[PATCH rtems6 - v2 09/16] flashdev: Refactor macro name
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Sun Jan 7 18:18:43 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
The major change in this patch is that it refactors
RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE to become
RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE.
Apart from that this patch fixes comments and aligns function names.
There is no change in the behaviour of the code introduced by this
patch.
Updates #4981
 cpukit/dev/flash/flashdev.c                   | 26 +++++-----
 cpukit/include/dev/flash/flashdev.h           | 15 +++---
 cpukit/libmisc/shell/main_flashdev.c          | 47 +++++++++++--------
 testsuites/libtests/flashdev01/init.c         |  9 ++--
 .../libtests/flashdev01/test_flashdev.c       | 30 ++++++------
 5 files changed, 68 insertions(+), 59 deletions(-)
diff --git a/cpukit/dev/flash/flashdev.c b/cpukit/dev/flash/flashdev.c
index 37d42955eb..50915312a0 100644
--- a/cpukit/dev/flash/flashdev.c
+++ b/cpukit/dev/flash/flashdev.c
@@ -108,12 +108,12 @@ static uint32_t rtems_flashdev_ioctl_get_flash_type(
   void *arg
-static int rtems_flashdev_ioctl_get_pageinfo_offset(
+static int rtems_flashdev_ioctl_get_pageinfo_by_offset(
   rtems_flashdev *flash,
   void *arg
-static int rtems_flashdev_ioctl_get_pageinfo_index(
+static int rtems_flashdev_ioctl_get_pageinfo_by_index(
   void *arg
@@ -123,7 +123,7 @@ static int rtems_flashdev_ioctl_get_page_count(
   void *arg
-static int rtems_flashdev_ioctl_get_write_block_size(
+static int rtems_flashdev_ioctl_get_min_write_block_size(
   void *arg
@@ -378,16 +378,16 @@ static int rtems_flashdev_ioctl(
       err = rtems_flashdev_ioctl_get_flash_type( flash, arg );
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET:
-      err = rtems_flashdev_ioctl_get_pageinfo_offset( flash, arg );
+      err = rtems_flashdev_ioctl_get_pageinfo_by_offset( flash, arg );
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX:
-      err = rtems_flashdev_ioctl_get_pageinfo_index( flash, arg );
+      err = rtems_flashdev_ioctl_get_pageinfo_by_index( flash, arg );
       break;
     case RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT:
       err = rtems_flashdev_ioctl_get_page_count( flash, arg );
       break;
-    case RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE:
-      err = rtems_flashdev_ioctl_get_write_block_size( flash, arg );
+    case RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE:
+      err = rtems_flashdev_ioctl_get_min_write_block_size( flash, arg );
       break;
     default:
       err = EINVAL;
@@ -511,7 +511,7 @@ static int rtems_flashdev_do_init(
   flash->get_page_info_by_offset = NULL;
   flash->get_page_info_by_index = NULL;
   flash->get_page_count = NULL;
-  flash->get_write_block_size = NULL;
+  flash->get_min_write_block_size = NULL;
   flash->region_table = NULL;
   return 0;
@@ -802,7 +802,7 @@ static uint32_t rtems_flashdev_ioctl_get_flash_type(
   void *arg
@@ -823,7 +823,7 @@ static int rtems_flashdev_ioctl_get_pageinfo_offset(
-static int rtems_flashdev_ioctl_get_pageinfo_index( rtems_flashdev *flash,
+static int rtems_flashdev_ioctl_get_pageinfo_by_index( rtems_flashdev *flash,
                                                 void *arg )
   rtems_flashdev_ioctl_page_info *page_info;
@@ -854,7 +854,7 @@ static int rtems_flashdev_ioctl_get_page_count( rtems_flashdev *flash, void *arg
   void *arg
@@ -862,10 +862,10 @@ static int rtems_flashdev_ioctl_get_write_block_size(
   if ( arg == NULL ) {
     rtems_set_errno_and_return_minus_one( EINVAL );
-  if ( flash->get_write_block_size == NULL ) {
+  if ( flash->get_min_write_block_size == NULL ) {
     return 0;
   } else {
-    return ( *flash->get_write_block_size )( flash, ( (size_t *) arg ) );
+    return ( *flash->get_min_write_block_size )( flash, ( (size_t *) arg ) );
diff --git a/cpukit/include/dev/flash/flashdev.h b/cpukit/include/dev/flash/flashdev.h
index 51e0486148..6ce00c4ead 100644
--- a/cpukit/include/dev/flash/flashdev.h
+++ b/cpukit/include/dev/flash/flashdev.h
@@ -138,11 +138,11 @@ typedef struct rtems_flashdev rtems_flashdev;
 #define RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT 9
- * @brief Get the minimum write size supported by the driver.
+ * @brief Get the minimum write block size supported by the driver.
- * @param[out] count Integer containing the minimum write size.
+ * @param[out] count Integer containing the minimum write block size.
-#define RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE 10
+#define RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE 10
  * @brief The maximum number of region limited file descriptors
@@ -351,17 +351,18 @@ struct rtems_flashdev {
-   * @brief Call to device driver to return the minimum write size of the
+   * @brief Call to device driver to return the minimum write block size of the
    * flash device.
-   * @param[out] write_block_size The minimum write size of the flash device.
+   * @param[out] min_write_block_size The minimum write block size of the flash
+   * device.
    * @retval 0 Success.
    * @retval non-zero Failed.
-  int ( *get_write_block_size )(
+  int ( *get_min_write_block_size )(
     rtems_flashdev *flashdev,
-    size_t *write_block_size
+    size_t *min_write_block_size
diff --git a/cpukit/libmisc/shell/main_flashdev.c b/cpukit/libmisc/shell/main_flashdev.c
index 516c77ae27..8443d8f71d 100644
--- a/cpukit/libmisc/shell/main_flashdev.c
+++ b/cpukit/libmisc/shell/main_flashdev.c
@@ -37,10 +37,17 @@ static int flashdev_shell_write(char *dev_path, int argc, char *argv[]);
 static int flashdev_shell_erase(char *dev_path, int argc, char *argv[]);
 static int flashdev_shell_get_type(char *dev_path);
 static int flashdev_shell_get_jedec_id(char *dev_path);
-static int flashdev_shell_get_page_by_off(char *dev_path, int argc, char *argv[]);
-static int flashdev_shell_get_page_by_idx(char *dev_path, int argc, char *argv[]);
-static int flashdev_shell_get_pg_count(char *dev_path);
-static int flashdev_shell_get_wb_size(char *dev_path);
+static int flashdev_shell_get_page_by_off(
+  char *dev_path,
+  int argc, char *argv[]
+static int flashdev_shell_get_page_by_idx(
+  char *dev_path,
+  int argc,
+  char *argv[]
+static int flashdev_shell_get_page_count(char *dev_path);
+static int flashdev_shell_get_min_write_block_size(char *dev_path);
 static int flashdev_shell_ioctl_value(
   char *dev_path,
@@ -67,7 +74,7 @@ static const char rtems_flashdev_shell_usage [] =
   "   -o <address>          Print the page information of page at address\n"
   "   -i <index>            Print the page information of page at index\n"
   "   -p                    Print the number of pages\n"
-  "   -b                    Print the write block size\n"
+  "   -b                    Print the min. write block size\n"
   "   -h                    Print this help\n";
@@ -98,23 +105,23 @@ static int rtems_flashdev_shell_main( int argc, char *argv[] ) {
         /* Erase */
         return flashdev_shell_erase(dev_path, argc, &argv[i]);
       case ('t'):
-        /* Flash Type */
+        /* Get Flash Type */
         return flashdev_shell_get_type(dev_path);
       case ('d'):
-        /* JEDEC Id */
+        /* Get JEDEC Id */
         return flashdev_shell_get_jedec_id(dev_path);
       case ('o'):
-        /* Page info by offset */
+        /* Get page info by offset */
         return flashdev_shell_get_page_by_off(dev_path, argc, &argv[i]);
       case ('i'):
-        /* Page info by index */
+        /* Get page info by index */
         return flashdev_shell_get_page_by_idx(dev_path, argc, &argv[i]);
       case ('p'):
-        /* Page count */
-        return flashdev_shell_get_pg_count(dev_path);
+        /* Get page count */
+        return flashdev_shell_get_page_count(dev_path);
       case ('b'):
-        /* Write block size */
-        return flashdev_shell_get_wb_size(dev_path);
+        /* Get min. write block size */
+        return flashdev_shell_get_min_write_block_size(dev_path);
       case ('h'):
       default:
         /* Help */
@@ -458,7 +465,7 @@ static int flashdev_shell_get_page_by_idx(
-static int flashdev_shell_get_pg_count( char *dev_path )
+static int flashdev_shell_get_page_count( char *dev_path )
   uint32_t ret;
   int status;
@@ -480,24 +487,24 @@ static int flashdev_shell_get_pg_count( char *dev_path )
   return 0;
-static int flashdev_shell_get_wb_size( char *dev_path )
+static int flashdev_shell_get_min_write_block_size( char *dev_path )
   size_t ret;
   int status;
-  /* Get Write Block Size */
+  /* Get Min Write Block Size */
   status = flashdev_shell_ioctl_value(
     dev_path,
-    RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE,
+    RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE,
     &ret
-  /* Print Write Block Size */
+  /* Print Min Write Block Size */
   if (status) {
-    printf("Failed to get write block size\n");
+    printf("Failed to get min. write block size\n");
     return status;
   } else {
-    printf("Write block size: 0x%zx\n", ret);
+    printf("Min. write block size: 0x%zx\n", ret);
   return 0;
diff --git a/testsuites/libtests/flashdev01/init.c b/testsuites/libtests/flashdev01/init.c
index 48cb033c04..dead939212 100644
--- a/testsuites/libtests/flashdev01/init.c
+++ b/testsuites/libtests/flashdev01/init.c
@@ -39,7 +39,7 @@
 #define TEST_DATA_SIZE (PAGE_SIZE * PAGE_COUNT)
 #define PAGE_COUNT 16
 #define PAGE_SIZE 128
-#define WB_SIZE 1
+#define MIN_WRTIE_BLOCK_SIZE 1
 const char rtems_test_name[] = "FLASHDEV 1";
@@ -59,7 +59,7 @@ static void run_test(void) {
   uint32_t jedec;
   int page_count;
   int type;
-  size_t wb_size;
+  size_t min_write_block_size;
   const char flash_path[] = "/dev/flashdev0";
   /* Initalize the flash device driver and flashdev */
@@ -134,9 +134,10 @@ static void run_test(void) {
   rtems_test_assert(page_count == PAGE_COUNT);
   /* Test getting write block size */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_WRITE_BLOCK_SIZE, &wb_size);
+  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE,
+                  &min_write_block_size);
   rtems_test_assert(!status);
-  rtems_test_assert(wb_size == WB_SIZE);
+  rtems_test_assert(min_write_block_size == min_write_block_size);
   /* Test Regions */
   region.offset = 0x400;
diff --git a/testsuites/libtests/flashdev01/test_flashdev.c b/testsuites/libtests/flashdev01/test_flashdev.c
index 9e257863b1..6b147d0f64 100644
--- a/testsuites/libtests/flashdev01/test_flashdev.c
+++ b/testsuites/libtests/flashdev01/test_flashdev.c
@@ -33,7 +33,7 @@
-#define WB_SIZE 1
+#define MIN_WRITE_BLOCK_SIZE 1
 #define MAX_NUM_REGIONS 48
 #define BITALLOC_SIZE 32
 #define NUM_BITALLOC ((MAX_NUM_REGIONS + BITALLOC_SIZE - 1) / BITALLOC_SIZE)
@@ -49,7 +49,7 @@ typedef struct test_flashdev {
   rtems_flashdev_region regions[MAX_NUM_REGIONS];
 } test_flashdev;
-int test_flashdev_get_page_by_off(
+int test_flashdev_get_page_by_offset(
   off_t search_offset,
   off_t *page_offset,
@@ -68,9 +68,9 @@ int test_flashdev_get_page_count(
   int *page_count
-int test_flashdev_get_wb_size(
+int test_flashdev_get_min_write_block_size(
 uint32_t test_flashdev_get_jedec_id(
@@ -102,8 +102,8 @@ int test_flashdev_erase(
   size_t count
-/* Find page info by offset handler */
+/* Get page info by offset handler */
   off_t *page_offset,
@@ -115,7 +115,7 @@ int test_flashdev_get_page_by_off(
   return 0;
-/* Find page by index handler */
+/* Get page by index handler */
 int test_flashdev_get_page_by_index(
   off_t search_index,
@@ -128,7 +128,7 @@ int test_flashdev_get_page_by_index(
   return 0;
-/* Page count handler */
+/* Get page count handler */
   int *page_count
@@ -138,17 +138,17 @@ int test_flashdev_get_page_count(
   return 0;
-/* Write block size handler */
+/* Get min. write block size handler */
-  *write_block_size = WB_SIZE;
+  *min_write_block_size = MIN_WRITE_BLOCK_SIZE;
   return 0;
-/* JEDEC ID handler, this would normally require a READID
+/* Get JEDEC ID handler, this would normally require a READID
  * call to the physical flash device.
@@ -265,10 +265,10 @@ rtems_flashdev* test_flashdev_init(void)
   flash->erase = &test_flashdev_erase;
   flash->get_jedec_id = &test_flashdev_get_jedec_id;
   flash->get_flash_type = &test_flashdev_get_type;
-  flash->get_page_info_by_offset = &test_flashdev_get_page_by_off;
+  flash->get_page_info_by_offset = &test_flashdev_get_page_by_offset;
   flash->get_page_info_by_index = &test_flashdev_get_page_by_index;
   flash->get_page_count = &test_flashdev_get_page_count;
-  flash->get_write_block_size = &test_flashdev_get_wb_size;
+  flash->get_min_write_block_size = &test_flashdev_get_min_write_block_size;
   flash->region_table = ftable;
   return flash;
2.34.1
