[PATCH rtems6 1/1] libmisc/shell: Fix timeout in getting terminal size
dufault at hda.com
dufault at hda.com
Fri Jan 19 12:18:39 UTC 2024
- Fix detection of timeout in rtems_shell_term_wait_for().
- Switch to using "termios" VTIME inter-character timeout.
The previous implementation is dependent on the BSP clock tick value.
Updates #4763
cpukit/libmisc/shell/shell.c | 101 ++++++++++++++++++++++++++-----------------
1 file changed, 62 insertions(+), 39 deletions(-)
diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
index 9cefc80..60cdb4f 100644
--- a/cpukit/libmisc/shell/shell.c
+++ b/cpukit/libmisc/shell/shell.c
@@ -805,28 +805,52 @@ void rtems_shell_print_env(
#endif
+/* Debugging output for the terminal I/O associated with window size detection
+ * can be sent with rtems_shell_winsize_db().
+/* Window size detection knobs.
+static bool rtems_shell_winsize_dbf; /* Debug. "true" to debug. */
+static int rtems_shell_winsize_vtime = 1; /* VTIME timeout in .1 seconds */
+static void rtems_shell_winsize_vdb(const char *format, va_list ap) {
+ if (rtems_shell_winsize_dbf == false)
+ return;
+ printf("shell_winsize: ");
+ vprintf(format, ap);
+ fflush(stdout);
+static void rtems_shell_winsize_db(const char *format, ...) {
+ va_list ap;
+ va_start(ap, format);
+ rtems_shell_winsize_vdb(format, ap);
+ va_end(ap);
* Wait for the string to return or timeout.
-static bool rtems_shell_term_wait_for(const int fd, const char* str, const int timeout)
+static bool rtems_shell_term_wait_for(const int fd, const char* str)
- int msec = timeout;
int i = 0;
- while (msec-- > 0 && str[i] != '\0') {
+ while (str[i] != '\0') {
char ch[2];
- if (read(fd, &ch[0], 1) == 1) {
- fflush(stdout);
+ ssize_t n;
+ if ((n = read(fd, &ch[0], 1)) == 1) {
if (ch[0] != str[i++]) {
+ rtems_shell_winsize_db("Wrong char at char %d.\n", i);
return false;
- msec = timeout;
} else {
- usleep(1000);
+ rtems_shell_winsize_db("%s reading char %d.\n",
+ (n == 0) ? "Timeout" : "Error", i);
+ return false;
- if (msec == 0) {
- return false;
+ rtems_shell_winsize_db("Matched string.\n");
return true;
@@ -836,41 +860,42 @@ static bool rtems_shell_term_wait_for(const int fd, const char* str, const int t
static int rtems_shell_term_buffer_until(const int fd,
char* buf,
const int size,
- const char* end,
- const int timeout)
+ const char* end)
int i = 0;
int e = 0;
memset(&buf[0], 0, size);
- while (msec-- > 0 && i < size && end[e] != '\0') {
+ while (i < size && end[e] != '\0') {
char ch[2];
- fflush(stdout);
+ ssize_t n;
+ if ( (n = read(fd, &ch[0], 1)) == 1) {
buf[i++] = ch[0];
if (ch[0] == end[e]) {
e++;
} else {
+ rtems_shell_winsize_db("Reset search for end string.\n");
e = 0;
- msec = timeout;
} else {
- usleep(1000);
+ /* Error or timeout. */
+ "%s looking for end string \"%s\". Read \"%s\".\n",
+ (n == 0) ? "Timeout" : "Error", end, buf
+ return -1;
- if (msec == 0 || end[e] != '\0') {
- return -1;
- i -= e;
+ i -= e; /* Toss away the matched end. */
if (i < size) {
buf[i] = '\0';
+ rtems_shell_winsize_db("Found end string \"%s\".\n", end);
return i;
- * Determine if the terminal has the row and column values
- * swapped
+ * Determine if this is a version of the "tmux" terminal emulator with
+ * the row and column values swapped
* https://github.com/tmux/tmux/issues/3457
@@ -878,19 +903,19 @@ static int rtems_shell_term_buffer_until(const int fd,
* in the time it takes to get the fix into code so see if tmux is
* running and which version and work around the bug.
- * The terminal device needs to have VMIN=0, and VTIME=0
+ * The terminal device needs to have VMIN=0, and VTIME set to the
+ * desired timeout in .1 seconds.
-static bool rtems_shell_term_row_column_swapped(const int fd, const int timeout) {
+static bool rtems_shell_term_row_column_swapped(const int fd, const int fout) {
char buf[64];
memset(&buf[0], 0, sizeof(buf));
* CSI > Ps q
* Ps = 0 => DCS > | text ST
- fputs("\033[>0q", stdout);
- fflush(stdout);
- if (rtems_shell_term_wait_for(fd, "\033P>|", timeout)) {
- int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\", timeout);
+ write(fout, "\033[>0q", 5);
+ if (rtems_shell_term_wait_for(fd, "\033P>|")) {
+ int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\");
if (len > 0) {
if (memcmp(buf, "tmux ", 5) == 0) {
static const char* bad_versions[] = {
@@ -916,8 +941,8 @@ static bool rtems_shell_term_row_column_swapped(const int fd, const int timeout)
static void rtems_shell_winsize( void )
const int fd = fileno(stdin);
+ const int fout = fileno(stdout);
struct winsize ws;
- const int timeout = 150;
char buf[64];
bool ok = false;
int lines = 0;
@@ -933,18 +958,16 @@ static void rtems_shell_winsize( void )
if (tcgetattr(fd, &cterm) >= 0) {
struct termios term = cterm;
term.c_cc[VMIN] = 0;
- term.c_cc[VTIME] = 0;
- if (tcsetattr (fd, TCSADRAIN, &term) >= 0) {
+ term.c_cc[VTIME] = rtems_shell_winsize_vtime;
+ if (tcsetattr (fd, TCSAFLUSH, &term) >= 0) {
* https://invisible-island.net/xterm/ctlseqs/ctlseqs.html#h3-Miscellaneous
* CSI 1 8 t
- fputs("\033[18t", stdout);
- fflush(stdout);
- if (rtems_shell_term_wait_for(fd, "\033[8;", timeout)) {
- int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), ";", timeout);
+ if (write(fout, "\033[18t", 5) == 5 && rtems_shell_term_wait_for(fd, "\033[8;")) {
+ int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), ";");
if (len > 0) {
int i;
lines = 0;
@@ -953,7 +976,7 @@ static void rtems_shell_winsize( void )
lines *= 10;
lines += buf[i++] - '0';
- len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "t", timeout);
+ len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "t");
if (len > 0) {
cols = 0;
i = 0;
@@ -966,7 +989,7 @@ static void rtems_shell_winsize( void )
- if (rtems_shell_term_row_column_swapped(fd, timeout)) {
+ if (ok && rtems_shell_term_row_column_swapped(fd, fout)) {
int tmp = lines;
lines = cols;
cols = tmp;
1.8.3.1
