[PATCH rtems6 - v1 02/16] Flashdev: Unify IOCTL macro names
Thu Jan 4 20:21:38 UTC 2024
I'm ok with this. I like the subject/verb/direct object naming of the
ioctls.
--joel
On Thu, Jan 4, 2024 at 12:34 PM <berndmoessner80 at gmail.com> wrote:
> From: Bernd Moessner <berndmoessner80 at gmail.com>
>  cpukit/dev/flash/flashdev.c           | 16 ++++++++--------
>  cpukit/include/dev/flash/flashdev.h   | 16 ++++++++--------
>  cpukit/libmisc/shell/main_flashdev.c  | 12 ++++++------
>  testsuites/libtests/flashdev01/init.c | 16 ++++++++--------
>  4 files changed, 30 insertions(+), 30 deletions(-)
> diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
> index be85593201..40666290e0 100644
> --- a/cpukit/dev/flash/flashdev.c
> +++ b/cpukit/dev/flash/flashdev.c
> @@ -362,32 +362,32 @@ static int rtems_flashdev_ioctl(
>        rtems_flashdev_release( flash );
>        err = 0;
>        break;
> -    case RTEMS_FLASHDEV_IOCTL_JEDEC_ID:
> +    case RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID:
>        *( (uint32_t *) arg ) = rtems_flashdev_ioctl_jedec_id( flash );
>        err = 0;
>        break;
>      case RTEMS_FLASHDEV_IOCTL_ERASE:
>        err = rtems_flashdev_ioctl_erase( flash, iop, arg );
>        break;
> -    case RTEMS_FLASHDEV_IOCTL_REGION_SET:
> +    case RTEMS_FLASHDEV_IOCTL_SET_REGION:
>        err = rtems_flashdev_ioctl_set_region( flash, iop, arg );
>        break;
> -    case RTEMS_FLASHDEV_IOCTL_REGION_UNSET:
> +    case RTEMS_FLASHDEV_IOCTL_UNSET_REGION:
>        err = rtems_flashdev_ioctl_clear_region( flash, iop );
>        break;
> -    case RTEMS_FLASHDEV_IOCTL_TYPE:
> +    case RTEMS_FLASHDEV_IOCTL_GET_TYPE:
>        err = rtems_flashdev_ioctl_flash_type( flash, arg );
>        break;
> -    case RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET:
> +    case RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET:
>        err = rtems_flashdev_ioctl_pageinfo_offset( flash, arg );
>        break;
> -    case RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX:
> +    case RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX:
>        err = rtems_flashdev_ioctl_pageinfo_index( flash, arg );
>        break;
> -    case RTEMS_FLASHDEV_IOCTL_PAGE_COUNT:
> +    case RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT:
>        err = rtems_flashdev_ioctl_page_count( flash, arg );
>        break;
> -    case RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE:
> +    case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
>        err = rtems_flashdev_ioctl_write_block_size( flash, arg );
>        break;
> diff --git a/cpukit/include/dev/flash/flashdev.h
> b/cpukit/include/dev/flash/flashdev.h
> index 6759357206..59028a8cba 100644
> --- a/cpukit/include/dev/flash/flashdev.h
> +++ b/cpukit/include/dev/flash/flashdev.h
> @@ -77,7 +77,7 @@ typedef struct rtems_flashdev rtems_flashdev;
>   * @param[out] jedec_id Pointer to uint32_t in which the JEDEC ID is
>   * returned in.
> -#define RTEMS_FLASHDEV_IOCTL_JEDEC_ID 2
> +#define RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID 2
>   * @brief Erases flash device.
> @@ -94,20 +94,20 @@ typedef struct rtems_flashdev rtems_flashdev;
>   * @param[in] region Pointer to rtems_flashdev_region struct containing
>   * base and length of defined region.
> -#define RTEMS_FLASHDEV_IOCTL_REGION_SET 4
> +#define RTEMS_FLASHDEV_IOCTL_SET_REGION 4
>   * @brief Removes the set region on the file descriptor.
>   * This command has no argument.
> -#define RTEMS_FLASHDEV_IOCTL_REGION_UNSET 5
> +#define RTEMS_FLASHDEV_IOCTL_UNSET_REGION 5
>   * @brief Returns the type of flash device (e.g. NOR or NAND).
>   * @param[out] flash_type Pointer to integer which is set to the flash
>   * type macro value.
> -#define RTEMS_FLASHDEV_IOCTL_TYPE 6
> +#define RTEMS_FLASHDEV_IOCTL_GET_TYPE 6
>   * @brief Get the size and address of flash page at given offset
> @@ -118,7 +118,7 @@ typedef struct rtems_flashdev rtems_flashdev;
>   * @param[in,out] rtems_flashdev_ioctl_page_info arg Pointer to struct
>   * with offset and space for return values.
> -#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET 7
> +#define RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET 7
>   * @brief Get the size and address of nth flash page where n is index
> passed in.
> @@ -128,21 +128,21 @@ typedef struct rtems_flashdev rtems_flashdev;
>   * with index and space for return values.
> -#define RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX 8
> +#define RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX 8
>   * @brief Get the number of pages in flash device.
>   * @param[out] count Integer containing the number of pages.
> -#define RTEMS_FLASHDEV_IOCTL_PAGE_COUNT 9
> +#define RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT 9
>   * @brief Get the minimum write size supported by the driver.
>   * @param[out] count Integer containing the minimum write size.
> -#define RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE 10
> +#define RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE 10
>   * @brief The maximum number of region limited file descriptors
> diff --git a/cpukit/libmisc/shell/main_flashdev.c
> b/cpukit/libmisc/shell/main_flashdev.c
> index ca2454b33c..969b0687d2 100644
> --- a/cpukit/libmisc/shell/main_flashdev.c
> +++ b/cpukit/libmisc/shell/main_flashdev.c
> @@ -385,7 +385,7 @@ int flashdev_shell_type( char *dev_path )
>    /* Get type */
>    status = flashdev_shell_ioctl_value(
>      dev_path,
> -    RTEMS_FLASHDEV_IOCTL_TYPE,
> +    RTEMS_FLASHDEV_IOCTL_GET_TYPE,
>      &type
> @@ -416,7 +416,7 @@ int flashdev_shell_jedecid( char *dev_path ) {
>    /* Get JEDEC Id */
>      dev_path,
> -    RTEMS_FLASHDEV_IOCTL_JEDEC_ID,
> +    RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID,
>      &ret
> @@ -440,7 +440,7 @@ static int flashdev_shell_page_off(
>      dev_path,
>      argc,
>      argv,
> -    RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET
> +    RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET
> @@ -454,7 +454,7 @@ static int flashdev_shell_page_idx(
>      dev_path,
>      argc,
>      argv,
> -    RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX
> +    RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX
> @@ -466,7 +466,7 @@ static int flashdev_shell_pg_count( char *dev_path )
>    /* Get Page Count */
>      dev_path,
> -    RTEMS_FLASHDEV_IOCTL_PAGE_COUNT,
> +    RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT,
>      &ret
> @@ -488,7 +488,7 @@ static int flashdev_shell_wb_size( char *dev_path )
>    /* Get Write Block Size */
>      dev_path,
> -    RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE,
> +    RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE,
>      &ret
> diff --git a/testsuites/libtests/flashdev01/init.c
> b/testsuites/libtests/flashdev01/init.c
> index 6ce9709496..30af3f33c1 100644
> --- a/testsuites/libtests/flashdev01/init.c
> +++ b/testsuites/libtests/flashdev01/init.c
> @@ -103,44 +103,44 @@ static void run_test(void) {
>    rtems_test_assert(buff[0] == 0);
>    /* Test getting JEDEC ID */
> -  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_JEDEC_ID, &jedec);
> +  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID, &jedec);
>    rtems_test_assert(!status);
>    rtems_test_assert(jedec == 0x00ABCDEF);
>    /* Test getting flash type */
> -  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_TYPE, &type);
> +  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_TYPE, &type);
>    rtems_test_assert(type == RTEMS_FLASHDEV_NOR);
>    /* Test getting page info from offset */
>    pg_info.location = PAGE_SIZE + PAGE_SIZE/2;
> -  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_OFFSET, &pg_info);
> +  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET,
> &pg_info);
>    rtems_test_assert(pg_info.page_info.offset == PAGE_SIZE);
>    rtems_test_assert(pg_info.page_info.size == PAGE_SIZE);
>    /* Test getting page info from index */
>    pg_info.location = 2;
> -  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_PAGEINFO_BY_INDEX, &pg_info);
> +  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX,
> &pg_info);
>    rtems_test_assert(pg_info.page_info.offset == 2*PAGE_SIZE);
>    /* Test getting page count */
> -  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_PAGE_COUNT, &page_count);
> +  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT, &page_count);
>    rtems_test_assert(page_count == PAGE_COUNT);
>    /* Test getting write block size */
> -  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_WRITE_BLOCK_SIZE, &wb_size);
> +  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE, &wb_size);
>    rtems_test_assert(wb_size == WB_SIZE);
>    /* Test Regions */
>    region.offset = 0x400;
>    region.size = 0x200;
> -  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_REGION_SET, &region);
> +  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_SET_REGION, &region);
>    /* Test read to larger then region */
> @@ -155,7 +155,7 @@ static void run_test(void) {
>    /* Write to base unset region and check the writes location */
>    fseek(file, 0x0, SEEK_SET);
>    fwrite("HELLO WORLD", 11, 1, file);
> -  ioctl(fd, RTEMS_FLASHDEV_IOCTL_REGION_UNSET, NULL);
> +  ioctl(fd, RTEMS_FLASHDEV_IOCTL_UNSET_REGION, NULL);
>    fseek(file, 0x400, SEEK_SET);
>    fgets(buff, 11, file);
>    rtems_test_assert(strncmp(buff, "HELLO WORLD", 11));
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/223740a0/attachment.htm>
