[PATCH rtems6 - v1 05/16] FIX: Add missing default case
Thu Jan 4 20:24:52 UTC 2024
On Thu, Jan 4, 2024 at 12:49 PM Kinsey Moore <kinsey.moore at oarcorp.com>
wrote:
> All of the patches here need an issue reference. Beyond that, this patch
> is good to go in. I'm still reviewing the remainder of the set and I'll
> leave the renaming discussion to Aaron.
I have only gotten this far into the patch set but I agree with Kinsey that
they look ok.
Aaron should ack though. Hopefully that won't take long.
> Kinsey
> On Thu, Jan 4, 2024 at 12:35 PM <berndmoessner80 at gmail.com> wrote:
>> From: Bernd Moessner <berndmoessner80 at gmail.com>
>>  cpukit/dev/flash/flashdev.c | 2 ++
>>  1 file changed, 2 insertions(+)
>> diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
>> index 27edead968..8bd3d11246 100644
>> --- a/cpukit/dev/flash/flashdev.c
>> +++ b/cpukit/dev/flash/flashdev.c
>> @@ -390,6 +390,8 @@ static int rtems_flashdev_ioctl(
>>      case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
>>        err = rtems_flashdev_ioctl_get_write_block_size( flash, arg );
>>        break;
>> +    default:
>> +      err = EINVAL;
>>    rtems_flashdev_release( flash );
>> 2.34.1
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/b11392d4/attachment.htm>
