[PATCH rtems6 - v1 05/16] FIX: Add missing default case
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Thu Jan 4 18:34:29 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
 cpukit/dev/flash/flashdev.c | 2 ++
 1 file changed, 2 insertions(+)
diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
index 27edead968..8bd3d11246 100644
--- a/cpukit/dev/flash/flashdev.c
+++ b/cpukit/dev/flash/flashdev.c
@@ -390,6 +390,8 @@ static int rtems_flashdev_ioctl(
     case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
       err = rtems_flashdev_ioctl_get_write_block_size( flash, arg );
       break;
+    default:
+      err = EINVAL;
   rtems_flashdev_release( flash );
2.34.1
