[PATCH rtems-lwip 1/1] Add ZYNQ 7000 support
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Sat Jan 6 15:15:19 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
This patch adds support for the Xilinx ZYNQ 7000 series. Please note that this patch also affects ZYNQ Ultrascale+ as I`ve moved some functions from zynqmp/xil_shims.c to xilinx/freertos.c and xilinx/xscugic.c to share them between both families.
 defs/bsps/aarch64/xilinx_zynqmp_base.json     |  2 +
 defs/bsps/arm/xilinx_zynq_base.json           | 28 ++++++
 defs/bsps/arm/xilinx_zynq_picozed.json        | 13 +++
 .../ports/xilinx/include/netif/xadapter.h     |  4 +
 .../contrib/ports/xilinx/netif/xemacpsif.c    | 18 ++++
 .../ports/xilinx/netif/xemacpsif_dma.c        | 14 +++
 .../bsp/standalone/src/arm/cortexa9/xil_mmu.h | 92 +++++++++++++++++++
 rtemslwip/xilinx/freertos.c                   | 64 +++++++++++++
 rtemslwip/xilinx/xpseudo_asm.h                |  5 +
 rtemslwip/xilinx/xscugic_hw.c                 | 40 ++++++++
 rtemslwip/zynq/common_lwipopts.h              |  3 +
 rtemslwip/zynq/xil_shims.c                    | 42 +++++++++
 rtemslwip/zynq/xlwipconfig.h                  | 38 ++++++++
 rtemslwip/zynq_picozed/lwipbspopts.h          |  1 +
 rtemslwip/zynq_picozed/netstart.c             | 66 +++++++++++++
 rtemslwip/zynq_picozed/xemacps_g.c            | 35 +++++++
 rtemslwip/zynq_picozed/xparameters_ps.h       | 72 +++++++++++++++
 rtemslwip/zynq_picozed/xtopology_g.c          | 40 ++++++++
 rtemslwip/zynqmp/xil_shims.c                  | 45 ---------
 19 files changed, 577 insertions(+), 45 deletions(-)
 create mode 100644 defs/bsps/arm/xilinx_zynq_base.json
 create mode 100644 defs/bsps/arm/xilinx_zynq_picozed.json
 create mode 100644 embeddedsw/lib/bsp/standalone/src/arm/cortexa9/xil_mmu.h
 create mode 100644 rtemslwip/xilinx/freertos.c
 create mode 100644 rtemslwip/xilinx/xscugic_hw.c
 create mode 100644 rtemslwip/zynq/common_lwipopts.h
 create mode 100644 rtemslwip/zynq/xil_shims.c
 create mode 100644 rtemslwip/zynq/xlwipconfig.h
 create mode 100644 rtemslwip/zynq_picozed/lwipbspopts.h
 create mode 100644 rtemslwip/zynq_picozed/netstart.c
 create mode 100644 rtemslwip/zynq_picozed/xemacps_g.c
 create mode 100644 rtemslwip/zynq_picozed/xparameters_ps.h
 create mode 100644 rtemslwip/zynq_picozed/xtopology_g.c
diff --git a/defs/bsps/aarch64/xilinx_zynqmp_base.json b/defs/bsps/aarch64/xilinx_zynqmp_base.json
index 600415d..f8f4c14 100644
--- a/defs/bsps/aarch64/xilinx_zynqmp_base.json
+++ b/defs/bsps/aarch64/xilinx_zynqmp_base.json
@@ -9,6 +9,8 @@
 		"embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit"
 	"source-files-to-import": [
+		"rtemslwip/xilinx/freertos.c",
+		"rtemslwip/xilinx/xscugic_hw.c",
 		"rtemslwip/zynqmp/xemacps_g.c",
 		"rtemslwip/zynqmp/xil_shims.c",
 		"rtemslwip/zynqmp/xtopology_g.c",
diff --git a/defs/bsps/arm/xilinx_zynq_base.json b/defs/bsps/arm/xilinx_zynq_base.json
new file mode 100644
index 0000000..aad0640
--- /dev/null
+++ b/defs/bsps/arm/xilinx_zynq_base.json
@@ -0,0 +1,28 @@
+	"header-paths-to-import": [
+		"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include",
+		"embeddedsw/lib/bsp/standalone/src/common",
+		"embeddedsw/XilinxProcessorIPLib/drivers/scugic/src",
+		"embeddedsw/XilinxProcessorIPLib/drivers/emacps/src",
+		"rtemslwip/xilinx",
+		"rtemslwip/zynq",
+		"embeddedsw/lib/bsp/standalone/src/arm/cortexa9",
+		"embeddedsw/lib/bsp/standalone/src/arm/common"
+	"source-files-to-import": [
+		"rtemslwip/zynq/xil_shims.c",
+		"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c",
+		"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xpqueue.c",
+		"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c",
+		"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c",
+		"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c",
+		"embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_physpeed.c",
+		"embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.c",
+		"embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.c",
+		"embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_control.c",
+		"embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_intr.c",
+		"embeddedsw/lib/bsp/standalone/src/common/xil_assert.c"
diff --git a/defs/bsps/arm/xilinx_zynq_picozed.json b/defs/bsps/arm/xilinx_zynq_picozed.json
index 0000000..feb4188
--- /dev/null
+++ b/defs/bsps/arm/xilinx_zynq_picozed.json
@@ -0,0 +1,13 @@
+	"includes": [
+		"xilinx_zynq_base"
+		"rtemslwip/zynq_picozed"
+		"rtemslwip/zynq_picozed/xemacps_g.c",
+		"rtemslwip/zynq_picozed/xtopology_g.c",
+		"rtemslwip/zynq_picozed/netstart.c"
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h
index 4d32b7f..aa491b7 100644
--- a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h
@@ -53,7 +53,11 @@ struct xemac_s {
 #if !NO_SYS
     sys_sem_t sem_rx_data_available;
 #if defined(__arm__) && !defined(ARMR5)
+#ifndef __rtems__
 	TimerHandle_t xTimer;
+#else /* __rtems__ */
+	rtems_id xTimer;
+#endif
 #endif
 #endif
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c
index 5328e86..3e36771 100644
--- a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c
@@ -329,11 +329,19 @@ s32_t xemacpsif_input(struct netif *netif)
 #if !NO_SYS
+#ifndef __rtems__
 void vTimerCallback( TimerHandle_t pxTimer )
 	/* Do something if the pxTimer parameter is NULL */
 	configASSERT(pxTimer);
+static rtems_timer_service_routine vTimerCallback(
+  rtems_id  timer,
+  void     *arg
+#endif
 	lExpireCounter++;
 	/* If the timer has expired 100 times then reset RX */
 	if(lExpireCounter >= RESETRXTIMEOUT) {
@@ -434,6 +442,7 @@ static err_t low_level_init(struct netif *netif)
 											XEMACPS_DMACR_OFFSET, dmacrreg);
 #if !NO_SYS
+#ifndef __rtems__
 	/* Freertos tick is 10ms by default; set period to the same */
 	xemac->xTimer = xTimerCreate("Timer", 10, pdTRUE, ( void * ) 1, vTimerCallback);
 	if (xemac->xTimer == NULL) {
@@ -443,6 +452,15 @@ static err_t low_level_init(struct netif *netif)
 			xil_printf("In %s:Timer start failed....\r\n", __func__);
+    rtems_status_code ret = rtems_timer_create( rtems_build_name( 'L', 'W', 'M', 'R' ), &xemac->xTimer);
+    if(RTEMS_SUCCESSFUL == ret){
+        ret = rtems_timer_fire_after(xemac->xTimer, rtems_clock_get_ticks_per_second()/100, vTimerCallback, NULL);
+    if(RTEMS_SUCCESSFUL != ret){
+        xil_printf("In %s:Timer setup failed....\r\n", __func__);
+#endif
 #endif
 #endif
 	setup_isr(xemac);
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
index 1d2439a..c222835 100644
--- a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
@@ -114,7 +114,15 @@ volatile u32_t notifyinfo[4*XLWIP_CONFIG_N_TX_DESC];
 #if defined __aarch64__
 u8_t bd_space[0x200000] __attribute__ ((aligned (0x200000)));
 #else
+#ifndef __rtems__
 u8_t bd_space[0x100000] __attribute__ ((aligned (0x100000)));
+#if defined(__arm__) && !defined(ARMR5)
+u8_t bd_space[0x100000] __attribute__ ((section(".bsp_nocache"), aligned (0x100000)));
+#else
+u8_t bd_space[0x100000] __attribute__ ((aligned (0x100000)));
+#endif
+#endif
 #endif
 static volatile u32_t bd_space_index = 0;
 static volatile u32_t bd_space_attr_set = 0;
@@ -676,7 +684,13 @@ XStatus init_dma(struct xemac_s *xemac)
 	Xil_SetTlbAttributes((u64)bd_space, NORM_NONCACHE | INNER_SHAREABLE);
 #else
+#ifndef __rtems__
 	Xil_SetTlbAttributes((s32_t)bd_space, DEVICE_MEMORY); // addr, attr
+#if !defined(__arm__)
+	Xil_SetTlbAttributes((s32_t)bd_space, DEVICE_MEMORY); // addr, attr
+#endif
+#endif
 #endif
 #endif
 		bd_space_attr_set = 1;
diff --git a/embeddedsw/lib/bsp/standalone/src/arm/cortexa9/xil_mmu.h b/embeddedsw/lib/bsp/standalone/src/arm/cortexa9/xil_mmu.h
index 0000000..d21e13a
--- /dev/null
+++ b/embeddedsw/lib/bsp/standalone/src/arm/cortexa9/xil_mmu.h
@@ -0,0 +1,92 @@
+* Copyright (c) 2012 - 2021 Xilinx, Inc.  All rights reserved.
+* SPDX-License-Identifier: MIT
+* @file xil_mmu.h
+* @addtogroup a9_mmu_apis Cortex A9 Processor MMU Functions
+* MMU functions equip users to enable MMU, disable MMU and modify default
+* memory attributes of MMU table as per the need.
+* <pre>
+* MODIFICATION HISTORY:
+* Ver   Who  Date     Changes
+* 1.00a sdm  01/12/12 Initial version
+* 4.2	pkp	 07/21/14 Included xil_types.h file which contains definition for
+*					  u32 which resolves issue of CR#805869
+* 5.4	pkp	 23/11/15 Added attribute definitions for Xil_SetTlbAttributes API
+* 6.8   aru  09/06/18 Removed compilation warnings for ARMCC toolchain.
+* </pre>
+*@cond nocomments
+#ifndef XIL_MMU_H
+#define XIL_MMU_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+/***************************** Include Files *********************************/
+#include "xil_types.h"
+/***************** Macros (Inline Functions) Definitions *********************/
+/**************************** Type Definitions *******************************/
+/************************** Constant Definitions *****************************/
+/* Memory type */
+#define NORM_NONCACHE 0x11DE2 	/* Normal Non-cacheable */
+#define STRONG_ORDERED 0xC02	/* Strongly ordered */
+#define DEVICE_MEMORY 0xC06		/* Device memory */
+#define RESERVED 0x0			/* reserved memory */
+/* Normal write-through cacheable shareable */
+#define NORM_WT_CACHE 0x16DEA
+/* Normal write back cacheable shareable */
+#define NORM_WB_CACHE 0x15DE6
+/* shareability attribute */
+#define SHAREABLE (0x1 << 16)
+#define NON_SHAREABLE	(~(0x1 << 16))
+/* Execution type */
+#define EXECUTE_NEVER ((0x1 << 4) | (0x1 << 0))
+*@endcond
+/************************** Variable Definitions *****************************/
+/************************** Function Prototypes ******************************/
+void Xil_SetTlbAttributes(INTPTR Addr, u32 attrib);
+void Xil_EnableMMU(void);
+void Xil_DisableMMU(void);
+void* Xil_MemMap(UINTPTR PhysAddr, size_t size, u32 flags);
+#ifdef __cplusplus
+#endif /* XIL_MMU_H */
+* @} End of "addtogroup a9_mmu_apis".
diff --git a/rtemslwip/xilinx/freertos.c b/rtemslwip/xilinx/freertos.c
index 0000000..90d1f83
--- /dev/null
+++ b/rtemslwip/xilinx/freertos.c
@@ -0,0 +1,64 @@
+ * Copyright (C) 2024 On-Line Applications Research Corporation (OAR)
+ * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
+ * are met:
+#include <rtems/rtems/intr.h>
+#include <rtems/score/threadimpl.h>
+#include <stdio.h>
+#include <string.h>
+#include "FreeRTOS.h"
+ * XInterruptHandler function pointer signature just happens to exactly match
+ * rtems_interrupt_handler
+BaseType_t xPortInstallInterruptHandler(
+  uint8_t           ucInterruptID,
+  XInterruptHandler pxHandler,
+  void             *pvCallBackRef
+  char name[10];
+  /* Is this running in the context of any interrupt server tasks? */
+  _Thread_Get_name( _Thread_Get_executing(), name, sizeof( name ) );
+  if (strcmp(name, "IRQS") == 0) {
+    /* Can't run this from within an IRQ Server thread context */
+    return RTEMS_ILLEGAL_ON_SELF;
+  rtems_status_code sc = rtems_interrupt_server_handler_install(
+    RTEMS_INTERRUPT_SERVER_DEFAULT,
+    ucInterruptID,
+    "CGEM Handler",
+    RTEMS_INTERRUPT_UNIQUE,
+    pxHandler,
+    pvCallBackRef
+  return sc;
diff --git a/rtemslwip/xilinx/xpseudo_asm.h b/rtemslwip/xilinx/xpseudo_asm.h
index cb51433..0168ce3 100644
--- a/rtemslwip/xilinx/xpseudo_asm.h
+++ b/rtemslwip/xilinx/xpseudo_asm.h
@@ -28,6 +28,11 @@
 #define XPSEUDO_ASM_H
 #include <rtems/score/cpu.h>
+#define dsb() _ARM_Data_synchronization_barrier()
+#define isb() _ARM_Instruction_synchronization_barrier()
+#else
 #define dsb() _AARCH64_Data_synchronization_barrier()
+#endif
 #endif
diff --git a/rtemslwip/xilinx/xscugic_hw.c b/rtemslwip/xilinx/xscugic_hw.c
index 0000000..9ba14a4
--- /dev/null
+++ b/rtemslwip/xilinx/xscugic_hw.c
@@ -0,0 +1,40 @@
+ * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
+ * are met:
+ #include <rtems/rtems/intr.h>
+/* Enable the interrupt */
+void XScuGic_EnableIntr ( u32 DistBaseAddress, u32 Int_Id )
+  rtems_interrupt_vector_enable( Int_Id );
+/* Disable the interrupt */
+void XScuGic_DisableIntr ( u32 DistBaseAddress, u32 Int_Id )
+  rtems_interrupt_vector_disable( Int_Id );
diff --git a/rtemslwip/zynq/common_lwipopts.h b/rtemslwip/zynq/common_lwipopts.h
index 0000000..8b7d870
--- /dev/null
+++ b/rtemslwip/zynq/common_lwipopts.h
@@ -0,0 +1,3 @@
+#include <xparameters_ps.h>
+#include <xlwipopts.h>
+#define MEM_ALIGNMENT 64
diff --git a/rtemslwip/zynq/xil_shims.c b/rtemslwip/zynq/xil_shims.c
index 0000000..50afcf8
--- /dev/null
+++ b/rtemslwip/zynq/xil_shims.c
@@ -0,0 +1,42 @@
+ * SPDX-License-Identifier: BSD-2-Clause
+ * Copyright (C) 2024 Bernd Moessner
+ * are met:
+#include "xil_mmu.h"
+#include <rtems/rtems/cache.h>
+#include <stdio.h>
+void Xil_DCacheInvalidateRange( INTPTR adr, INTPTR len )
+  rtems_cache_flush_multiple_data_lines( (const void *) adr, len );
+void Xil_DCacheFlushRange( INTPTR adr, INTPTR len )
+  Xil_DCacheInvalidateRange(adr, len );
diff --git a/rtemslwip/zynq/xlwipconfig.h b/rtemslwip/zynq/xlwipconfig.h
index 0000000..8144153
--- /dev/null
+++ b/rtemslwip/zynq/xlwipconfig.h
@@ -0,0 +1,38 @@
+ * are met:
+#ifndef __XLWIPCONFIG_H_
+#define __XLWIPCONFIG_H_
+#define XLWIP_CONFIG_INCLUDE_GEM 1
+#define XLWIP_CONFIG_EMAC_NUMBER 0
+#define XLWIP_CONFIG_N_TX_DESC 64
+#define XLWIP_CONFIG_N_RX_DESC 64
+#define XLWIP_CONFIG_N_TX_COALESCE 1
+#define XLWIP_CONFIG_N_RX_COALESCE 1
+#endif
diff --git a/rtemslwip/zynq_picozed/lwipbspopts.h b/rtemslwip/zynq_picozed/lwipbspopts.h
index 0000000..143e302
--- /dev/null
+++ b/rtemslwip/zynq_picozed/lwipbspopts.h
@@ -0,0 +1 @@
+#include <common_lwipopts.h>
diff --git a/rtemslwip/zynq_picozed/netstart.c b/rtemslwip/zynq_picozed/netstart.c
index 0000000..2f11979
--- /dev/null
+++ b/rtemslwip/zynq_picozed/netstart.c
@@ -0,0 +1,66 @@
+ * are met:
+#include <netstart.h>
+#include "netif/xadapter.h"
+#include "xparameters.h"
+#include <lwip/tcpip.h>
+int start_networking(
+  struct netif  *net_interface,
+  ip_addr_t     *ipaddr,
+  ip_addr_t     *netmask,
+  ip_addr_t     *gateway,
+  unsigned char *mac_ethernet_address
+  start_networking_shared();
+  if ( !xemac_add(
+    net_interface,
+    ipaddr,
+    netmask,
+    gateway,
+    mac_ethernet_address,
+    XPAR_PS7_ETHERNET_0_BASEADDR
+    return 1;
+  netif_set_default( net_interface );
+  netif_set_up( net_interface );
+  sys_thread_new(
+    "xemacif_input_thread",
+    ( void ( * )( void * ) )xemacif_input_thread,
+    net_interface,
+    1024,
+    DEFAULT_THREAD_PRIO
+  return 0;
diff --git a/rtemslwip/zynq_picozed/xemacps_g.c b/rtemslwip/zynq_picozed/xemacps_g.c
index 0000000..596bc49
--- /dev/null
+++ b/rtemslwip/zynq_picozed/xemacps_g.c
@@ -0,0 +1,35 @@
+* CAUTION: This file is automatically generated by HSI.
+* Version: 2021.2
+* DO NOT EDIT.
+* Copyright (C) 2010-2023 Xilinx, Inc. All Rights Reserved.
+* Description: Driver configuration
+#include "xparameters_ps.h"
+#include "xemacps.h"
+* The configuration table for devices
+XEmacPs_Config XEmacPs_ConfigTable[XPAR_XEMACPS_NUM_INSTANCES] =
+		XPAR_PS7_ETHERNET_0_DEVICE_ID,
+		XPAR_PS7_ETHERNET_0_BASEADDR,
+		XPAR_PS7_ETHERNET_0_IS_CACHE_COHERENT,
+		XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0,
+		XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV1,
+		XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV0,
+		XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV1,
+		XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV0,
+		XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV1
diff --git a/rtemslwip/zynq_picozed/xparameters_ps.h b/rtemslwip/zynq_picozed/xparameters_ps.h
index 0000000..d88a3fe
--- /dev/null
+++ b/rtemslwip/zynq_picozed/xparameters_ps.h
@@ -0,0 +1,72 @@
+ * are met:
+#ifndef _XPARAMETERS_PS_H_
+#define _XPARAMETERS_PS_H_
+#ifdef __cplusplus
+extern "C" {
+#endif
+#define XPAR_SCUGIC_0_DIST_BASEADDR 0xF8F01000U
+#define XPS_SYS_CTRL_BASEADDR		0xF8000000U
+#define XPAR_XEMACPS_NUM_INSTANCES 1
+#define XPAR_PS7_ETHERNET_0_DEVICE_ID 0
+#define XPAR_PS7_ETHERNET_0_BASEADDR 0xE000B000
+#define XPAR_PS7_ETHERNET_0_HIGHADDR 0xE000BFFF
+#define XPAR_PS7_ETHERNET_0_ENET_CLK_FREQ_HZ 125000000
+#define XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0 8
+#define XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV1 1
+#define XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV0 8
+#define XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV1 5
+#define XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV0 8
+#define XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV1 50
+#define XPAR_PS7_ETHERNET_0_ENET_TSU_CLK_FREQ_HZ 0
+#define XPAR_PS7_ETHERNET_0_IS_CACHE_COHERENT 0
+#define XPAR_XEMACPS_0_IS_CACHE_COHERENT 0
+#define XPAR_XEMACPS_0_DEVICE_ID XPAR_PS7_ETHERNET_0_DEVICE_ID
+#define XPAR_XEMACPS_0_BASEADDR 0xE000B000
+#define XPAR_XEMACPS_0_HIGHADDR 0xE000BFFF
+#define XPAR_XEMACPS_0_ENET_CLK_FREQ_HZ 125000000
+#define XPAR_XEMACPS_0_ENET_SLCR_1000Mbps_DIV0 8
+#define XPAR_XEMACPS_0_ENET_SLCR_1000Mbps_DIV1 1
+#define XPAR_XEMACPS_0_ENET_SLCR_100Mbps_DIV0 8
+#define XPAR_XEMACPS_0_ENET_SLCR_100Mbps_DIV1 5
+#define XPAR_XEMACPS_0_ENET_SLCR_10Mbps_DIV0 8
+#define XPAR_XEMACPS_0_ENET_SLCR_10Mbps_DIV1 50
+#define XPAR_XEMACPS_0_ENET_TSU_CLK_FREQ_HZ 0
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/rtemslwip/zynq_picozed/xtopology_g.c b/rtemslwip/zynq_picozed/xtopology_g.c
index 0000000..bf0ee25
--- /dev/null
+++ b/rtemslwip/zynq_picozed/xtopology_g.c
@@ -0,0 +1,40 @@
+ * are met:
+#include "netif/xtopology.h"
+struct xtopology_t xtopology[] = {
+    0xE000B000,
+    xemac_type_emacps,
+    0x0,
+    0x0,
+    0xF8F00100,
+    0x36,
+int xtopology_n_emacs = 1;
diff --git a/rtemslwip/zynqmp/xil_shims.c b/rtemslwip/zynqmp/xil_shims.c
index 1b1b3cf..1b566b6 100644
--- a/rtemslwip/zynqmp/xil_shims.c
+++ b/rtemslwip/zynqmp/xil_shims.c
@@ -57,51 +57,6 @@ void Xil_SetTlbAttributes( UINTPTR Addr, u64 attrib )
-#include "FreeRTOS.h"
- * XInterruptHandler function pointer signature just happens to exactly match
- * rtems_interrupt_handler
-BaseType_t xPortInstallInterruptHandler(
-  uint8_t           ucInterruptID,
-  XInterruptHandler pxHandler,
-  void             *pvCallBackRef
-  char name[10];
-  /* Is this running in the context of any interrupt server tasks? */
-  _Thread_Get_name( _Thread_Get_executing(), name, sizeof( name ) );
-  if (strcmp(name, "IRQS") == 0) {
-    /* Can't run this from within an IRQ Server thread context */
-    return RTEMS_ILLEGAL_ON_SELF;
-  rtems_status_code sc = rtems_interrupt_server_handler_install(
-    RTEMS_INTERRUPT_SERVER_DEFAULT,
-    ucInterruptID,
-    "CGEM Handler",
-    RTEMS_INTERRUPT_UNIQUE,
-    pxHandler,
-    pvCallBackRef
-  return sc;
-/* Enable the interrupt */
-void XScuGic_EnableIntr ( u32 DistBaseAddress, u32 Int_Id )
-  rtems_interrupt_vector_enable( Int_Id );
-/* Disable the interrupt */
-void XScuGic_DisableIntr ( u32 DistBaseAddress, u32 Int_Id )
-  rtems_interrupt_vector_disable( Int_Id );
  * The Xilinx code was written such that it assumed there was no invalidate-only
  * functionality on A53 cores. This function must flush and invalidate because
2.34.1
