Fwd: [rtems-bsp-builder] 2024-01-20 06:26:20: Profile(s): everything
Sat Jan 20 18:04:16 UTC 2024
Looksike some of the rece t activities around the tms750 BSP have not been
fully accounted for.
Remember that if the set of BSPs has changed, the tiers definition files in
rtems-tools need to be updated
---------- Forwarded message ---------
From: OAR Tester for Ubuntu 22.04 <rtems-tester at oarcorp.com>
Date: Sat, Jan 20, 2024, 11:22 AM
Subject: [rtems-bsp-builder] 2024-01-20 06:26:20: Profile(s): everything
To: <build at rtems.org>
RTEMS Tools Project - RTEMS Kernel BSP Builder, 6.0.not_released
Host: #14~22.04.1-Ubuntu SMP PREEMPT_DYNAMIC Mon Nov 20 18:15:30 UTC 2
command: /home/tester/rtems-cron-6/tools/6/bin/rtems-bsp-builder\
         --rtems=/home/tester/rtems-cron-6/rtems --build-path=/home/tester\
         /rtems-cron-6/build --prefix=/home/tester/rtems-\
         cron-6/tools/6/bsps --log=/home/tester/rtems-cron-6/bsp-\
         builder.log --warnings-report=warnings.log --mail --use-gitconfig\
         --profiles=everything
Total Time            : 4:58:31.096177 for 1298 completed job(s)
Average BSP Build Time: 0:00:13.798995
Builds
 debug
 no-posix
 posix
 posix-debug
 posix-profiling
 profiling
 smp
 smp-debug
Failures Report
   1 debug arm/tms570ls3137_hdk_with_loader configure:
      configure: /home/tester/rtems-cron-6/rtems/waf configure\
      --prefix=/home/tester/rtems-cron-6/tools/6/bsps --top=/home/tester\
      /rtems-cron-6/rtems --rtems-config=config-arm-\
      tms570ls3137_hdk_with_loader-debug.ini
   2 no-posix arm/tms570ls3137_hdk_with_loader configure:
      tms570ls3137_hdk_with_loader-no-posix.ini
   3 posix arm/tms570ls3137_hdk_with_loader configure:
      tms570ls3137_hdk_with_loader-posix.ini
   4 posix-debug arm/tms570ls3137_hdk_with_loader configure:
      tms570ls3137_hdk_with_loader-posix-debug.ini
   5 posix-profiling arm/tms570ls3137_hdk_with_loader configure:
      tms570ls3137_hdk_with_loader-posix-profiling.ini
   6 profiling arm/tms570ls3137_hdk_with_loader configure:
      tms570ls3137_hdk_with_loader-profiling.ini
   7 smp arm/tms570ls3137_hdk_with_loader configure:
      tms570ls3137_hdk_with_loader-smp.ini
   8 smp-debug arm/tms570ls3137_hdk_with_loader configure:
      tms570ls3137_hdk_with_loader-smp-debug.ini
Warnings Report
 | By Architecture (total : 11489)                                     |
 | common : 15 warning(s)                                              |
 |   Shared :  534 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  342 |                |                 |
 | aarch64 : 0 warning(s)                                              |
 | arm : 57 warning(s)                                                 |
 |   Shared :  192 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit : 1116 |                |                 |
 | bfin : 32 warning(s)                                                |
 |   Shared :  138 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  234 | CPU Kit :  132 |                |                 |
 | i386 : 0 warning(s)                                                 |
 | lm32 : 14 warning(s)                                                |
 |   Shared :  156 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  114 |                |                 |
 | m68k : 33 warning(s)                                                |
 |   Shared :  936 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  594 |                |                 |
 | microblaze : 0 warning(s)                                           |
 | mips : 8 warning(s)                                                 |
 |   Shared :    0 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  102 |                |                 |
 | moxie : 2 warning(s)                                                |
 |   Shared :   12 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   32 |                |                 |
 | nios2 : 0 warning(s)                                                |
 | or1k : 1 warning(s)                                                 |
 |   Shared :    6 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | powerpc : 46 warning(s)                                             |
 |   Shared :  260 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   12 | CPU Kit :  310 |                |                 |
 | riscv : 0 warning(s)                                                |
 | sh : 162 warning(s)                                                 |
 |   Shared :   84 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  182 |                |                 |
 | sparc : 3 warning(s)                                                |
 |   LibCPU :    0 | CPU Kit :  126 |                |                 |
 | sparc64 : 2 warning(s)                                              |
 |   Shared :   36 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   16 |                |                 |
 | v850 : 1 warning(s)                                                 |
 |   Shared :   72 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :  120 |                |                 |
 | x86_64 : 1 warning(s)                                               |
 |   LibCPU :    0 | CPU Kit :   20 |                |                 |
 | By BSP (total : 11489)                                              |
 | common : 264 warning(s)                                             |
 |   Shared : 1584 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   96 | CPU Kit : 3170 |                |                 |
 | aarch64/a53_ilp32_qemu : 0 warning(s)                               |
 | aarch64/a53_lp64_qemu : 0 warning(s)                                |
 | aarch64/a72_ilp32_qemu : 0 warning(s)                               |
 | aarch64/a72_lp64_qemu : 0 warning(s)                                |
 | aarch64/xilinx_versal_aiedge : 0 warning(s)                         |
 | aarch64/xilinx_versal_qemu : 0 warning(s)                           |
 | aarch64/xilinx_versal_vck190 : 0 warning(s)                         |
 | aarch64/xilinx_zynqmp_ilp32_qemu : 0 warning(s)                     |
 | aarch64/xilinx_zynqmp_ilp32_zu3eg : 0 warning(s)                    |
 | aarch64/xilinx_zynqmp_lp64_qemu : 0 warning(s)                      |
 | aarch64/xilinx_zynqmp_lp64_zu3eg : 0 warning(s)                     |
 | arm/altcycv_devkit : 7 warning(s)                                   |
 | arm/atsamv : 6 warning(s)                                           |
 | arm/beagleboardorig : 0 warning(s)                                  |
 | arm/beagleboardxm : 0 warning(s)                                    |
 | arm/beagleboneblack : 0 warning(s)                                  |
 | arm/beaglebonewhite : 0 warning(s)                                  |
 | arm/csb336 : 0 warning(s)                                           |
 | arm/csb337 : 0 warning(s)                                           |
 | arm/csb637 : 0 warning(s)                                           |
 | arm/edb7312 : 0 warning(s)                                          |
 | arm/fvp_cortex_r52 : 0 warning(s)                                   |
 | arm/gumstix : 0 warning(s)                                          |
 | arm/imx7 : 2 warning(s)                                             |
 |   LibCPU :    0 | CPU Kit :   48 |                |                 |
 | arm/imxrt1052 : 1 warning(s)                                        |
 | arm/kit637_v6 : 0 warning(s)                                        |
 | arm/lm3s3749 : 0 warning(s)                                         |
 | arm/lm3s6965 : 0 warning(s)                                         |
 | arm/lm3s6965_qemu : 0 warning(s)                                    |
 | arm/lm4f120 : 0 warning(s)                                          |
 | arm/lpc1768_mbed : 0 warning(s)                                     |
 | arm/lpc1768_mbed_ahb_ram : 0 warning(s)                             |
 | arm/lpc1768_mbed_ahb_ram_eth : 0 warning(s)                         |
 | arm/lpc17xx_ea_ram : 0 warning(s)                                   |
 | arm/lpc17xx_ea_rom_int : 0 warning(s)                               |
 | arm/lpc17xx_plx800_ram : 0 warning(s)                               |
 | arm/lpc17xx_plx800_rom_int : 0 warning(s)                           |
 | arm/lpc2362 : 0 warning(s)                                          |
 | arm/lpc23xx_tli800 : 0 warning(s)                                   |
 | arm/lpc24xx_ea : 0 warning(s)                                       |
 | arm/lpc24xx_ncs_ram : 0 warning(s)                                  |
 | arm/lpc24xx_ncs_rom_ext : 0 warning(s)                              |
 | arm/lpc24xx_ncs_rom_int : 0 warning(s)                              |
 | arm/lpc24xx_plx800_ram : 0 warning(s)                               |
 | arm/lpc24xx_plx800_rom_int : 0 warning(s)                           |
 | arm/lpc32xx_mzx : 0 warning(s)                                      |
 | arm/lpc32xx_mzx_stage_1 : 0 warning(s)                              |
 | arm/lpc32xx_mzx_stage_2 : 0 warning(s)                              |
 | arm/lpc32xx_phycore : 0 warning(s)                                  |
 | arm/lpc40xx_ea_ram : 0 warning(s)                                   |
 | arm/lpc40xx_ea_rom_int : 0 warning(s)                               |
 | arm/nucleo-h743zi : 0 warning(s)                                    |
 | arm/raspberrypi : 0 warning(s)                                      |
 | arm/raspberrypi2 : 0 warning(s)                                     |
 | arm/realview_pbx_a9_qemu : 0 warning(s)                             |
 | arm/rtl22xx : 0 warning(s)                                          |
 | arm/rtl22xx_t : 0 warning(s)                                        |
 | arm/smdk2410 : 0 warning(s)                                         |
 | arm/stm32f105rc : 0 warning(s)                                      |
 | arm/stm32f4 : 2 warning(s)                                          |
 | arm/stm32h7 : 2 warning(s)                                          |
 | arm/stm32h747i-disco : 1 warning(s)                                 |
 | arm/stm32h747i-disco-m4 : 0 warning(s)                              |
 | arm/stm32h757i-eval : 1 warning(s)                                  |
 | arm/stm32h757i-eval-m4 : 0 warning(s)                               |
 | arm/stm32h7b3i-dk : 2 warning(s)                                    |
 | arm/tms570ls3137_hdk : 0 warning(s)                                 |
 | arm/tms570ls3137_hdk_intram : 0 warning(s)                          |
 | arm/tms570ls3137_hdk_sdram : 0 warning(s)                           |
 | arm/xen_virtual : 0 warning(s)                                      |
 | arm/xilinx_zynq_a9_qemu : 0 warning(s)                              |
 | arm/xilinx_zynq_zc702 : 0 warning(s)                                |
 | arm/xilinx_zynq_zc706 : 0 warning(s)                                |
 | arm/xilinx_zynq_zedboard : 0 warning(s)                             |
 | arm/xilinx_zynqmp_ultra96 : 1 warning(s)                            |
 |   LibCPU :    0 | CPU Kit :   14 |                |                 |
 | bfin/TLL6527M : 11 warning(s)                                       |
 |   Shared :   42 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  138 | CPU Kit :   44 |                |                 |
 | bfin/bf537Stamp : 0 warning(s)                                      |
 | bfin/eZKit533 : 0 warning(s)                                        |
 | i386/pc386 : 0 warning(s)                                           |
 | i386/pc486 : 0 warning(s)                                           |
 | i386/pc586 : 0 warning(s)                                           |
 | i386/pc586-sse : 0 warning(s)                                       |
 | i386/pc686 : 0 warning(s)                                           |
 | i386/pcp4 : 0 warning(s)                                            |
 | lm32/lm32_evr : 0 warning(s)                                        |
 | lm32/lm32_evr_gdbsim : 0 warning(s)                                 |
 | lm32/milkymist : 12 warning(s)                                      |
 |   Shared :   96 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   38 |                |                 |
 | m68k/COBRA5475 : 0 warning(s)                                       |
 | m68k/av5282 : 0 warning(s)                                          |
 | m68k/csb360 : 0 warning(s)                                          |
 | m68k/gen68340 : 0 warning(s)                                        |
 | m68k/gen68360 : 2 warning(s)                                        |
 |   Shared :   18 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   26 |                |                 |
 | m68k/gen68360_040 : 0 warning(s)                                    |
 | m68k/m5484FireEngine : 3 warning(s)                                 |
 |   Shared :   66 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :    0 | CPU Kit :   30 |                |                 |
 | m68k/mcf5206elite : 1 warning(s)                                    |
 |   Shared :   78 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | m68k/mcf52235 : 3 warning(s)                                        |
 | m68k/mcf5225x : 3 warning(s)                                        |
 | m68k/mcf5235 : 1 warning(s)                                         |
 | m68k/mcf5329 : 3 warning(s)                                         |
 | m68k/mrm332 : 0 warning(s)                                          |
 | m68k/mvme147 : 0 warning(s)                                         |
 | m68k/mvme147s : 0 warning(s)                                        |
 | m68k/mvme162 : 0 warning(s)                                         |
 | m68k/mvme162lx : 0 warning(s)                                       |
 | m68k/mvme167 : 0 warning(s)                                         |
 | m68k/pgh360 : 0 warning(s)                                          |
 | m68k/uC5282 : 6 warning(s)                                          |
 | microblaze/kcu105 : 0 warning(s)                                    |
 | microblaze/kcu105_qemu : 0 warning(s)                               |
 | mips/csb350 : 0 warning(s)                                          |
 | mips/hurricane : 1 warning(s)                                       |
 | mips/jmr3904 : 0 warning(s)                                         |
 | mips/malta : 6 warning(s)                                           |
 | mips/rbtx4925 : 0 warning(s)                                        |
 | mips/rbtx4938 : 1 warning(s)                                        |
 | moxie/moxiesim : 2 warning(s)                                       |
 | nios2/nios2_iss : 0 warning(s)                                      |
 | or1k/generic_or1k : 1 warning(s)                                    |
 | powerpc/beatnik : 2 warning(s)                                      |
 |   LibCPU :   12 | CPU Kit :    6 |                |                 |
 | powerpc/br_uid : 0 warning(s)                                       |
 | powerpc/gwlcfm : 0 warning(s)                                       |
 | powerpc/hsc_cm01 : 0 warning(s)                                     |
 | powerpc/icecube : 0 warning(s)                                      |
 | powerpc/mcp750 : 0 warning(s)                                       |
 | powerpc/mpc5566evb : 0 warning(s)                                   |
 | powerpc/mpc5643l_evb : 0 warning(s)                                 |
 | powerpc/mpc5668g : 0 warning(s)                                     |
 | powerpc/mpc5674fevb : 0 warning(s)                                  |
 | powerpc/mpc8260ads : 0 warning(s)                                   |
 | powerpc/mpc8309som : 0 warning(s)                                   |
 | powerpc/mpc8313erdb : 0 warning(s)                                  |
 | powerpc/mpc8349eamds : 0 warning(s)                                 |
 | powerpc/mtx603e : 0 warning(s)                                      |
 | powerpc/mvme2100 : 0 warning(s)                                     |
 | powerpc/mvme2307 : 0 warning(s)                                     |
 | powerpc/mvme3100 : 1 warning(s)                                     |
 |   LibCPU :    0 | CPU Kit :    6 |                |                 |
 | powerpc/mvme5500 : 2 warning(s)                                     |
 | powerpc/pghplus : 0 warning(s)                                      |
 | powerpc/phycore_mpc5554 : 0 warning(s)                              |
 | powerpc/pm520_cr825 : 0 warning(s)                                  |
 | powerpc/pm520_ze30 : 0 warning(s)                                   |
 | powerpc/psim : 1 warning(s)                                         |
 | powerpc/qemuppc : 1 warning(s)                                      |
 | powerpc/qemuprep : 0 warning(s)                                     |
 | powerpc/qemuprep-altivec : 0 warning(s)                             |
 | powerpc/qoriq_core_0 : 0 warning(s)                                 |
 | powerpc/qoriq_core_1 : 0 warning(s)                                 |
 | powerpc/qoriq_e500 : 0 warning(s)                                   |
 | powerpc/qoriq_e6500_32 : 0 warning(s)                               |
 | powerpc/qoriq_e6500_64 : 14 warning(s)                              |
 |   Shared :  104 |     BSP :    0 | Network :    0 |    Tests :    0 |
 | powerpc/ss555 : 2 warning(s)                                        |
 | powerpc/t32mppc : 4 warning(s)                                      |
 | powerpc/tqm8xx_stk8xx : 0 warning(s)                                |
 | powerpc/virtex : 0 warning(s)                                       |
 | powerpc/virtex4 : 0 warning(s)                                      |
 | powerpc/virtex5 : 0 warning(s)                                      |
 | riscv/frdme310arty : 0 warning(s)                                   |
 | riscv/griscv : 0 warning(s)                                         |
 | riscv/grv32i : 0 warning(s)                                         |
 | riscv/grv32im : 0 warning(s)                                        |
 | riscv/grv32imac : 0 warning(s)                                      |
 | riscv/grv32imafdc : 0 warning(s)                                    |
 | riscv/mpfs64imafdc : 0 warning(s)                                   |
 | riscv/noel32im : 0 warning(s)                                       |
 | riscv/noel32imafd : 0 warning(s)                                    |
 | riscv/noel64imac : 0 warning(s)                                     |
 | riscv/noel64imafd : 0 warning(s)                                    |
 | riscv/noel64imafdc : 0 warning(s)                                   |
 | riscv/rv32i : 0 warning(s)                                          |
 | riscv/rv32iac : 0 warning(s)                                        |
 | riscv/rv32im : 0 warning(s)                                         |
 | riscv/rv32imac : 0 warning(s)                                       |
 | riscv/rv32imafc : 0 warning(s)                                      |
 | riscv/rv32imafd : 0 warning(s)                                      |
 | riscv/rv32imafdc : 0 warning(s)                                     |
 | riscv/rv64imac : 0 warning(s)                                       |
 | riscv/rv64imafd : 0 warning(s)                                      |
 | riscv/rv64imafdc : 0 warning(s)                                     |
 | sh/gensh1 : 1 warning(s)                                            |
 | sh/gensh2 : 1 warning(s)                                            |
 | sh/gensh4 : 1 warning(s)                                            |
 | sh/simsh1 : 0 warning(s)                                            |
 | sh/simsh2 : 0 warning(s)                                            |
 | sh/simsh2e : 0 warning(s)                                           |
 | sh/simsh4 : 0 warning(s)                                            |
 | sparc/at697f : 0 warning(s)                                         |
 | sparc/erc32 : 0 warning(s)                                          |
 | sparc/gr712rc : 0 warning(s)                                        |
 | sparc/gr740 : 0 warning(s)                                          |
 | sparc/leon2 : 0 warning(s)                                          |
 | sparc/leon3 : 0 warning(s)                                          |
 | sparc/ut699 : 0 warning(s)                                          |
 | sparc/ut700 : 0 warning(s)                                          |
 | sparc64/niagara : 0 warning(s)                                      |
 | sparc64/usiii : 1 warning(s)                                        |
 |   LibCPU :    0 | CPU Kit :    8 |                |                 |
 | v850/v850e1sim : 0 warning(s)                                       |
 | v850/v850e2sim : 0 warning(s)                                       |
 | v850/v850e2v3sim : 0 warning(s)                                     |
 | v850/v850esim : 0 warning(s)                                        |
 | v850/v850essim : 0 warning(s)                                       |
 | v850/v850sim : 0 warning(s)                                         |
 | x86_64/amd64 : 1 warning(s)                                         |
 | By Build (total : 11489)                                            |
 | common : 362 warning(s)                                             |
 |   Shared : 1549 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :  205 | CPU Kit : 3464 |                |                 |
 | debug : 15 warning(s)                                               |
 |   Shared :  301 |     BSP :    0 | Network :    0 |    Tests :    0 |
 |   LibCPU :   41 | CPU Kit :  352 |                |                 |
 | no-posix : 0 warning(s)                                             |
 | posix-debug : 0 warning(s)                                          |
 | posix-profiling : 0 warning(s)                                      |
 | smp : 0 warning(s)                                                  |
 | smp-debug : 0 warning(s)                                            |
build mailing list
build at rtems.org
http://lists.rtems.org/mailman/listinfo/build
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240120/08fa4c8a/attachment-0001.htm>
