[PATCH rtems6 1/1] libmisc/shell: Fix timeout in getting terminal size
Mon Jan 22 17:16:05 UTC 2024
I have a couple minor notes below. More important, does this change
require updating documentation?
I know we have a somewhat aging shell-specific guide:
https://docs.rtems.org/branches/master/shell/index.html
On Fri, Jan 19, 2024 at 5:19 AM <dufault at hda.com> wrote:
> From: Peter Dufault <dufault at hda.com>
> - Fix detection of timeout in rtems_shell_term_wait_for().
> - Switch to using "termios" VTIME inter-character timeout.
>   The previous implementation is dependent on the BSP clock tick value.
> Updates #4763
>  cpukit/libmisc/shell/shell.c | 101 ++++++++++++++++++++++++++-----------------
>  1 file changed, 62 insertions(+), 39 deletions(-)
> diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
> index 9cefc80..60cdb4f 100644
> --- a/cpukit/libmisc/shell/shell.c
> +++ b/cpukit/libmisc/shell/shell.c
> @@ -805,28 +805,52 @@ void rtems_shell_print_env(
>  #endif
> +/* Debugging output for the terminal I/O associated with window size detection
> + * can be sent with rtems_shell_winsize_db().
> +/* Window size detection knobs.
> +static bool rtems_shell_winsize_dbf;        /* Debug.  "true" to debug. */
Is this necessary? How does the application set/test this?
> +static int rtems_shell_winsize_vtime = 1;  /* VTIME timeout in .1 seconds */
> +static void rtems_shell_winsize_vdb(const char *format, va_list ap) {
> +  if (rtems_shell_winsize_dbf == false)
> +    return;
> +  printf("shell_winsize: ");
> +  vprintf(format, ap);
> +  fflush(stdout);
> +static void rtems_shell_winsize_db(const char *format, ...) {
> +  va_list ap;
> +  va_start(ap, format);
> +  rtems_shell_winsize_vdb(format, ap);
> +  va_end(ap);
>   * Wait for the string to return or timeout.
> -static bool rtems_shell_term_wait_for(const int fd, const char* str, const int timeout)
> +static bool rtems_shell_term_wait_for(const int fd, const char* str)
> -  int msec = timeout;
>    int i = 0;
> -  while (msec-- > 0 && str[i] != '\0') {
> +  while (str[i] != '\0') {
>      char ch[2];
> -    if (read(fd, &ch[0], 1) == 1) {
> -      fflush(stdout);
> +    ssize_t n;
> +    if ((n = read(fd, &ch[0], 1)) == 1) {
>        if (ch[0] != str[i++]) {
> +        rtems_shell_winsize_db("Wrong char at char %d.\n", i);
>          return false;
> -      msec = timeout;
>      } else {
> -      usleep(1000);
> +      rtems_shell_winsize_db("%s reading char %d.\n",
> +       (n == 0) ? "Timeout" : "Error", i);
I'd suggest putting the 'i' on it's own line here.  I don't know that
there's a specific style guide for this file, but having trailing
statements after the ternary is a bit harder to read. imo
> +      return false;
> -  if (msec == 0) {
> -    return false;
> +  rtems_shell_winsize_db("Matched string.\n");
>    return true;
> @@ -836,41 +860,42 @@ static bool rtems_shell_term_wait_for(const int fd, const char* str, const int t
>  static int rtems_shell_term_buffer_until(const int fd,
>                                           char* buf,
>                                           const int size,
> -                                         const char* end,
> -                                         const int timeout)
> +                                         const char* end)
>    int i = 0;
>    int e = 0;
>    memset(&buf[0], 0, size);
> -  while (msec-- > 0 && i < size && end[e] != '\0') {
> +  while (i < size && end[e] != '\0') {
>      char ch[2];
> -      fflush(stdout);
> +    ssize_t n;
> +    if ( (n = read(fd, &ch[0], 1)) == 1) {
>        buf[i++] = ch[0];
>        if (ch[0] == end[e]) {
>          e++;
>        } else {
> +        rtems_shell_winsize_db("Reset search for end string.\n");
>          e = 0;
> -      msec = timeout;
>      } else {
> -      usleep(1000);
> +      /* Error or timeout. */
> +         "%s looking for end string \"%s\". Read \"%s\".\n",
> +         (n == 0) ? "Timeout" : "Error", end, buf
> +      return -1;
> -  if (msec == 0 || end[e] != '\0') {
> -    return -1;
> -  i -= e;
> +  i -= e;   /* Toss away the matched end. */
>    if (i < size) {
>      buf[i] = '\0';
> +  rtems_shell_winsize_db("Found end string \"%s\".\n", end);
>    return i;
> - * Determine if the terminal has the row and column values
> - * swapped
> + * Determine if this is a version of the "tmux" terminal emulator with
> + * the row and column values swapped
>   * https://github.com/tmux/tmux/issues/3457
> @@ -878,19 +903,19 @@ static int rtems_shell_term_buffer_until(const int fd,
>   * in the time it takes to get the fix into code so see if tmux is
>   * running and which version and work around the bug.
> - * The terminal device needs to have VMIN=0, and VTIME=0
> + * The terminal device needs to have VMIN=0, and VTIME set to the
> + * desired timeout in .1 seconds.
> -static bool rtems_shell_term_row_column_swapped(const int fd, const int timeout) {
> +static bool rtems_shell_term_row_column_swapped(const int fd, const int fout) {
>    char buf[64];
>    memset(&buf[0], 0, sizeof(buf));
>     * CSI > Ps q
>     *    Ps = 0   =>   DCS > | text ST
> -  fputs("\033[>0q", stdout);
> -  fflush(stdout);
> -  if (rtems_shell_term_wait_for(fd, "\033P>|", timeout)) {
> -    int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\", timeout);
> +  write(fout, "\033[>0q", 5);
> +  if (rtems_shell_term_wait_for(fd, "\033P>|")) {
> +    int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\");
>      if (len > 0) {
>        if (memcmp(buf, "tmux ", 5) == 0) {
>          static const char* bad_versions[] = {
> @@ -916,8 +941,8 @@ static bool rtems_shell_term_row_column_swapped(const int fd, const int timeout)
>  static void rtems_shell_winsize( void )
>    const int fd = fileno(stdin);
> +  const int fout = fileno(stdout);
>    struct winsize ws;
> -  const int timeout = 150;
>    char buf[64];
>    bool ok = false;
>    int lines = 0;
> @@ -933,18 +958,16 @@ static void rtems_shell_winsize( void )
>      if (tcgetattr(fd, &cterm) >= 0) {
>        struct termios term = cterm;
>        term.c_cc[VMIN] = 0;
> -      term.c_cc[VTIME] = 0;
> -      if (tcsetattr (fd, TCSADRAIN, &term) >= 0) {
> +      term.c_cc[VTIME] = rtems_shell_winsize_vtime;
> +      if (tcsetattr (fd, TCSAFLUSH, &term) >= 0) {
>           * https://invisible-island.net/xterm/ctlseqs/ctlseqs.html#h3-Miscellaneous
>           * CSI 1 8 t
> -        fputs("\033[18t", stdout);
> -        fflush(stdout);
> -        if (rtems_shell_term_wait_for(fd, "\033[8;", timeout)) {
> -          int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), ";", timeout);
> +        if (write(fout, "\033[18t", 5) == 5 && rtems_shell_term_wait_for(fd, "\033[8;")) {
> +          int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), ";");
>            if (len > 0) {
>              int i;
>              lines = 0;
> @@ -953,7 +976,7 @@ static void rtems_shell_winsize( void )
>                lines *= 10;
>                lines += buf[i++] - '0';
> -            len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "t", timeout);
> +            len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "t");
>              if (len > 0) {
>                cols = 0;
>                i = 0;
> @@ -966,7 +989,7 @@ static void rtems_shell_winsize( void )
> -      if (rtems_shell_term_row_column_swapped(fd, timeout)) {
> +      if (ok && rtems_shell_term_row_column_swapped(fd, fout)) {
>          int tmp = lines;
>          lines = cols;
>          cols = tmp;
> 1.8.3.1
> devel mailing list
> devel at rtems.org
