[PATCH rtems6 - v1 04/16] Flashdev: Align IOCTL and shell function names
Thu Jan 4 20:23:19 UTC 2024
This looks ok to me. Just more name realignment which shouldn't impact much.
On Thu, Jan 4, 2024 at 12:34 PM <berndmoessner80 at gmail.com> wrote:
> From: Bernd Moessner <berndmoessner80 at gmail.com>
>  cpukit/libmisc/shell/main_flashdev.c | 36 ++++++++++++++--------------
>  1 file changed, 18 insertions(+), 18 deletions(-)
> diff --git a/cpukit/libmisc/shell/main_flashdev.c
> b/cpukit/libmisc/shell/main_flashdev.c
> index 969b0687d2..516c77ae27 100644
> --- a/cpukit/libmisc/shell/main_flashdev.c
> +++ b/cpukit/libmisc/shell/main_flashdev.c
> @@ -35,12 +35,12 @@
>  static int flashdev_shell_read(char *dev_path, int argc, char *argv[]);
>  static int flashdev_shell_write(char *dev_path, int argc, char *argv[]);
>  static int flashdev_shell_erase(char *dev_path, int argc, char *argv[]);
> -static int flashdev_shell_type(char *dev_path);
> -static int flashdev_shell_jedecid(char *dev_path);
> -static int flashdev_shell_page_off(char *dev_path, int argc, char
> *argv[]);
> -static int flashdev_shell_page_idx(char *dev_path, int argc, char
> *argv[]);
> -static int flashdev_shell_pg_count(char *dev_path);
> -static int flashdev_shell_wb_size(char *dev_path);
> +static int flashdev_shell_get_type(char *dev_path);
> +static int flashdev_shell_get_jedec_id(char *dev_path);
> +static int flashdev_shell_get_page_by_off(char *dev_path, int argc, char
> *argv[]);
> +static int flashdev_shell_get_page_by_idx(char *dev_path, int argc, char
> *argv[]);
> +static int flashdev_shell_get_pg_count(char *dev_path);
> +static int flashdev_shell_get_wb_size(char *dev_path);
>  static int flashdev_shell_ioctl_value(
>    char *dev_path,
> @@ -99,22 +99,22 @@ static int rtems_flashdev_shell_main( int argc, char
> *argv[] ) {
>          return flashdev_shell_erase(dev_path, argc, &argv[i]);
>        case ('t'):
>          /* Flash Type */
> -        return flashdev_shell_type(dev_path);
> +        return flashdev_shell_get_type(dev_path);
>        case ('d'):
>          /* JEDEC Id */
> -        return flashdev_shell_jedecid(dev_path);
> +        return flashdev_shell_get_jedec_id(dev_path);
>        case ('o'):
>          /* Page info by offset */
> -        return flashdev_shell_page_off(dev_path, argc, &argv[i]);
> +        return flashdev_shell_get_page_by_off(dev_path, argc, &argv[i]);
>        case ('i'):
>          /* Page info by index */
> -        return flashdev_shell_page_idx(dev_path, argc, &argv[i]);
> +        return flashdev_shell_get_page_by_idx(dev_path, argc, &argv[i]);
>        case ('p'):
>          /* Page count */
> -        return flashdev_shell_pg_count(dev_path);
> +        return flashdev_shell_get_pg_count(dev_path);
>        case ('b'):
>          /* Write block size */
> -        return flashdev_shell_wb_size(dev_path);
> +        return flashdev_shell_get_wb_size(dev_path);
>        case ('h'):
>        default:
>          /* Help */
> @@ -377,7 +377,7 @@ int flashdev_shell_erase(
>    return 0;
> -int flashdev_shell_type( char *dev_path )
> +int flashdev_shell_get_type( char *dev_path )
>    int type;
>    int status;
> @@ -409,7 +409,7 @@ int flashdev_shell_type( char *dev_path )
>    return 0;
> -int flashdev_shell_jedecid( char *dev_path ) {
> +int flashdev_shell_get_jedec_id( char *dev_path ) {
>    uint32_t ret;
>    int status;
> @@ -430,7 +430,7 @@ int flashdev_shell_jedecid( char *dev_path ) {
>    return 0;
>    char *dev_path,
>    int argc,
>    char *argv[]
> @@ -444,7 +444,7 @@ static int flashdev_shell_page_off(
>    char *dev_path,
>    int argc,
>    char *argv[]
> @@ -458,7 +458,7 @@ static int flashdev_shell_page_idx(
> -static int flashdev_shell_pg_count( char *dev_path )
> +static int flashdev_shell_get_pg_count( char *dev_path )
>    uint32_t ret;
>    int status;
> @@ -480,7 +480,7 @@ static int flashdev_shell_pg_count( char *dev_path )
>    return 0;
> -static int flashdev_shell_wb_size( char *dev_path )
> +static int flashdev_shell_get_wb_size( char *dev_path )
>    size_t ret;
>    int status;
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/8aae63f1/attachment.htm>
