[PATCH rtems-libbsd 13/14] tsi148: Add an RTEMS VME glue layer
Christian Mauderer christian.mauderer at embedded-brains.de
Tue Jan 23 09:09:14 UTC 2024
The glue layer provides the necessary function so that the Tsi148 driver
in the BSP can use the PCI functionality from libbsd.
 libbsd.py                               |   1 +
 rtemsbsd/sys/dev/vme/tsi148.c           |  24 +++-
 rtemsbsd/sys/dev/vme/vme-rtems-compat.c | 143 ++++++++++++++++++++++++
 3 files changed, 167 insertions(+), 1 deletion(-)
 create mode 100644 rtemsbsd/sys/dev/vme/vme-rtems-compat.c
diff --git a/libbsd.py b/libbsd.py
index ed40106c..b05ea069 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -3152,6 +3152,7 @@ class tsi148(builder.Module):
         self.addRTEMSKernelSourceFiles(
                 'sys/dev/vme/tsi148.c',
+                'sys/dev/vme/vme-rtems-compat.c',
             mm.generator['source']()
diff --git a/rtemsbsd/sys/dev/vme/tsi148.c b/rtemsbsd/sys/dev/vme/tsi148.c
index 56c746bc..99c3cfcd 100644
--- a/rtemsbsd/sys/dev/vme/tsi148.c
+++ b/rtemsbsd/sys/dev/vme/tsi148.c
@@ -27,6 +27,10 @@
 #include <machine/rtems-bsd-kernel-space.h>
+#include <bsp.h>
+#ifdef LIBBSP_POWERPC_QORIQ_BSP_H
+#include <bsp/VMEConfig.h>
 #include <sys/cdefs.h>
 #include <sys/param.h>
 #include <sys/kernel.h>
@@ -37,6 +41,8 @@
 #include <dev/pci/pcireg.h>
 #include <dev/pci/pcivar.h>
+#include <stdio.h>
 struct tsi148 {
 	device_t		dev;
 	int			mem_rid;
@@ -52,6 +58,13 @@ tsi148_intr(void *arg)
 	struct tsi148 *sc;
 	sc = arg;
+	 * Note: This interrupt is never used. It would be used in case of MSIs.
+	 * But the Tsi148 can't generate them. So this interrupt must never
+	 * happen.
+	puts("tsi148_intr: Unexpected interrupt. Should never happen.\n");
 static int
@@ -71,6 +84,11 @@ tsi148_attach(device_t dev)
 	struct tsi148 *sc;
+	if (bsp_vme_pcie_base_address != 0) {
+		puts("tsi148: Another instance is already attached.\n");
+		return (ENXIO);
 	sc = device_get_softc(dev);
 	sc->dev = dev;
@@ -94,7 +112,10 @@ tsi148_attach(device_t dev)
 		return (ENOMEM);
-	return (ENXIO);
+	bsp_vme_pcie_base_address = sc->mem_res->r_bushandle;
+	BSP_vme_config();
+	return 0;
 static int
@@ -121,3 +142,4 @@ static driver_t tsi148_driver = {
 static devclass_t tsi148_devclass;
 DRIVER_MODULE(tsi148, pci, tsi148_driver, tsi148_devclass, NULL, 0);
+#endif /* LIBBSP_POWERPC_QORIQ_BSP_H */
diff --git a/rtemsbsd/sys/dev/vme/vme-rtems-compat.c b/rtemsbsd/sys/dev/vme/vme-rtems-compat.c
new file mode 100644
index 00000000..c5ce8d84
--- /dev/null
+++ b/rtemsbsd/sys/dev/vme/vme-rtems-compat.c
@@ -0,0 +1,143 @@
+ * Copyright (C) 2023 embedded brains GmbH
+ * are met:
+ * This file is a glue layer that allows the TSI148 RTEMS VME driver to use the
+ * libbsd PCI support.
+typedef void FILE;
+#define __INSIDE_RTEMS_BSP__
+#include <rtems/pci.h>
+#include <machine/rtems-bsd-kernel-space.h>
+#include <sys/types.h>
+#include <sys/bus.h>
+#include <sys/pciio.h>
+#include <dev/pci/pcivar.h>
+#undef pci_find_device
+static device_t dev;
+static int
+read_config_byte(unsigned char bus, unsigned char slot, unsigned char func,
+    unsigned char reg, uint8_t *val)
+	*val = (uint8_t)pci_read_config(dev, reg, 1);
+	return 0;
+static int
+read_config_word(unsigned char bus, unsigned char slot, unsigned char func,
+    unsigned char reg, uint16_t *val)
+	*val = (uint16_t)pci_read_config(dev, reg, 2);
+	return 0;
+static int
+read_config_dword(unsigned char bus, unsigned char slot, unsigned char func,
+    unsigned char reg, uint32_t *val)
+	*val = pci_read_config(dev, reg, 4);
+	return 0;
+static int
+write_config_byte(unsigned char bus, unsigned char slot, unsigned char func,
+    unsigned char reg, uint8_t val)
+	pci_write_config(dev, reg, val, 1);
+	return 0;
+static int
+write_config_word(unsigned char bus, unsigned char slot, unsigned char func,
+    unsigned char reg, uint16_t val)
+	pci_write_config(dev, reg, val, 2);
+	return 0;
+static int
+write_config_dword(unsigned char bus, unsigned char slot, unsigned char func,
+    unsigned char reg, uint32_t val)
+	pci_write_config(dev, reg, val, 4);
+	return 0;
+static const pci_config_access_functions pci_functions = {
+	.read_config_byte = read_config_byte,
+	.read_config_word = read_config_word,
+	.read_config_dword = read_config_dword,
+	.write_config_byte = write_config_byte,
+	.write_config_word = write_config_word,
+	.write_config_dword = write_config_dword
+rtems_pci_config_t BSP_pci_configuration = {
+	.pci_functions = &pci_functions
+int
+pci_find_device(unsigned short vendorid, unsigned short deviceid,
+    int instance, int *pbus, int *pdev, int *pfun)
+	struct pci_devinfo *dinfo;
+	if (instance != 0) {
+		return -1;
+	if (dev != NULL) {
+		return -1;
+	dev = _bsd_pci_find_device(vendorid, deviceid);
+	if (dev == NULL) {
+		return -1;
+	dinfo = device_get_ivars(dev);
+	*pbus = dinfo->conf.pc_sel.pc_bus;
+	*pdev = dinfo->conf.pc_sel.pc_dev;
+	*pfun = dinfo->conf.pc_sel.pc_func;
+	return 0;
+#include <bsp.h>
+uintptr_t bsp_vme_pcie_base_address = 0;
+unsigned short (*_BSP_clear_vmebridge_errors)(int) = NULL;
+#endif
2.35.3
