[RTEMS Tools 0/1] trace/wscript: Improve C++ standard selection
Thu Jan 25 00:52:40 UTC 2024
On 25/1/2024 12:33 am, Sebastian Huber wrote:
> ----- Am 24. Jan 2024 um 0:55 schrieb Chris Johns chrisj at rtems.org:
>> On 23/1/2024 5:55 pm, Sebastian Huber wrote:
>>> ----- Am 22. Jan 2024 um 22:56 schrieb Chris Johns chrisj at rtems.org:
>>> The usage of LLVM for the RTEMS Tools is optional. You can build them without
>>> LLVM. However, this patch is relevant to a host which has LLVM installed. So,
>>> to test this patch you need an LLVM installation.
>> Great and thanks. The change is fine to push however I like to understand some
>> things ...
>> Does this mean that tool does not work on some operating systems?
> The tool works, but not with all features.
>> Does the user get any indication?
> In the traces, the mapping of addresses to source files and lines doesn't work. So, you just see an address.
Thanks
