[PATCH rtems6 - v1 03/16] Flashdev: Align IOCTL function and macro names
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Thu Jan 4 18:34:27 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
 cpukit/dev/flash/flashdev.c                   | 72 +++++++++----------
 cpukit/include/dev/flash/flashdev.h           | 12 ++--
 .../libtests/flashdev01/test_flashdev.c       | 36 +++++-----
 3 files changed, 60 insertions(+), 60 deletions(-)
diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
index 40666290e0..27edead968 100644
--- a/cpukit/dev/flash/flashdev.c
+++ b/cpukit/dev/flash/flashdev.c
@@ -99,31 +99,31 @@ static int rtems_flashdev_ioctl_clear_region(
   rtems_libio_t *iop
-static uint32_t rtems_flashdev_ioctl_jedec_id(
+static uint32_t rtems_flashdev_ioctl_get_jedec_id(
   rtems_flashdev *flash
-static uint32_t rtems_flashdev_ioctl_flash_type(
+static uint32_t rtems_flashdev_ioctl_get_flash_type(
   rtems_flashdev *flash,
   void *arg
-static int rtems_flashdev_ioctl_pageinfo_offset(
+static int rtems_flashdev_ioctl_get_pageinfo_offset(
   void *arg
-static int rtems_flashdev_ioctl_pageinfo_index(
+static int rtems_flashdev_ioctl_get_pageinfo_index(
   void *arg
-static int rtems_flashdev_ioctl_page_count(
+static int rtems_flashdev_ioctl_get_page_count(
   void *arg
-static int rtems_flashdev_ioctl_write_block_size(
+static int rtems_flashdev_ioctl_get_write_block_size(
   void *arg
@@ -363,7 +363,7 @@ static int rtems_flashdev_ioctl(
       err = 0;
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID:
-      *( (uint32_t *) arg ) = rtems_flashdev_ioctl_jedec_id( flash );
+      *( (uint32_t *) arg ) = rtems_flashdev_ioctl_get_jedec_id( flash );
       err = 0;
       break;
     case RTEMS_FLASHDEV_IOCTL_ERASE:
@@ -376,19 +376,19 @@ static int rtems_flashdev_ioctl(
       err = rtems_flashdev_ioctl_clear_region( flash, iop );
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_TYPE:
-      err = rtems_flashdev_ioctl_flash_type( flash, arg );
+      err = rtems_flashdev_ioctl_get_flash_type( flash, arg );
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET:
-      err = rtems_flashdev_ioctl_pageinfo_offset( flash, arg );
+      err = rtems_flashdev_ioctl_get_pageinfo_offset( flash, arg );
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX:
-      err = rtems_flashdev_ioctl_pageinfo_index( flash, arg );
+      err = rtems_flashdev_ioctl_get_pageinfo_index( flash, arg );
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT:
-      err = rtems_flashdev_ioctl_page_count( flash, arg );
+      err = rtems_flashdev_ioctl_get_page_count( flash, arg );
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
-      err = rtems_flashdev_ioctl_write_block_size( flash, arg );
+      err = rtems_flashdev_ioctl_get_write_block_size( flash, arg );
       break;
@@ -493,12 +493,12 @@ static int rtems_flashdev_do_init(
   flash->read = NULL;
   flash->write = NULL;
   flash->erase = NULL;
-  flash->jedec_id = NULL;
-  flash->flash_type = NULL;
-  flash->page_info_by_offset = NULL;
-  flash->page_info_by_index = NULL;
-  flash->page_count = NULL;
-  flash->write_block_size = NULL;
+  flash->get_jedec_id = NULL;
+  flash->get_flash_type = NULL;
+  flash->get_page_info_by_offset = NULL;
+  flash->get_page_info_by_index = NULL;
+  flash->get_page_count = NULL;
+  flash->get_write_block_size = NULL;
   flash->region_table = NULL;
   return 0;
@@ -768,29 +768,29 @@ static size_t rtems_flashdev_get_region_size(
   return table->regions[ rtems_flashdev_get_region_index( iop ) ].size;
-static uint32_t rtems_flashdev_ioctl_jedec_id( rtems_flashdev *flash )
+static uint32_t rtems_flashdev_ioctl_get_jedec_id( rtems_flashdev *flash )
-  if ( flash->jedec_id == NULL ) {
+  if ( flash->get_jedec_id == NULL ) {
     return 0;
   } else {
-    return ( *flash->jedec_id )( flash );
+    return ( *flash->get_jedec_id )( flash );
   void *arg
   rtems_flashdev_flash_type *type = (rtems_flashdev_flash_type*)arg;
-  if ( flash->flash_type == NULL ) {
+  if ( flash->get_flash_type == NULL ) {
     return 0;
   } else {
-    return ( *flash->flash_type )( flash, type );
+    return ( *flash->get_flash_type )( flash, type );
   void *arg
@@ -800,18 +800,18 @@ static int rtems_flashdev_ioctl_pageinfo_offset(
   if ( arg == NULL ) {
     rtems_set_errno_and_return_minus_one( EINVAL );
-  if ( flash->page_info_by_offset == NULL ) {
+  if ( flash->get_page_info_by_offset == NULL ) {
     return 0;
   } else {
     page_info = (rtems_flashdev_ioctl_page_info *) arg;
-    return ( *flash->page_info_by_offset )( flash,
+    return ( *flash->get_page_info_by_offset )( flash,
                                          page_info->location,
                                          &page_info->page_info.offset,
                                          &page_info->page_info.size );
-static int rtems_flashdev_ioctl_pageinfo_index( rtems_flashdev *flash,
+static int rtems_flashdev_ioctl_get_pageinfo_index( rtems_flashdev *flash,
                                                 void *arg )
   rtems_flashdev_ioctl_page_info *page_info;
@@ -819,30 +819,30 @@ static int rtems_flashdev_ioctl_pageinfo_index( rtems_flashdev *flash,
-  if ( flash->page_info_by_index == NULL ) {
+  if ( flash->get_page_info_by_index == NULL ) {
     return 0;
   } else {
-    return ( *flash->page_info_by_index )( flash,
+    return ( *flash->get_page_info_by_index )( flash,
-static int rtems_flashdev_ioctl_page_count( rtems_flashdev *flash, void *arg )
+static int rtems_flashdev_ioctl_get_page_count( rtems_flashdev *flash, void *arg )
-  if ( flash->page_count == NULL ) {
+  if ( flash->get_page_count == NULL ) {
     return 0;
   } else {
-    return ( *flash->page_count )( flash, ( (int *) arg ) );
+    return ( *flash->get_page_count )( flash, ( (int *) arg ) );
   void *arg
@@ -850,10 +850,10 @@ static int rtems_flashdev_ioctl_write_block_size(
-  if ( flash->write_block_size == NULL ) {
+  if ( flash->get_write_block_size == NULL ) {
     return 0;
   } else {
-    return ( *flash->write_block_size )( flash, ( (size_t *) arg ) );
+    return ( *flash->get_write_block_size )( flash, ( (size_t *) arg ) );
diff --git a/cpukit/include/dev/flash/flashdev.h b/cpukit/include/dev/flash/flashdev.h
index 59028a8cba..6244d38e3a 100644
--- a/cpukit/include/dev/flash/flashdev.h
+++ b/cpukit/include/dev/flash/flashdev.h
@@ -279,7 +279,7 @@ struct rtems_flashdev {
    * @retval JEDEC ID.
-  uint32_t ( *jedec_id )(
+  uint32_t ( *get_jedec_id )(
@@ -292,7 +292,7 @@ struct rtems_flashdev {
    * @retval 0 Success
    * @retbal Other Failure
-  int ( *flash_type )(
+  int ( *get_flash_type )(
@@ -310,7 +310,7 @@ struct rtems_flashdev {
    * @retval 0 Success.
    * @retval non-zero Failed.
-  int ( *page_info_by_offset )(
+  int ( *get_page_info_by_offset )(
     off_t search_offset,
     off_t *page_offset,
@@ -329,7 +329,7 @@ struct rtems_flashdev {
-  int ( *page_info_by_index )(
+  int ( *get_page_info_by_index )(
     rtems_flashdev *flashdev,
     off_t search_index,
     off_t *page_offset,
@@ -345,7 +345,7 @@ struct rtems_flashdev {
-  int ( *page_count )(
+  int ( *get_page_count )(
     int *page_count
@@ -359,7 +359,7 @@ struct rtems_flashdev {
-  int ( *write_block_size )(
+  int ( *get_write_block_size )(
     size_t *write_block_size
diff --git a/testsuites/libtests/flashdev01/test_flashdev.c b/testsuites/libtests/flashdev01/test_flashdev.c
index 708d708977..d97f5d8145 100644
--- a/testsuites/libtests/flashdev01/test_flashdev.c
+++ b/testsuites/libtests/flashdev01/test_flashdev.c
@@ -49,35 +49,35 @@ typedef struct test_flashdev {
   rtems_flashdev_region regions[MAX_NUM_REGIONS];
 } test_flashdev;
-int test_flashdev_page_by_off(
+int test_flashdev_get_page_by_off(
   off_t *page_offset,
   size_t *page_size
-int test_flashdev_page_by_index(
+int test_flashdev_get_page_by_index(
   off_t search_index,
   off_t *page_offset,
   size_t *page_size
-int test_flashdev_page_count(
+int test_flashdev_get_page_count(
   int *page_count
-int test_flashdev_wb_size(
+int test_flashdev_get_wb_size(
-uint32_t test_flashdev_jedec_id(
+uint32_t test_flashdev_get_jedec_id(
   rtems_flashdev* flash
-int test_flashdev_type(
+int test_flashdev_get_type(
   rtems_flashdev* flash,
   rtems_flashdev_flash_type* type
@@ -103,7 +103,7 @@ int test_flashdev_erase(
 /* Find page info by offset handler */
   off_t *page_offset,
@@ -116,7 +116,7 @@ int test_flashdev_page_by_off(
 /* Find page by index handler */
   off_t search_index,
   off_t *page_offset,
@@ -129,7 +129,7 @@ int test_flashdev_page_by_index(
 /* Page count handler */
   int *page_count
@@ -139,7 +139,7 @@ int test_flashdev_page_count(
 /* Write block size handler */
@@ -151,7 +151,7 @@ int test_flashdev_wb_size(
 /* JEDEC ID handler, this would normally require a READID
  * call to the physical flash device.
@@ -160,7 +160,7 @@ uint32_t test_flashdev_jedec_id(
 /* Function to identify what kind of flash is attached. */
@@ -263,12 +263,12 @@ rtems_flashdev* test_flashdev_init(void)
   flash->read = &test_flashdev_read;
   flash->write = &test_flashdev_write;
   flash->erase = &test_flashdev_erase;
-  flash->jedec_id = &test_flashdev_jedec_id;
-  flash->flash_type = &test_flashdev_type;
-  flash->page_info_by_offset = &test_flashdev_page_by_off;
-  flash->page_info_by_index = &test_flashdev_page_by_index;
-  flash->page_count = &test_flashdev_page_count;
-  flash->write_block_size = &test_flashdev_wb_size;
+  flash->get_jedec_id = &test_flashdev_get_jedec_id;
+  flash->get_flash_type = &test_flashdev_get_type;
+  flash->get_page_info_by_offset = &test_flashdev_get_page_by_off;
+  flash->get_page_info_by_index = &test_flashdev_get_page_by_index;
+  flash->get_page_count = &test_flashdev_get_page_count;
+  flash->get_write_block_size = &test_flashdev_get_wb_size;
   flash->region_table = ftable;
   return flash;
2.34.1
