[PATCH rtems-libbsd 14/14] testsuite: Add a VME test
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jan 23 09:09:15 UTC 2024
Note: This test currently only works with a board with a Tsi148 like the
MVME2500. For other boards it will print only a message.
 libbsd.py                   |  2 +
 testsuite/vme01/test_main.c | 80 +++++++++++++++++++++++++++++++++++++
 2 files changed, 82 insertions(+)
 create mode 100644 testsuite/vme01/test_main.c
diff --git a/libbsd.py b/libbsd.py
index b05ea069..3fa2c8f3 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5631,6 +5631,8 @@ class tests(builder.Module):
         self.addTest(mm.generator['test']('openssl01', ['test_main']))
         self.addTest(mm.generator['test']('openssl02', ['test_main']))
         self.addTest(mm.generator['test']('tcpdump01', ['test_main']))
+        self.addTest(mm.generator['test']('vme01', ['test_main'],
+                                          runTest = False))
 def load(mm):
diff --git a/testsuite/vme01/test_main.c b/testsuite/vme01/test_main.c
new file mode 100644
index 00000000..fe6c1072
--- /dev/null
+++ b/testsuite/vme01/test_main.c
@@ -0,0 +1,80 @@
+ * @file
+ * @brief A test for VME interrupts.
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
+ * are met:
+#define TEST_NAME "LIBBSD VME 1"
+#include <assert.h>
+#include <stdlib.h>
+#include <stdio.h>
+#include <unistd.h>
+#include <bsp.h>
+#include <rtems/bsd/modules.h>
+#if defined(RTEMS_BSD_MODULE_TSI148) && defined(LIBBSP_POWERPC_QORIQ_BSP_H)
+#include <bsp/vmeTsi148.h>
+static void
+test_main(void)
+	int error = 0;
+	for (int vec = 42; vec < 43; ++vec) {
+		for (int lvl = 7; lvl > 0; --lvl) {
+			int x = vmeTsi148IntLoopbackTst(lvl, vec);
+			printf("Tsi Interrupt test lvl %d, vec %d: %d\n",
+				lvl, vec, x);
+			if (x != 0) {
+				error = x;
+	exit(error);
+#else /* RTEMS_BSD_MODULE_TSI148 */
+static void
+test_main(void)
+	puts("VME not enabled in the current build set or not available on this BSP.");
+	exit(0);
+#endif /* RTEMS_BSD_MODULE_TSI148 */
+#define RTEMS_BSD_CONFIG_BSP_CONFIG
+#include <rtems/bsd/test/default-init.h>
2.35.3
