Convert test executables to bootloader images?
Wed Jan 17 07:19:16 UTC 2024
Hello,
the RTEMS 6 build system only produces test executables in ELF format.
For example, if you want to run the tests using U-Boot, then you have to
convert the ELF file with the U-Boot mkimage tool to an U-Boot image
using BSP-specific command line arguments. For other bootloaders you
have to do other things.
In the old build system this was done by the bsp-post-link hooks:
define bsp-post-link
   $(OBJCOPY) -O binary '$@' '$(basename $@).bin'
   gzip -f -9 '$(basename $@).bin'
   mkimage -A ppc -O linux -T kernel -a 0x4000 -e 0x4000  -name
'$(notdir $@)' -d '$(basename $@).bin.gz' '$(basename $@).img'
   $(default-bsp-post-link)
endef
One approach would be to let the BSPs optionally provide a script
(configurable: shell, python, bat) to convert an ELF file to a
bootloader image. We could add a new waf target to do the conversion for
all test executables, for example:
./waf bootimages
It would invoke the BSP-provided script for all test executables.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
