[PATCH rtems6 1/1] libmisc/shell: Fix timeout in getting terminal size
Peter Dufault dufault at hda.com
Mon Jan 22 18:51:56 UTC 2024
> On Jan 22, 2024, at 12:16 PM, Gedare Bloom <gedare at rtems.org> wrote:
> I have a couple minor notes below. More important, does this change
> require updating documentation?
I'd have to look to see if this window size detection is documented, I wanted to fix the problem it caused me.
> I know we have a somewhat aging shell-specific guide:
> https://docs.rtems.org/branches/master/shell/index.html
> On Fri, Jan 19, 2024 at 5:19 AM <dufault at hda.com> wrote:
>> From: Peter Dufault <dufault at hda.com>
>> - Fix detection of timeout in rtems_shell_term_wait_for().
>> - Switch to using "termios" VTIME inter-character timeout.
>>  The previous implementation is dependent on the BSP clock tick value.
>> Updates #4763
>> cpukit/libmisc/shell/shell.c | 101 ++++++++++++++++++++++++++-----------------
>> 1 file changed, 62 insertions(+), 39 deletions(-)
>> diff --git a/cpukit/libmisc/shell/shell.c b/cpukit/libmisc/shell/shell.c
>> index 9cefc80..60cdb4f 100644
>> --- a/cpukit/libmisc/shell/shell.c
>> +++ b/cpukit/libmisc/shell/shell.c
>> @@ -805,28 +805,52 @@ void rtems_shell_print_env(
>> #endif
>> +/* Debugging output for the terminal I/O associated with window size detection
>> + * can be sent with rtems_shell_winsize_db().
>> +/* Window size detection knobs.
>> +static bool rtems_shell_winsize_dbf;        /* Debug.  "true" to debug. */
> Is this necessary? How does the application set/test this?
I don't know.  Same with the "vtime" setting, no way to change that either. Rationale:
- It puts what you may want to change in one place.
- I'm not a fan of "#define".
- I didn't want to add a public interface to tweak things (then I *would* need to document).
- It was useful. I left it in to make it clear how to compile-time turn it on if you need it.
I can make the "dbf" behavior pre-processor enabled at compile-time.  Or take it out.
I would leave the "vtime" static, there was no way to change the previous timeout either.
>> +static int rtems_shell_winsize_vtime = 1;  /* VTIME timeout in .1 seconds */
>> +static void rtems_shell_winsize_vdb(const char *format, va_list ap) {
>> +  if (rtems_shell_winsize_dbf == false)
>> +    return;
>> +  printf("shell_winsize: ");
>> +  vprintf(format, ap);
>> +  fflush(stdout);
>> +static void rtems_shell_winsize_db(const char *format, ...) {
>> +  va_list ap;
>> +  va_start(ap, format);
>> +  rtems_shell_winsize_vdb(format, ap);
>> +  va_end(ap);
>>  * Wait for the string to return or timeout.
>> -static bool rtems_shell_term_wait_for(const int fd, const char* str, const int timeout)
>> +static bool rtems_shell_term_wait_for(const int fd, const char* str)
>> -  int msec = timeout;
>>   int i = 0;
>> -  while (msec-- > 0 && str[i] != '\0') {
>> +  while (str[i] != '\0') {
>>     char ch[2];
>> -    if (read(fd, &ch[0], 1) == 1) {
>> -      fflush(stdout);
>> +    ssize_t n;
>> +    if ((n = read(fd, &ch[0], 1)) == 1) {
>>       if (ch[0] != str[i++]) {
>> +        rtems_shell_winsize_db("Wrong char at char %d.\n", i);
>>         return false;
>> -      msec = timeout;
>>     } else {
>> -      usleep(1000);
>> +      rtems_shell_winsize_db("%s reading char %d.\n",
>> +       (n == 0) ? "Timeout" : "Error", i);
> I'd suggest putting the 'i' on it's own line here.  I don't know that
> there's a specific style guide for this file, but having trailing
> statements after the ternary is a bit harder to read. imo
Sure.
>> +      return false;
>> -  if (msec == 0) {
>> -    return false;
>> +  rtems_shell_winsize_db("Matched string.\n");
>>   return true;
>> @@ -836,41 +860,42 @@ static bool rtems_shell_term_wait_for(const int fd, const char* str, const int t
>> static int rtems_shell_term_buffer_until(const int fd,
>>                                          char* buf,
>>                                          const int size,
>> -                                         const char* end,
>> -                                         const int timeout)
>> +                                         const char* end)
>>   int i = 0;
>>   int e = 0;
>>   memset(&buf[0], 0, size);
>> -  while (msec-- > 0 && i < size && end[e] != '\0') {
>> +  while (i < size && end[e] != '\0') {
>>     char ch[2];
>> -      fflush(stdout);
>> +    ssize_t n;
>> +    if ( (n = read(fd, &ch[0], 1)) == 1) {
>>       buf[i++] = ch[0];
>>       if (ch[0] == end[e]) {
>>         e++;
>>       } else {
>> +        rtems_shell_winsize_db("Reset search for end string.\n");
>>         e = 0;
>> -      msec = timeout;
>>     } else {
>> -      usleep(1000);
>> +      /* Error or timeout. */
>> +         "%s looking for end string \"%s\". Read \"%s\".\n",
>> +         (n == 0) ? "Timeout" : "Error", end, buf
>> +      return -1;
>> -  if (msec == 0 || end[e] != '\0') {
>> -    return -1;
>> -  i -= e;
>> +  i -= e;   /* Toss away the matched end. */
>>   if (i < size) {
>>     buf[i] = '\0';
>> +  rtems_shell_winsize_db("Found end string \"%s\".\n", end);
>>   return i;
>> - * Determine if the terminal has the row and column values
>> - * swapped
>> + * Determine if this is a version of the "tmux" terminal emulator with
>> + * the row and column values swapped
>>  * https://github.com/tmux/tmux/issues/3457
>> @@ -878,19 +903,19 @@ static int rtems_shell_term_buffer_until(const int fd,
>>  * in the time it takes to get the fix into code so see if tmux is
>>  * running and which version and work around the bug.
>> - * The terminal device needs to have VMIN=0, and VTIME=0
>> + * The terminal device needs to have VMIN=0, and VTIME set to the
>> + * desired timeout in .1 seconds.
>> -static bool rtems_shell_term_row_column_swapped(const int fd, const int timeout) {
>> +static bool rtems_shell_term_row_column_swapped(const int fd, const int fout) {
>>   char buf[64];
>>   memset(&buf[0], 0, sizeof(buf));
>>    * CSI > Ps q
>>    *    Ps = 0   =>   DCS > | text ST
>> -  fputs("\033[>0q", stdout);
>> -  fflush(stdout);
>> -  if (rtems_shell_term_wait_for(fd, "\033P>|", timeout)) {
>> -    int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\", timeout);
>> +  write(fout, "\033[>0q", 5);
>> +  if (rtems_shell_term_wait_for(fd, "\033P>|")) {
>> +    int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\");
>>     if (len > 0) {
>>       if (memcmp(buf, "tmux ", 5) == 0) {
>>         static const char* bad_versions[] = {
>> @@ -916,8 +941,8 @@ static bool rtems_shell_term_row_column_swapped(const int fd, const int timeout)
>> static void rtems_shell_winsize( void )
>>   const int fd = fileno(stdin);
>> +  const int fout = fileno(stdout);
>>   struct winsize ws;
>> -  const int timeout = 150;
>>   char buf[64];
>>   bool ok = false;
>>   int lines = 0;
>> @@ -933,18 +958,16 @@ static void rtems_shell_winsize( void )
>>     if (tcgetattr(fd, &cterm) >= 0) {
>>       struct termios term = cterm;
>>       term.c_cc[VMIN] = 0;
>> -      term.c_cc[VTIME] = 0;
>> -      if (tcsetattr (fd, TCSADRAIN, &term) >= 0) {
>> +      term.c_cc[VTIME] = rtems_shell_winsize_vtime;
>> +      if (tcsetattr (fd, TCSAFLUSH, &term) >= 0) {
>>          * https://invisible-island.net/xterm/ctlseqs/ctlseqs.html#h3-Miscellaneous
>>          * CSI 1 8 t
>> -        fputs("\033[18t", stdout);
>> -        fflush(stdout);
>> -        if (rtems_shell_term_wait_for(fd, "\033[8;", timeout)) {
>> -          int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), ";", timeout);
>> +        if (write(fout, "\033[18t", 5) == 5 && rtems_shell_term_wait_for(fd, "\033[8;")) {
>> +          int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), ";");
>>           if (len > 0) {
>>             int i;
>>             lines = 0;
>> @@ -953,7 +976,7 @@ static void rtems_shell_winsize( void )
>>               lines *= 10;
>>               lines += buf[i++] - '0';
>> -            len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "t", timeout);
>> +            len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "t");
>>             if (len > 0) {
>>               cols = 0;
>>               i = 0;
>> @@ -966,7 +989,7 @@ static void rtems_shell_winsize( void )
>> -      if (rtems_shell_term_row_column_swapped(fd, timeout)) {
>> +      if (ok && rtems_shell_term_row_column_swapped(fd, fout)) {
>>         int tmp = lines;
>>         lines = cols;
>>         cols = tmp;
>> 1.8.3.1
>> devel mailing list
>> devel at rtems.org
Peter
Peter Dufault
HD Associates, Inc.      Software and System Engineering
