[PATCH rtems6 - v2 10/16] flashdev: extend testsuite
berndmoessner80 at gmail.com berndmoessner80 at gmail.com
Sun Jan 7 18:18:44 UTC 2024
From: Bernd Moessner <berndmoessner80 at gmail.com>
Allow testsuite to set the min. write block size
Updates #4981
 testsuites/libtests/flashdev01/init.c         | 191 +++++++++++-------
 .../libtests/flashdev01/test_flashdev.c       |  13 +-
 .../libtests/flashdev01/test_flashdev.h       |   2 +-
 3 files changed, 133 insertions(+), 73 deletions(-)
diff --git a/testsuites/libtests/flashdev01/init.c b/testsuites/libtests/flashdev01/init.c
index dead939212..7745f43e36 100644
--- a/testsuites/libtests/flashdev01/init.c
+++ b/testsuites/libtests/flashdev01/init.c
@@ -42,6 +42,7 @@
 #define MIN_WRTIE_BLOCK_SIZE 1
 const char rtems_test_name[] = "FLASHDEV 1";
+const char test_string[] = "My test string!";
 static void run_test(void);
@@ -59,11 +60,116 @@ static void run_test(void) {
   uint32_t jedec;
   int page_count;
   int type;
-  size_t min_write_block_size;
+  size_t bytes_read;
+  size_t min_write_write_block_size_in[] = {1,8,16};
+  size_t min_write_write_block_size_out;
   const char flash_path[] = "/dev/flashdev0";
+  for ( int loop = 0; loop <= 2; loop++)
+    /* Initalize the flash device driver and flashdev */
+    flash = test_flashdev_init(min_write_write_block_size_in[loop]);
+    rtems_test_assert(flash != NULL);
+    /* Register the flashdev as a device */
+    status = rtems_flashdev_register(flash, flash_path);
+    rtems_test_assert(!status);
+    /* Open the flashdev */
+    file = fopen(flash_path, "r+");
+    rtems_test_assert(file != NULL);
+    /* Adjust the file buffering */
+    status = setvbuf(file, NULL, _IOFBF, min_write_write_block_size_in[loop]);
+    fd = fileno(file);
+    /* Read data from flash */
+    read_data = fgets(buff, TEST_DATA_SIZE, file);
+    rtems_test_assert(read_data != NULL);
+    /* Fseek to start of flash and read again */
+    status = fseek(file, 0x0, SEEK_SET);
+    bytes_read = fread(buff, 1, TEST_DATA_SIZE, file);
+    rtems_test_assert(bytes_read == TEST_DATA_SIZE);
+    /* Fseek to start of flash */
+    /* Write the test name to the flash */
+    status = fwrite(test_string, 1, sizeof(test_string), file);
+    rtems_test_assert(status == sizeof(test_string));
+    fgets(buff, TEST_DATA_SIZE, file);
+    rtems_test_assert(!strncmp(buff, test_string, sizeof(test_string)));
+    /* Test Erasing */
+    e_args.offset = 0x0;
+    e_args.size = PAGE_SIZE;
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_ERASE, &e_args);
+    fseek(file, 0x0, SEEK_SET);
+    rtems_test_assert(buff[0] == 0);
+    /* Test getting JEDEC ID */
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID, &jedec);
+    rtems_test_assert(jedec == 0x00ABCDEF);
+    /* Test getting flash type */
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_TYPE, &type);
+    rtems_test_assert(type == RTEMS_FLASHDEV_NOR);
+    /* Test getting page info from offset */
+    pg_info.location = PAGE_SIZE + PAGE_SIZE/2;
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET, &pg_info);
+    rtems_test_assert(pg_info.page_info.offset == PAGE_SIZE);
+    rtems_test_assert(pg_info.page_info.size == PAGE_SIZE);
+    /* Test getting page info from index */
+    pg_info.location = 2;
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX, &pg_info);
+    rtems_test_assert(pg_info.page_info.offset == 2*PAGE_SIZE);
+    /* Test getting page count */
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT, &page_count);
+    rtems_test_assert(page_count == PAGE_COUNT);
+    /* Test getting min write size */
+    status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE,
+                    &min_write_write_block_size_out);
+    rtems_test_assert(0 == memcmp(&min_write_write_block_size_out,
+                                  &min_write_write_block_size_in[loop],
+                                  sizeof(size_t)));
+    /* Close the file handle */
+    status = fclose(file);
+    /* Deregister path */
+    status = rtems_flashdev_deregister(flash_path);
+    test_flashdev_deinit(flash);
-  flash = test_flashdev_init();
+  flash = test_flashdev_init(min_write_write_block_size_in[1]);
@@ -72,72 +178,12 @@ static void run_test(void) {
-  rtems_test_assert(file != NULL);
-  fd = fileno(file);
-  /* Read data from flash */
-  read_data = fgets(buff, TEST_DATA_SIZE, file);
-  rtems_test_assert(read_data != NULL);
-  /* Fseek to start of flash */
-  status = fseek(file, 0x0, SEEK_SET);
-  rtems_test_assert(!status);
-  /* Write the test name to the flash */
-  status = fwrite(rtems_test_name, TEST_NAME_LENGTH, 1, file);
-  rtems_test_assert(status == 1);
-  /* Fseek to start of flash and read again */
-  fgets(buff, TEST_DATA_SIZE, file);
-  rtems_test_assert(!strncmp(buff, rtems_test_name, TEST_NAME_LENGTH));
-  /* Test Erasing */
-  e_args.offset = 0x0;
-  e_args.size = PAGE_SIZE;
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_ERASE, &e_args);
-  fseek(file, 0x0, SEEK_SET);
-  rtems_test_assert(buff[0] == 0);
-  /* Test getting JEDEC ID */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_JEDEC_ID, &jedec);
+  status = setvbuf(file, NULL, _IOFBF, min_write_write_block_size_in[1]);
-  rtems_test_assert(jedec == 0x00ABCDEF);
-  /* Test getting flash type */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_TYPE, &type);
-  rtems_test_assert(type == RTEMS_FLASHDEV_NOR);
-  /* Test getting page info from offset */
-  pg_info.location = PAGE_SIZE + PAGE_SIZE/2;
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_OFFSET, &pg_info);
-  rtems_test_assert(pg_info.page_info.offset == PAGE_SIZE);
-  rtems_test_assert(pg_info.page_info.size == PAGE_SIZE);
-  /* Test getting page info from index */
-  pg_info.location = 2;
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGEINFO_BY_INDEX, &pg_info);
-  rtems_test_assert(pg_info.page_info.offset == 2*PAGE_SIZE);
-  /* Test getting page count */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_PAGE_COUNT, &page_count);
-  rtems_test_assert(page_count == PAGE_COUNT);
-  /* Test getting write block size */
-  status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_GET_MIN_WRITE_BLOCK_SIZE,
-                  &min_write_block_size);
-  rtems_test_assert(min_write_block_size == min_write_block_size);
   /* Test Regions */
   region.offset = 0x400;
@@ -145,10 +191,16 @@ static void run_test(void) {
   status = ioctl(fd, RTEMS_FLASHDEV_IOCTL_SET_REGION, &region);
+  /* Test read within then region */
+  bytes_read = fread(buff, 1, 0x200, file);
+  rtems_test_assert(bytes_read == 0x200);
   /* Test read to larger then region */
   read_data = fgets(buff, 2048, file);
-  rtems_test_assert(read_data == NULL);
   /* Test fseek outside of region */
   status = fseek(file, 0x201, SEEK_SET);
@@ -156,11 +208,12 @@ static void run_test(void) {
   /* Write to base unset region and check the writes location */
-  fwrite("HELLO WORLD", 11, 1, file);
+  fwrite("HELLO WORLD!!!!!", 1, 16, file);
   ioctl(fd, RTEMS_FLASHDEV_IOCTL_UNSET_REGION, NULL);
   fseek(file, 0x400, SEEK_SET);
-  fgets(buff, 11, file);
-  rtems_test_assert(strncmp(buff, "HELLO WORLD", 11));
+  fgets(buff, 16, file);
+  rtems_test_assert(strncmp(buff, "HELLO WORLD!!!!!", 16));
diff --git a/testsuites/libtests/flashdev01/test_flashdev.c b/testsuites/libtests/flashdev01/test_flashdev.c
index 6b147d0f64..acc02e04f6 100644
--- a/testsuites/libtests/flashdev01/test_flashdev.c
+++ b/testsuites/libtests/flashdev01/test_flashdev.c
@@ -33,11 +33,12 @@
 #define TEST_DATA_SIZE (PAGE_SIZE * PAGE_COUNT)
 #define PAGE_COUNT 16
 #define PAGE_SIZE 128
-#define MIN_WRITE_BLOCK_SIZE 1
 #define MAX_NUM_REGIONS 48
 #define BITALLOC_SIZE 32
 #define NUM_BITALLOC ((MAX_NUM_REGIONS + BITALLOC_SIZE - 1) / BITALLOC_SIZE)
+size_t g_min_write_block_size = 0;
  * This flash device driver is for testing flashdev
  * API calls.
@@ -144,7 +145,7 @@ int test_flashdev_get_min_write_block_size(
   size_t *min_write_block_size
-  *min_write_block_size = MIN_WRITE_BLOCK_SIZE;
+  *min_write_block_size = g_min_write_block_size;
   return 0;
@@ -230,8 +231,14 @@ int test_flashdev_erase(
 /* Initialize Flashdev and underlying driver. */
-rtems_flashdev* test_flashdev_init(void)
+rtems_flashdev* test_flashdev_init(size_t min_write_block_size)
+  if (0 == min_write_block_size) {
+    return NULL;
+  g_min_write_block_size = min_write_block_size;
   rtems_flashdev *flash = rtems_flashdev_alloc_and_init(sizeof(rtems_flashdev));
   if (flash == NULL) {
diff --git a/testsuites/libtests/flashdev01/test_flashdev.h b/testsuites/libtests/flashdev01/test_flashdev.h
index 894c5d3747..568efcee34 100644
--- a/testsuites/libtests/flashdev01/test_flashdev.h
+++ b/testsuites/libtests/flashdev01/test_flashdev.h
@@ -30,7 +30,7 @@
 #include <dev/flash/flashdev.h>
-rtems_flashdev* test_flashdev_init(void);
+rtems_flashdev* test_flashdev_init(size_t min_write_block_size);
 void test_flashdev_deinit(rtems_flashdev* flash);
2.34.1
