[PATCH rtems6 - v1 03/16] Flashdev: Align IOCTL function and macro names
Thu Jan 4 20:22:41 UTC 2024
This looks ok to me. Similar naming change.
On Thu, Jan 4, 2024 at 12:34 PM <berndmoessner80 at gmail.com> wrote:
> From: Bernd Moessner <berndmoessner80 at gmail.com>
>  cpukit/dev/flash/flashdev.c                   | 72 +++++++++----------
>  cpukit/include/dev/flash/flashdev.h           | 12 ++--
>  .../libtests/flashdev01/test_flashdev.c       | 36 +++++-----
>  3 files changed, 60 insertions(+), 60 deletions(-)
> diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
> index 40666290e0..27edead968 100644
> --- a/cpukit/dev/flash/flashdev.c
> +++ b/cpukit/dev/flash/flashdev.c
> @@ -99,31 +99,31 @@ static int rtems_flashdev_ioctl_clear_region(
>    rtems_libio_t *iop
> -static uint32_t rtems_flashdev_ioctl_jedec_id(
> +static uint32_t rtems_flashdev_ioctl_get_jedec_id(
>    rtems_flashdev *flash
> -static uint32_t rtems_flashdev_ioctl_flash_type(
> +static uint32_t rtems_flashdev_ioctl_get_flash_type(
>    rtems_flashdev *flash,
>    void *arg
> -static int rtems_flashdev_ioctl_pageinfo_offset(
> +static int rtems_flashdev_ioctl_get_pageinfo_offset(
>    void *arg
> -static int rtems_flashdev_ioctl_pageinfo_index(
> +static int rtems_flashdev_ioctl_get_pageinfo_index(
>    void *arg
> -static int rtems_flashdev_ioctl_page_count(
> +static int rtems_flashdev_ioctl_get_page_count(
>    void *arg
> -static int rtems_flashdev_ioctl_write_block_size(
> +static int rtems_flashdev_ioctl_get_write_block_size(
>    void *arg
> @@ -363,7 +363,7 @@ static int rtems_flashdev_ioctl(
>        err = 0;
>        break;
>      case RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID:
> -      *( (uint32_t *) arg ) = rtems_flashdev_ioctl_jedec_id( flash );
> +      *( (uint32_t *) arg ) = rtems_flashdev_ioctl_get_jedec_id( flash );
>        err = 0;
>        break;
>      case RTEMS_FLASHDEV_IOCTL_ERASE:
> @@ -376,19 +376,19 @@ static int rtems_flashdev_ioctl(
>        err = rtems_flashdev_ioctl_clear_region( flash, iop );
>        break;
>      case RTEMS_FLASHDEV_IOCTL_GET_TYPE:
> -      err = rtems_flashdev_ioctl_flash_type( flash, arg );
> +      err = rtems_flashdev_ioctl_get_flash_type( flash, arg );
>        break;
>      case RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET:
> -      err = rtems_flashdev_ioctl_pageinfo_offset( flash, arg );
> +      err = rtems_flashdev_ioctl_get_pageinfo_offset( flash, arg );
>        break;
>      case RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX:
> -      err = rtems_flashdev_ioctl_pageinfo_index( flash, arg );
> +      err = rtems_flashdev_ioctl_get_pageinfo_index( flash, arg );
>        break;
>      case RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT:
> -      err = rtems_flashdev_ioctl_page_count( flash, arg );
> +      err = rtems_flashdev_ioctl_get_page_count( flash, arg );
>        break;
>      case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
> -      err = rtems_flashdev_ioctl_write_block_size( flash, arg );
> +      err = rtems_flashdev_ioctl_get_write_block_size( flash, arg );
>        break;
> @@ -493,12 +493,12 @@ static int rtems_flashdev_do_init(
>    flash->read = NULL;
>    flash->write = NULL;
>    flash->erase = NULL;
> -  flash->jedec_id = NULL;
> -  flash->flash_type = NULL;
> -  flash->page_info_by_offset = NULL;
> -  flash->page_info_by_index = NULL;
> -  flash->page_count = NULL;
> -  flash->write_block_size = NULL;
> +  flash->get_jedec_id = NULL;
> +  flash->get_flash_type = NULL;
> +  flash->get_page_info_by_offset = NULL;
> +  flash->get_page_info_by_index = NULL;
> +  flash->get_page_count = NULL;
> +  flash->get_write_block_size = NULL;
>    flash->region_table = NULL;
>    return 0;
> @@ -768,29 +768,29 @@ static size_t rtems_flashdev_get_region_size(
>    return table->regions[ rtems_flashdev_get_region_index( iop ) ].size;
> -static uint32_t rtems_flashdev_ioctl_jedec_id( rtems_flashdev *flash )
> +static uint32_t rtems_flashdev_ioctl_get_jedec_id( rtems_flashdev *flash )
> -  if ( flash->jedec_id == NULL ) {
> +  if ( flash->get_jedec_id == NULL ) {
>      return 0;
>    } else {
> -    return ( *flash->jedec_id )( flash );
> +    return ( *flash->get_jedec_id )( flash );
>    void *arg
>    rtems_flashdev_flash_type *type = (rtems_flashdev_flash_type*)arg;
> -  if ( flash->flash_type == NULL ) {
> +  if ( flash->get_flash_type == NULL ) {
>      return 0;
>    } else {
> -    return ( *flash->flash_type )( flash, type );
> +    return ( *flash->get_flash_type )( flash, type );
>    void *arg
> @@ -800,18 +800,18 @@ static int rtems_flashdev_ioctl_pageinfo_offset(
>    if ( arg == NULL ) {
>      rtems_set_errno_and_return_minus_one( EINVAL );
> -  if ( flash->page_info_by_offset == NULL ) {
> +  if ( flash->get_page_info_by_offset == NULL ) {
>      return 0;
>    } else {
>      page_info = (rtems_flashdev_ioctl_page_info *) arg;
> -    return ( *flash->page_info_by_offset )( flash,
> +    return ( *flash->get_page_info_by_offset )( flash,
>                                           page_info->location,
>                                           &page_info->page_info.offset,
>                                           &page_info->page_info.size );
> -static int rtems_flashdev_ioctl_pageinfo_index( rtems_flashdev *flash,
> +static int rtems_flashdev_ioctl_get_pageinfo_index( rtems_flashdev *flash,
>                                                  void *arg )
>    rtems_flashdev_ioctl_page_info *page_info;
> @@ -819,30 +819,30 @@ static int rtems_flashdev_ioctl_pageinfo_index(
> -  if ( flash->page_info_by_index == NULL ) {
> +  if ( flash->get_page_info_by_index == NULL ) {
>      return 0;
>    } else {
> -    return ( *flash->page_info_by_index )( flash,
> +    return ( *flash->get_page_info_by_index )( flash,
> -static int rtems_flashdev_ioctl_page_count( rtems_flashdev *flash, void
> *arg )
> +static int rtems_flashdev_ioctl_get_page_count( rtems_flashdev *flash,
> void *arg )
> -  if ( flash->page_count == NULL ) {
> +  if ( flash->get_page_count == NULL ) {
>      return 0;
>    } else {
> -    return ( *flash->page_count )( flash, ( (int *) arg ) );
> +    return ( *flash->get_page_count )( flash, ( (int *) arg ) );
>    void *arg
> @@ -850,10 +850,10 @@ static int rtems_flashdev_ioctl_write_block_size(
> -  if ( flash->write_block_size == NULL ) {
> +  if ( flash->get_write_block_size == NULL ) {
>      return 0;
>    } else {
> -    return ( *flash->write_block_size )( flash, ( (size_t *) arg ) );
> +    return ( *flash->get_write_block_size )( flash, ( (size_t *) arg ) );
> diff --git a/cpukit/include/dev/flash/flashdev.h
> b/cpukit/include/dev/flash/flashdev.h
> index 59028a8cba..6244d38e3a 100644
> --- a/cpukit/include/dev/flash/flashdev.h
> +++ b/cpukit/include/dev/flash/flashdev.h
> @@ -279,7 +279,7 @@ struct rtems_flashdev {
>     * @retval JEDEC ID.
> -  uint32_t ( *jedec_id )(
> +  uint32_t ( *get_jedec_id )(
> @@ -292,7 +292,7 @@ struct rtems_flashdev {
>     * @retval 0 Success
>     * @retbal Other Failure
> -  int ( *flash_type )(
> +  int ( *get_flash_type )(
> @@ -310,7 +310,7 @@ struct rtems_flashdev {
>     * @retval 0 Success.
>     * @retval non-zero Failed.
> -  int ( *page_info_by_offset )(
> +  int ( *get_page_info_by_offset )(
>      off_t search_offset,
>      off_t *page_offset,
> @@ -329,7 +329,7 @@ struct rtems_flashdev {
> -  int ( *page_info_by_index )(
> +  int ( *get_page_info_by_index )(
>      rtems_flashdev *flashdev,
>      off_t search_index,
>      off_t *page_offset,
> @@ -345,7 +345,7 @@ struct rtems_flashdev {
> -  int ( *page_count )(
> +  int ( *get_page_count )(
>      int *page_count
> @@ -359,7 +359,7 @@ struct rtems_flashdev {
> -  int ( *write_block_size )(
> +  int ( *get_write_block_size )(
>      size_t *write_block_size
> diff --git a/testsuites/libtests/flashdev01/test_flashdev.c
> b/testsuites/libtests/flashdev01/test_flashdev.c
> index 708d708977..d97f5d8145 100644
> --- a/testsuites/libtests/flashdev01/test_flashdev.c
> +++ b/testsuites/libtests/flashdev01/test_flashdev.c
> @@ -49,35 +49,35 @@ typedef struct test_flashdev {
>    rtems_flashdev_region regions[MAX_NUM_REGIONS];
>  } test_flashdev;
> -int test_flashdev_page_by_off(
> +int test_flashdev_get_page_by_off(
>    off_t *page_offset,
>    size_t *page_size
> -int test_flashdev_page_by_index(
> +int test_flashdev_get_page_by_index(
>    off_t search_index,
>    off_t *page_offset,
>    size_t *page_size
> -int test_flashdev_page_count(
> +int test_flashdev_get_page_count(
>    int *page_count
> -int test_flashdev_wb_size(
> +int test_flashdev_get_wb_size(
> -uint32_t test_flashdev_jedec_id(
> +uint32_t test_flashdev_get_jedec_id(
>    rtems_flashdev* flash
> -int test_flashdev_type(
> +int test_flashdev_get_type(
>    rtems_flashdev* flash,
>    rtems_flashdev_flash_type* type
> @@ -103,7 +103,7 @@ int test_flashdev_erase(
>  /* Find page info by offset handler */
>    off_t *page_offset,
> @@ -116,7 +116,7 @@ int test_flashdev_page_by_off(
>  /* Find page by index handler */
>    off_t search_index,
>    off_t *page_offset,
> @@ -129,7 +129,7 @@ int test_flashdev_page_by_index(
>  /* Page count handler */
>    int *page_count
> @@ -139,7 +139,7 @@ int test_flashdev_page_count(
>  /* Write block size handler */
> @@ -151,7 +151,7 @@ int test_flashdev_wb_size(
>  /* JEDEC ID handler, this would normally require a READID
>   * call to the physical flash device.
> @@ -160,7 +160,7 @@ uint32_t test_flashdev_jedec_id(
>  /* Function to identify what kind of flash is attached. */
> @@ -263,12 +263,12 @@ rtems_flashdev* test_flashdev_init(void)
>    flash->read = &test_flashdev_read;
>    flash->write = &test_flashdev_write;
>    flash->erase = &test_flashdev_erase;
> -  flash->jedec_id = &test_flashdev_jedec_id;
> -  flash->flash_type = &test_flashdev_type;
> -  flash->page_info_by_offset = &test_flashdev_page_by_off;
> -  flash->page_info_by_index = &test_flashdev_page_by_index;
> -  flash->page_count = &test_flashdev_page_count;
> -  flash->write_block_size = &test_flashdev_wb_size;
> +  flash->get_jedec_id = &test_flashdev_get_jedec_id;
> +  flash->get_flash_type = &test_flashdev_get_type;
> +  flash->get_page_info_by_offset = &test_flashdev_get_page_by_off;
> +  flash->get_page_info_by_index = &test_flashdev_get_page_by_index;
> +  flash->get_page_count = &test_flashdev_get_page_count;
> +  flash->get_write_block_size = &test_flashdev_get_wb_size;
>    flash->region_table = ftable;
>    return flash;
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/27b78add/attachment-0001.htm>
