[RTEMS Tools 0/1] trace/wscript: Improve C++ standard selection
Wed Jan 24 13:33:07 UTC 2024
----- Am 24. Jan 2024 um 0:55 schrieb Chris Johns chrisj at rtems.org:
> On 23/1/2024 5:55 pm, Sebastian Huber wrote:
>> ----- Am 22. Jan 2024 um 22:56 schrieb Chris Johns chrisj at rtems.org:
>> The usage of LLVM for the RTEMS Tools is optional. You can build them without
>> LLVM. However, this patch is relevant to a host which has LLVM installed. So,
>> to test this patch you need an LLVM installation.
> Great and thanks. The change is fine to push however I like to understand some
> things ...
> Does this mean that tool does not work on some operating systems?
The tool works, but not with all features.
> Does the user get any indication?
In the traces, the mapping of addresses to source files and lines doesn't work. So, you just see an address.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
