Convert test executables to bootloader images?
Wed Jan 17 12:39:29 UTC 2024
Hello,
attached is a proof of concept. Using a ./waf bootimages command didn't
work since you don't have a build context in this case. I added a new
option:
# If this option is enabled, then boot images for the test programs
# are built.
BUILD_BOOT_IMAGES = False
If this option is enabled, then a BSP-specific method is used to build a
boot image. This method is optional. BSPs can provide it through a new
build item with type "mkimage", see the powerpc/qoriq example of the
attached patches.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240117/682f87ec/attachment.bin>
Type: text/x-patch
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240117/682f87ec/attachment-0001.bin>
