[PATCH rtems-lwip - v1 05/11] FIX: remove header files which are already provided by RTEMS
Kinsey Moore kinsey.moore at oarcorp.com
Thu Jan 4 22:16:16 UTC 2024
This change looks good.
Kinsey
On Thu, Jan 4, 2024 at 12:54 PM <berndmoessner80 at gmail.com> wrote:
> From: Bernd Moessner <berndmoessner80 at gmail.com>
>  defs/bsps/aarch64/xilinx_zynqmp_base.json     |   3 +-
>  .../src/arm/ARMv8/64bit/xil_cache.h           |  75 ----
>  .../standalone/src/arm/common/xil_exception.h | 408 ------------------
>  rtemslwip/xilinx/xil_printf.h                 |  33 --
>  rtemslwip/xilinx/xil_smc.h                    |   1 -
>  5 files changed, 1 insertion(+), 519 deletions(-)
>  delete mode 100644
> embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
>  delete mode 100644
> embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
>  delete mode 100644 rtemslwip/xilinx/xil_printf.h
>  delete mode 100644 rtemslwip/xilinx/xil_smc.h
> diff --git a/defs/bsps/aarch64/xilinx_zynqmp_base.json
> b/defs/bsps/aarch64/xilinx_zynqmp_base.json
> index 3e47434..600415d 100644
> --- a/defs/bsps/aarch64/xilinx_zynqmp_base.json
> +++ b/defs/bsps/aarch64/xilinx_zynqmp_base.json
> @@ -6,8 +6,7 @@
>                 "embeddedsw/XilinxProcessorIPLib/drivers/emacps/src",
>                 "rtemslwip/xilinx",
>                 "rtemslwip/zynqmp",
> -               "embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit",
> -               "embeddedsw/lib/bsp/standalone/src/arm/common"
> +               "embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit"
>         "source-files-to-import": [
>                 "rtemslwip/zynqmp/xemacps_g.c",
> diff --git a/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
> b/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
> deleted file mode 100644
> index b878d05..0000000
> --- a/embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit/xil_cache.h
> +++ /dev/null
> @@ -1,75 +0,0 @@
> -* Copyright (c) 2014 - 2021 Xilinx, Inc.  All rights reserved.
> -* SPDX-License-Identifier: MIT
> -* @file xil_cache.h
> -* @addtogroup a53_64_cache_apis Cortex A53 64bit Processor Cache Functions
> -* Cache functions provide access to cache related operations such as flush
> -* and invalidate for instruction and data caches. It gives option to
> perform
> -* the cache operations on a single cacheline, a range of memory and an
> entire
> -* cache.
> -* <pre>
> -* MODIFICATION HISTORY:
> -* Ver   Who  Date     Changes
> -* 5.00         pkp  05/29/14 First release
> -* </pre>
> -#ifndef XIL_CACHE_H
> -#define XIL_CACHE_H
> -#include "xil_types.h"
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> - *@cond nocomments
> -/************************** Constant Definitions
> -#define L1_DATA_PREFETCH_CONTROL_MASK  0xE000
> -#define L1_DATA_PREFETCH_CONTROL_SHIFT  13
> - *@endcond
> -/***************** Macros (Inline Functions) Definitions
> -#define Xil_DCacheFlushRange Xil_DCacheInvalidateRange
> -/************************** Function Prototypes
> -void Xil_DCacheEnable(void);
> -void Xil_DCacheDisable(void);
> -void Xil_DCacheInvalidate(void);
> -void Xil_DCacheInvalidateRange(INTPTR adr, INTPTR len);
> -void Xil_DCacheInvalidateLine(INTPTR adr);
> -void Xil_DCacheFlush(void);
> -void Xil_DCacheFlushLine(INTPTR adr);
> -void Xil_ICacheEnable(void);
> -void Xil_ICacheDisable(void);
> -void Xil_ICacheInvalidate(void);
> -void Xil_ICacheInvalidateRange(INTPTR adr, INTPTR len);
> -void Xil_ICacheInvalidateLine(INTPTR adr);
> -void Xil_ConfigureL1Prefetch(u8 num);
> -#ifdef __cplusplus
> -#endif
> -#endif
> -* @} End of "addtogroup a53_64_cache_apis".
> diff --git a/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
> b/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
> index 144d842..0000000
> --- a/embeddedsw/lib/bsp/standalone/src/arm/common/xil_exception.h
> +++ /dev/null
> @@ -1,408 +0,0 @@
> -* Copyright (c) 2015 - 2022 Xilinx, Inc.  All rights reserved.
> -* @file xil_exception.h
> -* This header file contains ARM Cortex A53,A9,R5 specific exception
> related APIs.
> -* For exception related functions that can be used across all Xilinx
> supported
> -* processors, please use xil_exception.h.
> -* @addtogroup arm_exception_apis ARM Processor Exception Handling
> -* ARM processors specific exception related APIs for cortex A53,A9 and R5
> can
> -* utilized for enabling/disabling IRQ, registering/removing handler for
> -* exceptions or initializing exception vector table with null handler.
> -* <pre>
> -* 5.2  pkp      28/05/15 First release
> -* 6.0   mus      27/07/16 Consolidated file for a53,a9 and r5 processors
> -* 6.7   mna      26/04/18 Add API Xil_GetExceptionRegisterHandler.
> -* 6.7   asa      18/05/18 Update signature of API
> -* 7.0   mus      01/03/19 Tweak Xil_ExceptionEnableMask and
> -*                         Xil_ExceptionDisableMask macros to support
> legacy
> -*                         examples for Cortexa72 EL3 exception level.
> -* 7.3   mus      04/15/20 Added Xil_EnableNestedInterrupts and
> -*                         Xil_DisableNestedInterrupts macros for ARMv8.
> -*                         For Cortexa72, these macro's would not be
> supported
> -*                         at EL3, as Cortexa72 is using GIC-500(GICv3),
> which
> -*                         triggeres only FIQ at EL3. Fix for CR#1062506
> -* 7.6   mus      09/17/21 Updated flag checking to fix warning reported
> with
> -*                         -Wundef compiler option CR#1110261
> -* 7.7   mus      01/31/22 Few of the #defines in xil_exception.h in are
> treated
> -*                         in different way based on "versal" flag. In
> existing
> -*                         flow, this flag is defined only in
> xparameters.h and
> -*                         BSP compiler flags, it is not defined in
> application
> -*                         compiler flags. So, including xil_exception.h in
> -*                         application source file, without including
> -*                         xparameters.h results  in incorrect behavior.
> -*                         Including xparameters.h in xil_exception.h to
> avoid
> -*                         such issues. It fixes CR#1120498.
> -* 7.7  sk       03/02/22 Define XExc_VectorTableEntry structure to fix
> -*                        misra_c_2012_rule_5_6 violation.
> -* 7.7  sk       03/02/22 Add XExc_VectorTable as extern to fix
> misra_c_2012_
> -*                        rule_8_4 violation.
> -* </pre>
> - *@cond nocomments
> -#ifndef XIL_EXCEPTION_H /* prevent circular inclusions */
> -#define XIL_EXCEPTION_H /* by using protection macros */
> -/***************************** Include Files
> -#include "xpseudo_asm.h"
> -#include "bspconfig.h"
> -#include "xparameters.h"
> -#ifdef __cplusplus
> -extern "C" {
> -#endif
> -#define XIL_EXCEPTION_FIQ      XREG_CPSR_FIQ_ENABLE
> -#define XIL_EXCEPTION_IRQ      XREG_CPSR_IRQ_ENABLE
> -#define XIL_EXCEPTION_ALL      (XREG_CPSR_FIQ_ENABLE |
> XREG_CPSR_IRQ_ENABLE)
> -#define XIL_EXCEPTION_ID_FIRST                 0U
> -#if defined (__aarch64__)
> -#define XIL_EXCEPTION_ID_SYNC_INT              1U
> -#define XIL_EXCEPTION_ID_IRQ_INT               2U
> -#define XIL_EXCEPTION_ID_FIQ_INT               3U
> -#define XIL_EXCEPTION_ID_SERROR_ABORT_INT              4U
> -#define XIL_EXCEPTION_ID_LAST                  5U
> -#else
> -#define XIL_EXCEPTION_ID_RESET                 0U
> -#define XIL_EXCEPTION_ID_UNDEFINED_INT         1U
> -#define XIL_EXCEPTION_ID_SWI_INT               2U
> -#define XIL_EXCEPTION_ID_PREFETCH_ABORT_INT    3U
> -#define XIL_EXCEPTION_ID_DATA_ABORT_INT                4U
> -#define XIL_EXCEPTION_ID_IRQ_INT               5U
> -#define XIL_EXCEPTION_ID_FIQ_INT               6U
> -#define XIL_EXCEPTION_ID_LAST                  6U
> -#endif
> - * XIL_EXCEPTION_ID_INT is defined for all Xilinx processors.
> -#if defined (versal) && !defined(ARMR5) && EL3
> -#define XIL_EXCEPTION_ID_INT    XIL_EXCEPTION_ID_FIQ_INT
> -#else
> -#define XIL_EXCEPTION_ID_INT   XIL_EXCEPTION_ID_IRQ_INT
> -#endif
> -/**************************** Type Definitions
> - * This typedef is the exception handler function.
> -typedef void (*Xil_ExceptionHandler)(void *data);
> -typedef void (*Xil_InterruptHandler)(void *data);
> -typedef struct {
> -        Xil_ExceptionHandler Handler;
> -        void *Data;
> -} XExc_VectorTableEntry;
> -extern XExc_VectorTableEntry XExc_VectorTable[];
> -*@endcond
> -* @brief       Enable Exceptions.
> -* @param       Mask: Value for enabling the exceptions.
> -* @return      None.
> -* @note                If bit is 0, exception is enabled.
> -*                      C-Style signature: void
> Xil_ExceptionEnableMask(Mask)
> - * Cortexa72 processor in versal is coupled with GIC-500, and GIC-500
> supports
> - * only FIQ at EL3. Hence, tweaking this macro to always enable FIQ
> - * ignoring argument passed by user.
> -#define Xil_ExceptionEnableMask(Mask)  \
> -               mtcpsr(mfcpsr() & ~ ((XIL_EXCEPTION_FIQ) &
> XIL_EXCEPTION_ALL))
> -#elif defined (__GNUC__) || defined (__ICCARM__)
> -               mtcpsr(mfcpsr() & ~ ((Mask) & XIL_EXCEPTION_ALL))
> -#else
> -                 register u32 Reg __asm("cpsr"); \
> -                 mtcpsr((Reg) & (~((Mask) & XIL_EXCEPTION_ALL))); \
> -#endif
> -* @brief       Enable the IRQ exception.
> -* @return   None.
> -* @note     None.
> -#define Xil_ExceptionEnable() \
> -                Xil_ExceptionEnableMask(XIL_EXCEPTION_FIQ)
> -#else
> -               Xil_ExceptionEnableMask(XIL_EXCEPTION_IRQ)
> -#endif
> -* @brief       Disable Exceptions.
> -* @param       Mask: Value for disabling the exceptions.
> -* @return      None.
> -* @note                If bit is 1, exception is disabled.
> -*                      C-Style signature: Xil_ExceptionDisableMask(Mask)
> supports
> - * only FIQ at EL3. Hence, tweaking this macro to always disable FIQ
> -#define Xil_ExceptionDisableMask(Mask) \
> -               mtcpsr(mfcpsr() | ((XIL_EXCEPTION_FIQ) &
> XIL_EXCEPTION_ALL))
> -               mtcpsr(mfcpsr() | ((Mask) & XIL_EXCEPTION_ALL))
> -#else
> -                 mtcpsr((Reg) | ((Mask) & XIL_EXCEPTION_ALL)); \
> -#endif
> -* Disable the IRQ exception.
> -* @return   None.
> -* @note     None.
> -#define Xil_ExceptionDisable() \
> -               Xil_ExceptionDisableMask(XIL_EXCEPTION_IRQ)
> -#if ( defined (PLATFORM_ZYNQMP) && defined (EL3) && (EL3==1) )
> -* @brief       Enable nested interrupts by clearing the I bit in DAIF.This
> -*                      macro is defined for Cortex-A53 64 bit mode BSP
> configured to run
> -*                      at EL3.. However,it is not defined for Versal
> Cortex-A72 BSP
> -*                      configured to run at EL3. Reason is, Cortex-A72 is
> coupled
> -*                      with GIC-500(GICv3 specifications) and it triggers
> only FIQ at EL3.
> -* @return   None.
> -* @note     This macro is supposed to be used from interrupt handlers. In
> the
> -*                      interrupt handler the interrupts are disabled by
> default (I bit
> -*                      is set as 1). To allow nesting of interrupts, this
> macro should be
> -*                      used. It clears the I bit. Once that bit is
> cleared and provided the
> -*                      preemption of interrupt conditions are met in the
> GIC, nesting of
> -*                      interrupts will start happening.
> -*                      Caution: This macro must be used with caution.
> Before calling this
> -*                      macro, the user must ensure that the source of the
> current IRQ
> -*                      is appropriately cleared. Otherwise, as soon as we
> clear the I
> -*                      bit, there can be an infinite loop of interrupts
> with an
> -*                      eventual crash (all the stack space getting
> consumed).
> -#define Xil_EnableNestedInterrupts() \
> -                __asm__ __volatile__ ("mrs    X1, ELR_EL3"); \
> -                __asm__ __volatile__ ("mrs    X2, SPSR_EL3");  \
> -                __asm__ __volatile__ ("stp    X1,X2, [sp,#-0x10]!"); \
> -                __asm__ __volatile__ ("mrs    X1, DAIF");  \
> -                __asm__ __volatile__ ("bic    X1,X1,#(0x1<<7)");  \
> -                __asm__ __volatile__ ("msr    DAIF, X1");  \
> -* @brief       Disable the nested interrupts by setting the I bit in
> DAIF. This
> configured to run
> -*                      at EL3.
> -* @return   None.
> -* @note     This macro is meant to be called in the interrupt service
> routines.
> -*                      This macro cannot be used independently. It can
> only be used when
> -*                      nesting of interrupts have been enabled by using
> the macro
> -*                      Xil_EnableNestedInterrupts(). In a typical flow,
> the user first
> -*                      calls the Xil_EnableNestedInterrupts in the ISR at
> the appropriate
> -*                      point. The user then must call this macro before
> exiting the interrupt
> -*                      service routine. This macro puts the ARM back in
> IRQ mode and
> -*                      hence sets back the I bit.
> -#define Xil_DisableNestedInterrupts() \
> -                __asm__ __volatile__ ("ldp    X1,X2, [sp,#0x10]!"); \
> -                __asm__ __volatile__ ("msr    ELR_EL3, X1"); \
> -                __asm__ __volatile__ ("msr    SPSR_EL3, X2"); \
> -                __asm__ __volatile__ ("orr    X1, X1, #(0x1<<7)"); \
> -#elif (defined (EL1_NONSECURE) && (EL1_NONSECURE==1))
> -*                      macro is defined for Cortex-A53 64 bit mode and
> Cortex-A72 64 bit
> -*                      BSP configured to run at EL1 NON SECURE
> -* @return   None.
> the
> default (I bit
> macro should be
> GIC, nesting of
> Before calling this
> current IRQ
> clear the I
> with an
> consumed).
> -                __asm__ __volatile__ ("mrs    X1, ELR_EL1"); \
> -                __asm__ __volatile__ ("mrs    X2, SPSR_EL1");  \
> DAIF. This
> Cortex-A72 64 bit
> -* @return   None.
> routines.
> only be used when
> the macro
> the user first
> the appropriate
> IRQ mode and
> -                __asm__ __volatile__ ("msr    ELR_EL1, X1"); \
> -                __asm__ __volatile__ ("msr    SPSR_EL1, X2"); \
> -#elif (!defined (__aarch64__) && !defined (ARMA53_32))
> -* @brief       Enable nested interrupts by clearing the I and F bits in
> CPSR. This
> -*                      API is defined for cortex-a9 and cortex-r5.
> -* @return   None.
> the
> default (I and F
> -*                      are 1). To allow nesting of interrupts, this macro
> should be
> -*                      used. It clears the I and F bits by changing the
> ARM mode to
> -*                      system mode. Once these bits are cleared and
> provided the
> GIC, nesting of
> Before calling this
> current IRQ
> clear the I and
> -*                      F bits, there can be an infinite loop of
> interrupts with an
> consumed).
> -               __asm__ __volatile__ ("stmfd   sp!, {lr}"); \
> -               __asm__ __volatile__ ("mrs     lr, spsr");  \
> -               __asm__ __volatile__ ("msr     cpsr_c, #0x1F"); \
> -* @brief       Disable the nested interrupts by setting the I and F bits.
> This API
> -*                      is defined for cortex-a9 and cortex-r5.
> -* @return   None.
> routines.
> only be used when
> the macro
> the user first
> the appropriate
> IRQ/FIQ mode and
> -*                      hence sets back the I and F bits.
> -               __asm__ __volatile__ ("ldmfd   sp!, {lr}");   \
> -               __asm__ __volatile__ ("msr     cpsr_c, #0x92"); \
> -               __asm__ __volatile__ ("msr     spsr_cxsf, lr"); \
> -#endif
> -/************************** Variable Definitions
> -extern void Xil_ExceptionRegisterHandler(u32 Exception_id,
> -                                        Xil_ExceptionHandler Handler,
> -                                        void *Data);
> -extern void Xil_ExceptionRemoveHandler(u32 Exception_id);
> -extern void Xil_GetExceptionRegisterHandler(u32 Exception_id,
> -                                       Xil_ExceptionHandler *Handler,
> void **Data);
> -extern void Xil_ExceptionInit(void);
> -void Xil_SyncAbortHandler(void *CallBackRef);
> -void Xil_SErrorAbortHandler(void *CallBackRef);
> -#else
> -extern void Xil_DataAbortHandler(void *CallBackRef);
> -extern void Xil_PrefetchAbortHandler(void *CallBackRef);
> -extern void Xil_UndefinedExceptionHandler(void *CallBackRef);
> -#endif
> -#ifdef __cplusplus
> -#endif /* __cplusplus */
> -#endif /* XIL_EXCEPTION_H */
> -* @} End of "addtogroup arm_exception_apis".
> diff --git a/rtemslwip/xilinx/xil_printf.h b/rtemslwip/xilinx/xil_printf.h
> index 3da55bd..0000000
> --- a/rtemslwip/xilinx/xil_printf.h
> +++ /dev/null
> @@ -1,33 +0,0 @@
> - * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
> - * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> - * Redistribution and use in source and binary forms, with or without
> - * modification, are permitted provided that the following conditions
> - * are met:
> - * 1. Redistributions of source code must retain the above copyright
> - *    notice, this list of conditions and the following disclaimer.
> - * 2. Redistributions in binary form must reproduce the above copyright
> - *    notice, this list of conditions and the following disclaimer in the
> - *    documentation and/or other materials provided with the distribution.
> - * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> - * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> - * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> - * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> - * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> - * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> - * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> - * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> - * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> - * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> - * POSSIBILITY OF SUCH DAMAGE.
> -#ifndef XIL_PRINTF_H
> -#define XIL_PRINTF_H
> -#define xil_printf( args ... ) printf( args )
> -#define print( args ... ) printf( args )
> -#endif
> diff --git a/rtemslwip/xilinx/xil_smc.h b/rtemslwip/xilinx/xil_smc.h
> index d35e631..0000000
> --- a/rtemslwip/xilinx/xil_smc.h
> +++ /dev/null
> @@ -1 +0,0 @@
> -/* This file is a stub and intentionally left blank */
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240104/26657693/attachment-0001.htm>
