[PATCH rtems6 - v1 05/16] FIX: Add missing default case
Bernd Moessner berndmoessner80 at gmail.com
Thu Jan 4 20:24:54 UTC 2024
Dear Kinsey,
sry for the stupid question. What is the correct way to reference the issue
[#4981 <https://devel.rtems.org/ticket/4981> rtems6 - v1 05/16] FIX: Add
or
[PATCH rtems6 - v1 05/16] #4981 <https://devel.rtems.org/ticket/4981>
On 04.01.2024 19:48, Kinsey Moore wrote:
> All of the patches here need an issue reference. Beyond that, this
> patch is good to go in. I'm still reviewing the remainder of the set
> and I'll leave the renaming discussion to Aaron.
> Kinsey
> On Thu, Jan 4, 2024 at 12:35 PM <berndmoessner80 at gmail.com> wrote:
>     From: Bernd Moessner <berndmoessner80 at gmail.com>
>      cpukit/dev/flash/flashdev.c | 2 ++
>      1 file changed, 2 insertions(+)
>     diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
>     index 27edead968..8bd3d11246 100644
>     --- a/cpukit/dev/flash/flashdev.c
>     +++ b/cpukit/dev/flash/flashdev.c
>     @@ -390,6 +390,8 @@ static int rtems_flashdev_ioctl(
>          case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
>            err = rtems_flashdev_ioctl_get_write_block_size( flash, arg );
>            break;
>     +    default:
>     +      err = EINVAL;
>        rtems_flashdev_release( flash );
>     2.34.1
>     _______________________________________________
>     devel mailing list
>     devel at rtems.org
>     http://lists.rtems.org/mailman/listinfo/devel
