Latest toolchain throws error when including newlib's regex.h
Sat Jan 20 15:49:21 UTC 2024
On 19.01.24 21:31, Bernd Moessner wrote:
> Dear all,
> I'm currently encountering an issue with the latest RTEMS toolchain (GCC
> 13) while attempting to build GoogleTest.
> Simple example, test.cpp with the following content:
> #include <sys/types.h>
> #include <regex.h>
> compiled with
> ~/quick-start/install/tools/toolchain-arm/bin/arm-rtems6-g++ test.cpp
> gives me:
> In file included from test.cpp:2:
> /home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:99:45: error: expected primary-expression before '__restrict'
>     99 |                         size_t, regmatch_t [__restrict], int);
> /home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:99:45: error: expected ']' before '__restrict'
> /home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:99:45: error: expected ')' before '__restrict'
> /home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:98:16: note: to match this '('
>     98 | int     regexec(const regex_t *__restrict, const char *__restrict,
> /home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:99:55: error: expected initializer before ']' token
> Is rejecting " [__restrict] " a bug in GCC, or should the signature of
> newlib`s /newlib/libc/include/regex.h be changed from
> to
>              size_t, regmatch_t __restrict *, int);
> ? I would appreciate any insights or guidance you could provide on this
> matter.
I would look at the pre-processed file (for example using
-save-temps=obj). Then I would send a patch fixing the issue to the
Newlib mailing list.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
