this function, then the new value has
> +been dynamically allocated and can be deallocated by the caller with
> + at code{freeargv}.  However, most callers will simply call
> + at code{expandargv} near the beginning of @code{main} and allow the
> +operating system to free the memory when the program exits.
> + at end deftypefn
> +void
> +expandargv (int *argcp, char ***argvp)
> +  /* The argument we are currently processing.  */
> +  int i = 0;
> +  /* To check if ***argvp has been dynamically allocated.  */
> +  char ** const original_argv = *argvp;
> +  /* Limit the number of response files that we parse in order
> +     to prevent infinite recursion.  */
> +  unsigned int iteration_limit = 2000;
> +  /* Loop over the arguments, handling response files.  We always skip
> +     ARGVP[0], as that is the name of the program being run.  */
> +  while (++i < *argcp)
> +      /* The name of the response file.  */
> +      const char *filename;
> +      /* The response file.  */
> +      FILE *f;
> +      /* An upper bound on the number of characters in the response
> +	 file.  */
> +      long pos;
> +      /* The number of characters in the response file, when actually
> +	 read.  */
> +      size_t len;
> +      /* A dynamically allocated buffer used to hold options read from a
> +	 response file.  */
> +      char *buffer;
> +      /* Dynamically allocated storage for the options read from the
> +	 response file.  */
> +      char **file_argv;
> +      /* The number of options read from the response file, if any.  */
> +      size_t file_argc;
> +#ifdef S_ISDIR
> +      struct stat sb;
> +#endif
> +      /* We are only interested in options of the form "@file".  */
> +      filename = (*argvp)[i];
> +      if (filename[0] != '@')
> +	continue;
> +      /* If we have iterated too many times then stop.  */
> +      if (-- iteration_limit == 0)
> +	  fprintf (stderr, "%s: error: too many @-files encountered\n", (*argvp)[0]);
> +	  xexit (1);
> +#ifdef S_ISDIR
> +      if (stat (filename+1, &sb) < 0)
> +	continue;
> +      if (S_ISDIR(sb.st_mode))
> +	  fprintf (stderr, "%s: error: @-file refers to a directory\n", (*argvp)[0]);
> +	  xexit (1);
> +#endif
> +      /* Read the contents of the file.  */
> +      f = fopen (++filename, "r");
> +      if (!f)
> +	continue;
> +      if (fseek (f, 0L, SEEK_END) == -1)
> +	goto error;
> +      pos = ftell (f);
> +      if (pos == -1)
> +	goto error;
> +      if (fseek (f, 0L, SEEK_SET) == -1)
> +	goto error;
> +      buffer = (char *) xmalloc (pos * sizeof (char) + 1);
> +      len = fread (buffer, sizeof (char), pos, f);
> +      if (len != (size_t) pos
> +	  /* On Windows, fread may return a value smaller than POS,
> +	     due to CR/LF->CR translation when reading text files.
> +	     That does not in-and-of itself indicate failure.  */
> +	  && ferror (f))
> +	  free (buffer);
> +	  goto error;
> +      /* Add a NUL terminator.  */
> +      buffer[len] = '\0';
> +      /* If the file is empty or contains only whitespace, buildargv would
> +	 return a single empty argument.  In this context we want no arguments,
> +	 instead.  */
> +      if (only_whitespace (buffer))
> +	  file_argv = (char **) xmalloc (sizeof (char *));
> +	  file_argv[0] = NULL;
> +      else
> +	/* Parse the string.  */
> +	file_argv = buildargv (buffer);
> +      /* If *ARGVP is not already dynamically allocated, copy it.  */
> +      if (*argvp == original_argv)
> +	*argvp = dupargv (*argvp);
> +      /* Count the number of arguments.  */
> +      file_argc = 0;
> +      while (file_argv[file_argc])
> +	++file_argc;
> +      /* Free the original option's memory.  */
> +      free ((*argvp)[i]);
> +      /* Now, insert FILE_ARGV into ARGV.  The "+1" below handles the
> +	 NULL terminator at the end of ARGV.  */
> +      *argvp = ((char **)
> +		xrealloc (*argvp,
> +			  (*argcp + file_argc + 1) * sizeof (char *)));
> +      memmove (*argvp + i + file_argc, *argvp + i + 1,
> +	       (*argcp - i) * sizeof (char *));
> +      memcpy (*argvp + i, file_argv, file_argc * sizeof (char *));
> +      /* The original option has been replaced by all the new
> +	 options.  */
> +      *argcp += file_argc - 1;
> +      /* Free up memory allocated to process the response file.  We do
> +	 not use freeargv because the individual options in FILE_ARGV
> +	 are now in the main ARGV.  */
> +      free (file_argv);
> +      free (buffer);
> +      /* Rescan all of the arguments just read to support response
> +	 files that include other response files.  */
> +      --i;
> +    error:
> +      /* We're all done with the file now.  */
> +      fclose (f);
> + at deftypefn Extension int countargv (char * const *@var{argv})
> +Return the number of elements in @var{argv}.
> +Returns zero if @var{argv} is NULL.
> + at end deftypefn
> +int
> +countargv (char * const *argv)
> +  int argc;
> +  if (argv == NULL)
> +    return 0;
> +    continue;
> +  return argc;
> +#ifdef MAIN
> +/* Simple little test driver. */
> +static const char *const tests[] =
> +  "a simple command line",
> +  "arg 'foo' is single quoted",
> +  "arg \"bar\" is double quoted",
> +  "arg \"foo bar\" has embedded whitespace",
> +  "arg 'Jack said \\'hi\\'' has single quotes",
> +  "arg 'Jack said \\\"hi\\\"' has double quotes",
> +  "a b c d e f g h i j k l m n o p q r s t u v w x y z 1 2 3 4 5 6 7 8 9",
> +  /* This should be expanded into only one argument.  */
> +  "trailing-whitespace ",
> +  NULL
> +int
> +main (void)
> +  char **argv;
> +  const char *const *test;
> +  char **targs;
> +  for (test = tests; *test != NULL; test++)
> +      printf ("buildargv(\"%s\")\n", *test);
> +      if ((argv = buildargv (*test)) == NULL)
> +	  printf ("failed!\n\n");
> +      else
> +	  for (targs = argv; *targs != NULL; targs++)
> +	      printf ("\t\"%s\"\n", *targs);
> +	  printf ("\n");
> +      freeargv (argv);
> +  return 0;
> +#endif	/* MAIN */
> diff --git a/rtemstoolkit/wscript b/rtemstoolkit/wscript
> index d1d5127..20b1047 100644
> --- a/rtemstoolkit/wscript
> +++ b/rtemstoolkit/wscript
> @@ -410,7 +410,8 @@ def bld_libiberty(bld, conf):
>                includes = ['libiberty'],
>                cflags = conf['cflags'],
>                defines = defines,
> -              source =['libiberty/concat.c',
> +              source =['libiberty/argv.c',
> +                       'libiberty/concat.c',
>                         'libiberty/cplus-dem.c',
>                         'libiberty/cp-demangle.c',
>                         'libiberty/d-demangle.c',
