[PATCH rtems-lwip 1/1] Add ZYNQ 7000 support
Kinsey Moore kinsey.moore at oarcorp.com
Mon Jan 8 19:23:26 UTC 2024
A few comments inline below. For the most part, this looks good.
On Sat, Jan 6, 2024 at 9:15 AM <berndmoessner80 at gmail.com> wrote:
> From: Bernd Moessner <berndmoessner80 at gmail.com>
> This patch adds support for the Xilinx ZYNQ 7000 series. Please note that
> this patch also affects ZYNQ Ultrascale+ as I`ve moved some functions from
> zynqmp/xil_shims.c to xilinx/freertos.c and xilinx/xscugic.c to share them
> between both families.
>  defs/bsps/aarch64/xilinx_zynqmp_base.json     |  2 +
>  defs/bsps/arm/xilinx_zynq_base.json           | 28 ++++++
>  defs/bsps/arm/xilinx_zynq_picozed.json        | 13 +++
>  .../ports/xilinx/include/netif/xadapter.h     |  4 +
>  .../contrib/ports/xilinx/netif/xemacpsif.c    | 18 ++++
>  .../ports/xilinx/netif/xemacpsif_dma.c        | 14 +++
>  .../bsp/standalone/src/arm/cortexa9/xil_mmu.h | 92 +++++++++++++++++++
>  rtemslwip/xilinx/freertos.c                   | 64 +++++++++++++
>  rtemslwip/xilinx/xpseudo_asm.h                |  5 +
>  rtemslwip/xilinx/xscugic_hw.c                 | 40 ++++++++
>  rtemslwip/zynq/common_lwipopts.h              |  3 +
>  rtemslwip/zynq/xil_shims.c                    | 42 +++++++++
>  rtemslwip/zynq/xlwipconfig.h                  | 38 ++++++++
>  rtemslwip/zynq_picozed/lwipbspopts.h          |  1 +
>  rtemslwip/zynq_picozed/netstart.c             | 66 +++++++++++++
>  rtemslwip/zynq_picozed/xemacps_g.c            | 35 +++++++
>  rtemslwip/zynq_picozed/xparameters_ps.h       | 72 +++++++++++++++
>  rtemslwip/zynq_picozed/xtopology_g.c          | 40 ++++++++
>  rtemslwip/zynqmp/xil_shims.c                  | 45 ---------
>  19 files changed, 577 insertions(+), 45 deletions(-)
>  create mode 100644 defs/bsps/arm/xilinx_zynq_base.json
>  create mode 100644 defs/bsps/arm/xilinx_zynq_picozed.json
>  create mode 100644
> embeddedsw/lib/bsp/standalone/src/arm/cortexa9/xil_mmu.h
>  create mode 100644 rtemslwip/xilinx/freertos.c
>  create mode 100644 rtemslwip/xilinx/xscugic_hw.c
>  create mode 100644 rtemslwip/zynq/common_lwipopts.h
>  create mode 100644 rtemslwip/zynq/xil_shims.c
>  create mode 100644 rtemslwip/zynq/xlwipconfig.h
>  create mode 100644 rtemslwip/zynq_picozed/lwipbspopts.h
>  create mode 100644 rtemslwip/zynq_picozed/netstart.c
>  create mode 100644 rtemslwip/zynq_picozed/xemacps_g.c
>  create mode 100644 rtemslwip/zynq_picozed/xparameters_ps.h
>  create mode 100644 rtemslwip/zynq_picozed/xtopology_g.c
> diff --git a/defs/bsps/aarch64/xilinx_zynqmp_base.json
> b/defs/bsps/aarch64/xilinx_zynqmp_base.json
> index 600415d..f8f4c14 100644
> --- a/defs/bsps/aarch64/xilinx_zynqmp_base.json
> +++ b/defs/bsps/aarch64/xilinx_zynqmp_base.json
> @@ -9,6 +9,8 @@
>                 "embeddedsw/lib/bsp/standalone/src/arm/ARMv8/64bit"
>         "source-files-to-import": [
> +               "rtemslwip/xilinx/freertos.c",
> +               "rtemslwip/xilinx/xscugic_hw.c",
>                 "rtemslwip/zynqmp/xemacps_g.c",
>                 "rtemslwip/zynqmp/xil_shims.c",
>                 "rtemslwip/zynqmp/xtopology_g.c",
> diff --git a/defs/bsps/arm/xilinx_zynq_base.json
> b/defs/bsps/arm/xilinx_zynq_base.json
> new file mode 100644
> index 0000000..aad0640
> --- /dev/null
> +++ b/defs/bsps/arm/xilinx_zynq_base.json
> @@ -0,0 +1,28 @@
> +       "header-paths-to-import": [
>  "embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include",
> +               "embeddedsw/lib/bsp/standalone/src/common",
> +               "embeddedsw/XilinxProcessorIPLib/drivers/scugic/src",
> +               "embeddedsw/XilinxProcessorIPLib/drivers/emacps/src",
> +               "rtemslwip/xilinx",
> +               "rtemslwip/zynq",
> +               "embeddedsw/lib/bsp/standalone/src/arm/cortexa9",
> +               "embeddedsw/lib/bsp/standalone/src/arm/common"
> +       "source-files-to-import": [
> +               "rtemslwip/zynq/xil_shims.c",
>  "embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xadapter.c",
>  "embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xpqueue.c",
>  "embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c",
>  "embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c",
>  "embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_hw.c",
>  "embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_physpeed.c",
>  "embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_bdring.c",
>  "embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps.c",
>  "embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_control.c",
>  "embeddedsw/XilinxProcessorIPLib/drivers/emacps/src/xemacps_intr.c",
> +               "embeddedsw/lib/bsp/standalone/src/common/xil_assert.c"
> diff --git a/defs/bsps/arm/xilinx_zynq_picozed.json
> b/defs/bsps/arm/xilinx_zynq_picozed.json
> index 0000000..feb4188
> --- /dev/null
> +++ b/defs/bsps/arm/xilinx_zynq_picozed.json
> @@ -0,0 +1,13 @@
> +       "includes": [
> +               "xilinx_zynq_base"
> +               "rtemslwip/zynq_picozed"
> +               "rtemslwip/zynq_picozed/xemacps_g.c",
> +               "rtemslwip/zynq_picozed/xtopology_g.c",
> +               "rtemslwip/zynq_picozed/netstart.c"
> diff --git
> a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h
> b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/include/netif/xadapter.h
> index 4d32b7f..aa491b7 100644
> @@ -53,7 +53,11 @@ struct xemac_s {
>  #if !NO_SYS
>      sys_sem_t sem_rx_data_available;
>  #if defined(__arm__) && !defined(ARMR5)
> +#ifndef __rtems__
>         TimerHandle_t xTimer;
> +#else /* __rtems__ */
> +       rtems_id xTimer;
> +#endif
>  #endif
>  #endif
> diff --git
> a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c
> b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif.c
> index 5328e86..3e36771 100644
> @@ -329,11 +329,19 @@ s32_t xemacpsif_input(struct netif *netif)
>  #if !NO_SYS
> +#ifndef __rtems__
>  void vTimerCallback( TimerHandle_t pxTimer )
>         /* Do something if the pxTimer parameter is NULL */
>         configASSERT(pxTimer);
> +static rtems_timer_service_routine vTimerCallback(
> +  rtems_id  timer,
> +  void     *arg
> +#endif
I'm surprised you're not getting warnings for unused arguments for timer
and arg.
>         lExpireCounter++;
>         /* If the timer has expired 100 times then reset RX */
>         if(lExpireCounter >= RESETRXTIMEOUT) {
> @@ -434,6 +442,7 @@ static err_t low_level_init(struct netif *netif)
>               XEMACPS_DMACR_OFFSET, dmacrreg);
>  #if !NO_SYS
> +#ifndef __rtems__
>         /* Freertos tick is 10ms by default; set period to the same */
>         xemac->xTimer = xTimerCreate("Timer", 10, pdTRUE, ( void * ) 1,
> vTimerCallback);
>         if (xemac->xTimer == NULL) {
> @@ -443,6 +452,15 @@ static err_t low_level_init(struct netif *netif)
>                         xil_printf("In %s:Timer start failed....\r\n",
> __func__);
> +    rtems_status_code ret = rtems_timer_create( rtems_build_name( 'L',
> 'W', 'M', 'R' ), &xemac->xTimer);
> +    if(RTEMS_SUCCESSFUL == ret){
> +        ret = rtems_timer_fire_after(xemac->xTimer,
> rtems_clock_get_ticks_per_second()/100, vTimerCallback, NULL);
> +    if(RTEMS_SUCCESSFUL != ret){
> +        xil_printf("In %s:Timer setup failed....\r\n", __func__);
Indentation doesn't match surrounding code.
> +#endif
>  #endif
>  #endif
>         setup_isr(xemac);
> diff --git
> a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
> b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
> index 1d2439a..c222835 100644
> @@ -114,7 +114,15 @@ volatile u32_t notifyinfo[4*XLWIP_CONFIG_N_TX_DESC];
>  #if defined __aarch64__
>  u8_t bd_space[0x200000] __attribute__ ((aligned (0x200000)));
>  #else
> +#ifndef __rtems__
>  u8_t bd_space[0x100000] __attribute__ ((aligned (0x100000)));
> +#if defined(__arm__) && !defined(ARMR5)
> +u8_t bd_space[0x100000] __attribute__ ((section(".bsp_nocache"), aligned
> (0x100000)));
> +#else
> +u8_t bd_space[0x100000] __attribute__ ((aligned (0x100000)));
> +#endif
> +#endif
Is there a reason you chose to change this interface instead of defining
Xil_SetTlbAttributes to use
arm_cp15_start_set_translation_table_entries(bsp_translation_table_base,
...)? The struct passed as the second parameter only needs to exist for the
duration of the function call.
>  #endif
>  static volatile u32_t bd_space_index = 0;
>  static volatile u32_t bd_space_attr_set = 0;
> @@ -676,7 +684,13 @@ XStatus init_dma(struct xemac_s *xemac)
>         Xil_SetTlbAttributes((u64)bd_space, NORM_NONCACHE |
> INNER_SHAREABLE);
>  #else
> +#ifndef __rtems__
>         Xil_SetTlbAttributes((s32_t)bd_space, DEVICE_MEMORY); // addr, attr
> +#if !defined(__arm__)
> +       Xil_SetTlbAttributes((s32_t)bd_space, DEVICE_MEMORY); // addr, attr
> +#endif
> +#endif
>  #endif
>  #endif
>                 bd_space_attr_set = 1;
With the current configuration not using any of the identifiers defined
here, this file import (cortexa9/xil_mmu.h) would be better served by a
blank stub file. You'll need it if you define Xil_SetTlbAttributes, instead.
> diff --git a/embeddedsw/lib/bsp/standalone/src/arm/cortexa9/xil_mmu.h
> b/embeddedsw/lib/bsp/standalone/src/arm/cortexa9/xil_mmu.h
> index 0000000..d21e13a
> --- /dev/null
> +++ b/embeddedsw/lib/bsp/standalone/src/arm/cortexa9/xil_mmu.h
> @@ -0,0 +1,92 @@
> +* Copyright (c) 2012 - 2021 Xilinx, Inc.  All rights reserved.
> +* SPDX-License-Identifier: MIT
> +* @file xil_mmu.h
> +* @addtogroup a9_mmu_apis Cortex A9 Processor MMU Functions
> +* MMU functions equip users to enable MMU, disable MMU and modify default
> +* memory attributes of MMU table as per the need.
> +* <pre>
> +* MODIFICATION HISTORY:
> +* Ver   Who  Date     Changes
> +* 1.00a sdm  01/12/12 Initial version
> +* 4.2  pkp      07/21/14 Included xil_types.h file which contains
> definition for
> +*                                        u32 which resolves issue of
> CR#805869
> +* 5.4  pkp      23/11/15 Added attribute definitions for
> Xil_SetTlbAttributes API
> +* 6.8   aru  09/06/18 Removed compilation warnings for ARMCC toolchain.
> +* </pre>
> +*@cond nocomments
> +#ifndef XIL_MMU_H
> +#define XIL_MMU_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> +/***************************** Include Files
> +#include "xil_types.h"
> +/***************** Macros (Inline Functions) Definitions
> +/**************************** Type Definitions
> +/************************** Constant Definitions
> +/* Memory type */
> +#define NORM_NONCACHE 0x11DE2  /* Normal Non-cacheable */
> +#define STRONG_ORDERED 0xC02   /* Strongly ordered */
> +#define DEVICE_MEMORY 0xC06            /* Device memory */
> +#define RESERVED 0x0                   /* reserved memory */
> +/* Normal write-through cacheable shareable */
> +#define NORM_WT_CACHE 0x16DEA
> +/* Normal write back cacheable shareable */
> +#define NORM_WB_CACHE 0x15DE6
> +/* shareability attribute */
> +#define SHAREABLE (0x1 << 16)
> +#define NON_SHAREABLE  (~(0x1 << 16))
> +/* Execution type */
> +#define EXECUTE_NEVER ((0x1 << 4) | (0x1 << 0))
> +*@endcond
> +/************************** Variable Definitions
> +/************************** Function Prototypes
> +void Xil_SetTlbAttributes(INTPTR Addr, u32 attrib);
> +void Xil_EnableMMU(void);
> +void Xil_DisableMMU(void);
> +void* Xil_MemMap(UINTPTR PhysAddr, size_t size, u32 flags);
> +#ifdef __cplusplus
> +#endif /* XIL_MMU_H */
> +* @} End of "addtogroup a9_mmu_apis".
> diff --git a/rtemslwip/xilinx/freertos.c b/rtemslwip/xilinx/freertos.c
> index 0000000..90d1f83
> --- /dev/null
> +++ b/rtemslwip/xilinx/freertos.c
> @@ -0,0 +1,64 @@
> + * Copyright (C) 2024 On-Line Applications Research Corporation (OAR)
> + * Written by Kinsey Moore <kinsey.moore at oarcorp.com>
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
> "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
> THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
> PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS
> BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
> BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF
> THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#include <rtems/rtems/intr.h>
> +#include <rtems/score/threadimpl.h>
> +#include <stdio.h>
> +#include <string.h>
> +#include "FreeRTOS.h"
> + * XInterruptHandler function pointer signature just happens to exactly
> match
> + * rtems_interrupt_handler
> +BaseType_t xPortInstallInterruptHandler(
> +  uint8_t           ucInterruptID,
> +  XInterruptHandler pxHandler,
> +  void             *pvCallBackRef
> +  char name[10];
> +  /* Is this running in the context of any interrupt server tasks? */
> +  _Thread_Get_name( _Thread_Get_executing(), name, sizeof( name ) );
> +  if (strcmp(name, "IRQS") == 0) {
> +    /* Can't run this from within an IRQ Server thread context */
> +    return RTEMS_ILLEGAL_ON_SELF;
> +  rtems_status_code sc = rtems_interrupt_server_handler_install(
> +    RTEMS_INTERRUPT_SERVER_DEFAULT,
> +    ucInterruptID,
> +    "CGEM Handler",
> +    RTEMS_INTERRUPT_UNIQUE,
> +    pxHandler,
> +    pvCallBackRef
> +  return sc;
> diff --git a/rtemslwip/xilinx/xpseudo_asm.h
> b/rtemslwip/xilinx/xpseudo_asm.h
> index cb51433..0168ce3 100644
> --- a/rtemslwip/xilinx/xpseudo_asm.h
> +++ b/rtemslwip/xilinx/xpseudo_asm.h
> @@ -28,6 +28,11 @@
>  #define XPSEUDO_ASM_H
>  #include <rtems/score/cpu.h>
> +#define dsb() _ARM_Data_synchronization_barrier()
> +#define isb() _ARM_Instruction_synchronization_barrier()
> +#else
>  #define dsb() _AARCH64_Data_synchronization_barrier()
> +#endif
>  #endif
> diff --git a/rtemslwip/xilinx/xscugic_hw.c b/rtemslwip/xilinx/xscugic_hw.c
> index 0000000..9ba14a4
> --- /dev/null
> +++ b/rtemslwip/xilinx/xscugic_hw.c
> @@ -0,0 +1,40 @@
> + * Copyright (C) 2022 On-Line Applications Research Corporation (OAR)
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> + #include <rtems/rtems/intr.h>
> +/* Enable the interrupt */
> +void XScuGic_EnableIntr ( u32 DistBaseAddress, u32 Int_Id )
> +  rtems_interrupt_vector_enable( Int_Id );
> +/* Disable the interrupt */
> +void XScuGic_DisableIntr ( u32 DistBaseAddress, u32 Int_Id )
> +  rtems_interrupt_vector_disable( Int_Id );
> diff --git a/rtemslwip/zynq/common_lwipopts.h
> b/rtemslwip/zynq/common_lwipopts.h
> index 0000000..8b7d870
> --- /dev/null
> +++ b/rtemslwip/zynq/common_lwipopts.h
> @@ -0,0 +1,3 @@
> +#include <xparameters_ps.h>
> +#include <xlwipopts.h>
> +#define MEM_ALIGNMENT 64
> diff --git a/rtemslwip/zynq/xil_shims.c b/rtemslwip/zynq/xil_shims.c
> index 0000000..50afcf8
> --- /dev/null
> +++ b/rtemslwip/zynq/xil_shims.c
> @@ -0,0 +1,42 @@
> + * SPDX-License-Identifier: BSD-2-Clause
> + * Copyright (C) 2024 Bernd Moessner
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include "xil_mmu.h"
> +#include <rtems/rtems/cache.h>
> +#include <stdio.h>
> +void Xil_DCacheInvalidateRange( INTPTR adr, INTPTR len )
> +  rtems_cache_flush_multiple_data_lines( (const void *) adr, len );
> +void Xil_DCacheFlushRange( INTPTR adr, INTPTR len )
> +  Xil_DCacheInvalidateRange(adr, len );
> diff --git a/rtemslwip/zynq/xlwipconfig.h b/rtemslwip/zynq/xlwipconfig.h
> index 0000000..8144153
> --- /dev/null
> +++ b/rtemslwip/zynq/xlwipconfig.h
> @@ -0,0 +1,38 @@
You should replace the copyright information here.
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef __XLWIPCONFIG_H_
> +#define __XLWIPCONFIG_H_
> +#define XLWIP_CONFIG_INCLUDE_GEM 1
> +#define XLWIP_CONFIG_EMAC_NUMBER 0
> +#define XLWIP_CONFIG_N_TX_DESC 64
> +#define XLWIP_CONFIG_N_RX_DESC 64
> +#define XLWIP_CONFIG_N_TX_COALESCE 1
> +#define XLWIP_CONFIG_N_RX_COALESCE 1
> +#endif
> diff --git a/rtemslwip/zynq_picozed/lwipbspopts.h
> b/rtemslwip/zynq_picozed/lwipbspopts.h
> index 0000000..143e302
> --- /dev/null
> +++ b/rtemslwip/zynq_picozed/lwipbspopts.h
> @@ -0,0 +1 @@
> +#include <common_lwipopts.h>
> diff --git a/rtemslwip/zynq_picozed/netstart.c
> b/rtemslwip/zynq_picozed/netstart.c
> index 0000000..2f11979
> --- /dev/null
> +++ b/rtemslwip/zynq_picozed/netstart.c
> @@ -0,0 +1,66 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include <netstart.h>
> +#include "netif/xadapter.h"
> +#include "xparameters.h"
> +#include <lwip/tcpip.h>
> +int start_networking(
> +  struct netif  *net_interface,
> +  ip_addr_t     *ipaddr,
> +  ip_addr_t     *netmask,
> +  ip_addr_t     *gateway,
> +  unsigned char *mac_ethernet_address
> +  start_networking_shared();
> +  if ( !xemac_add(
> +    net_interface,
> +    ipaddr,
> +    netmask,
> +    gateway,
> +    mac_ethernet_address,
> +    XPAR_PS7_ETHERNET_0_BASEADDR
> +    return 1;
> +  netif_set_default( net_interface );
> +  netif_set_up( net_interface );
> +  sys_thread_new(
> +    "xemacif_input_thread",
> +    ( void ( * )( void * ) )xemacif_input_thread,
> +    net_interface,
> +    1024,
> +    DEFAULT_THREAD_PRIO
No changes currently required here, but fair warning that I have a patch
coming soon that will affect the ZynqMP netstart code. I've received
confirmation from Xilinx/AMD that the emacps driver was never meant to be
SMP-capable (and it really isn't). This thread creation will be locked to
core 0 with the IRQ server servicing thread. I'll update this code when I
update the ZynqMP code.
> +  return 0;
> diff --git a/rtemslwip/zynq_picozed/xemacps_g.c
> b/rtemslwip/zynq_picozed/xemacps_g.c
> index 0000000..596bc49
> --- /dev/null
> +++ b/rtemslwip/zynq_picozed/xemacps_g.c
> @@ -0,0 +1,35 @@
> +* CAUTION: This file is automatically generated by HSI.
> +* Version: 2021.2
> +* DO NOT EDIT.
> +* Copyright (C) 2010-2023 Xilinx, Inc. All Rights Reserved.
> +* Description: Driver configuration
> +#include "xparameters_ps.h"
> +#include "xemacps.h"
> +* The configuration table for devices
This should be made more generic and shared among Zynq hardware if possible
by adding the other ethernet interface.
> +XEmacPs_Config XEmacPs_ConfigTable[XPAR_XEMACPS_NUM_INSTANCES] =
> +               XPAR_PS7_ETHERNET_0_DEVICE_ID,
> +               XPAR_PS7_ETHERNET_0_BASEADDR,
> +               XPAR_PS7_ETHERNET_0_IS_CACHE_COHERENT,
> +               XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0,
> +               XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV1,
> +               XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV0,
> +               XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV1,
> +               XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV0,
> +               XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV1
> diff --git a/rtemslwip/zynq_picozed/xparameters_ps.h
> b/rtemslwip/zynq_picozed/xparameters_ps.h
> index 0000000..d88a3fe
> --- /dev/null
> +++ b/rtemslwip/zynq_picozed/xparameters_ps.h
> @@ -0,0 +1,72 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#ifndef _XPARAMETERS_PS_H_
> +#define _XPARAMETERS_PS_H_
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#define XPAR_SCUGIC_0_DIST_BASEADDR 0xF8F01000U
> +#define XPS_SYS_CTRL_BASEADDR          0xF8000000U
> +#define XPAR_XEMACPS_NUM_INSTANCES 1
> +#define XPAR_PS7_ETHERNET_0_DEVICE_ID 0
> +#define XPAR_PS7_ETHERNET_0_BASEADDR 0xE000B000
> +#define XPAR_PS7_ETHERNET_0_HIGHADDR 0xE000BFFF
> +#define XPAR_PS7_ETHERNET_0_ENET_CLK_FREQ_HZ 125000000
> +#define XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV0 8
> +#define XPAR_PS7_ETHERNET_0_ENET_SLCR_1000MBPS_DIV1 1
> +#define XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV0 8
> +#define XPAR_PS7_ETHERNET_0_ENET_SLCR_100MBPS_DIV1 5
> +#define XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV0 8
> +#define XPAR_PS7_ETHERNET_0_ENET_SLCR_10MBPS_DIV1 50
> +#define XPAR_PS7_ETHERNET_0_ENET_TSU_CLK_FREQ_HZ 0
> +#define XPAR_PS7_ETHERNET_0_IS_CACHE_COHERENT 0
> +#define XPAR_XEMACPS_0_IS_CACHE_COHERENT 0
> +#define XPAR_XEMACPS_0_DEVICE_ID XPAR_PS7_ETHERNET_0_DEVICE_ID
> +#define XPAR_XEMACPS_0_BASEADDR 0xE000B000
> +#define XPAR_XEMACPS_0_HIGHADDR 0xE000BFFF
> +#define XPAR_XEMACPS_0_ENET_CLK_FREQ_HZ 125000000
> +#define XPAR_XEMACPS_0_ENET_SLCR_1000Mbps_DIV0 8
> +#define XPAR_XEMACPS_0_ENET_SLCR_1000Mbps_DIV1 1
> +#define XPAR_XEMACPS_0_ENET_SLCR_100Mbps_DIV0 8
> +#define XPAR_XEMACPS_0_ENET_SLCR_100Mbps_DIV1 5
> +#define XPAR_XEMACPS_0_ENET_SLCR_10Mbps_DIV0 8
> +#define XPAR_XEMACPS_0_ENET_SLCR_10Mbps_DIV1 50
> +#define XPAR_XEMACPS_0_ENET_TSU_CLK_FREQ_HZ 0
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/rtemslwip/zynq_picozed/xtopology_g.c
> b/rtemslwip/zynq_picozed/xtopology_g.c
> index 0000000..bf0ee25
> --- /dev/null
> +++ b/rtemslwip/zynq_picozed/xtopology_g.c
> @@ -0,0 +1,40 @@
> + * are met:
> "AS IS"
> THE
> PURPOSE
> BE
> BUSINESS
> THE
> +#include "netif/xtopology.h"
> +struct xtopology_t xtopology[] = {
> +    0xE000B000,
> +    xemac_type_emacps,
> +    0x0,
> +    0x0,
> +    0xF8F00100,
> +    0x36,
> +int xtopology_n_emacs = 1;
> diff --git a/rtemslwip/zynqmp/xil_shims.c b/rtemslwip/zynqmp/xil_shims.c
> index 1b1b3cf..1b566b6 100644
> --- a/rtemslwip/zynqmp/xil_shims.c
> +++ b/rtemslwip/zynqmp/xil_shims.c
> @@ -57,51 +57,6 @@ void Xil_SetTlbAttributes( UINTPTR Addr, u64 attrib )
> -#include "FreeRTOS.h"
> - * XInterruptHandler function pointer signature just happens to exactly
> match
> - * rtems_interrupt_handler
> -BaseType_t xPortInstallInterruptHandler(
> -  uint8_t           ucInterruptID,
> -  XInterruptHandler pxHandler,
> -  void             *pvCallBackRef
> -  char name[10];
> -  /* Is this running in the context of any interrupt server tasks? */
> -  _Thread_Get_name( _Thread_Get_executing(), name, sizeof( name ) );
> -  if (strcmp(name, "IRQS") == 0) {
> -    /* Can't run this from within an IRQ Server thread context */
> -    return RTEMS_ILLEGAL_ON_SELF;
> -  rtems_status_code sc = rtems_interrupt_server_handler_install(
> -    RTEMS_INTERRUPT_SERVER_DEFAULT,
> -    ucInterruptID,
> -    "CGEM Handler",
> -    RTEMS_INTERRUPT_UNIQUE,
> -    pxHandler,
> -    pvCallBackRef
> -  return sc;
> -/* Enable the interrupt */
> -void XScuGic_EnableIntr ( u32 DistBaseAddress, u32 Int_Id )
> -  rtems_interrupt_vector_enable( Int_Id );
> -/* Disable the interrupt */
> -void XScuGic_DisableIntr ( u32 DistBaseAddress, u32 Int_Id )
> -  rtems_interrupt_vector_disable( Int_Id );
>   * The Xilinx code was written such that it assumed there was no
> invalidate-only
>   * functionality on A53 cores. This function must flush and invalidate
> because
> 2.34.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240108/8c2714dd/attachment-0001.htm>
