Latest toolchain throws error when including newlib's regex.h
Bernd Moessner
berndmoessner80 at gmail.com
Sat Jan 20 17:31:28 UTC 2024
On 20.01.2024 16:49, Sebastian Huber wrote:
> On 19.01.24 21:31, Bernd Moessner wrote:
>> Dear all,
>> I'm currently encountering an issue with the latest RTEMS toolchain
>> (GCC 13) while attempting to build GoogleTest.
>> Simple example, test.cpp with the following content:
>> #include <sys/types.h>
>> #include <regex.h>
>> compiled with
>> ~/quick-start/install/tools/toolchain-arm/bin/arm-rtems6-g++ test.cpp
>> gives me:
>> In file included from test.cpp:2:
>> /home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:99:45:
>> error: expected primary-expression before '__restrict'
>> 99 | size_t, regmatch_t [__restrict], int);
>> error: expected ']' before '__restrict'
>> error: expected ')' before '__restrict'
>> /home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:98:16:
>> note: to match this '('
>> 98 | int regexec(const regex_t *__restrict, const char
>> *__restrict,
>> /home/blofeld/quick-start/install/tools/toolchain-arm/arm-rtems6/include/regex.h:99:55:
>> error: expected initializer before ']' token
>> Is rejecting " [__restrict] " a bug in GCC, or should the signature
>> of newlib`s /newlib/libc/include/regex.h be changed from
>> int regexec(const regex_t *__restrict, const char *__restrict,
>> to
>> size_t, regmatch_t __restrict *, int);
>> ? I would appreciate any insights or guidance you could provide on
>> this matter.
> I would look at the pre-processed file (for example using
> -save-temps=obj). Then I would send a patch fixing the issue to the
> Newlib mailing list.
Thank you!
I found a bug report https://gcc.gnu.org/bugzilla/show_bug.cgi?id=97477
regarding this issue. Wondering why I havent seen the error earlier.
Besides, it should be regmatch_t * __restrict.
Regards Bernd
