Latest toolchain throws error when including newlib's regex.h
Bernd Moessner berndmoessner80 at gmail.com
Fri Jan 19 20:31:55 UTC 2024
Dear all,
I'm currently encountering an issue with the latest RTEMS toolchain (GCC
13) while attempting to build GoogleTest.
Simple example, test.cpp with the following content:
#include <sys/types.h>
#include <regex.h>
compiled with
~/quick-start/install/tools/toolchain-arm/bin/arm-rtems6-g++ test.cpp
gives me:
In file included from test.cpp:2:
/home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:99:45:
error: expected primary-expression before '__restrict'
    99 |                         size_t, regmatch_t [__restrict], int);
error: expected ']' before '__restrict'
error: expected ')' before '__restrict'
/home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:98:16:
note: to match this '('
    98 | int     regexec(const regex_t *__restrict, const char *__restrict,
/home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:99:55:
error: expected initializer before ']' token
Is rejecting " [__restrict] " a bug in GCC, or should the signature of
newlib`s /newlib/libc/include/regex.h be changed from
to
             size_t, regmatch_t __restrict *, int);
? I would appreciate any insights or guidance you could provide on this
matter.
Regards
Bernd
