bsps: xilinx-zynqmp-rpu: fix the integer truncation in Triple Timer Counter clock driver
Tue Mar 19 10:50:44 UTC 2024
Hello Stanislav,
that is a nice coincidence. I started to work with this BSP last week
and I also fixed this issue, but I had some other patches in the queue.
I reworked this driver a bit. I will check in your patch first.
On 19.03.24 10:54, Stanislav Pankevich wrote:
> Dear RTEMS developers,
> Here is a follow-up patch to our previous work on the Zynq US+ RPU BSP.
> In fact, we had fixed this issue a few months ago but didn't find a good
> time to upstream it since then.
> P.S. It is great to see that the migration to GitLab is happening.
> Thanks,
> Stanislav
> Author: Stanislav Pankevich <stanislav at reflexaerospace.com>
> Date:   Tue Mar 19 10:34:57 2024 +0100
>      We observed a strange behavior of the 1Hz timer when running cFS on
> Zynq RPU. After some investigation, we reduced the error to the
> truncation issue. This patch fixes the issue.
> diff --git a/bsps/shared/dev/clock/xil-ttc.c
> b/bsps/shared/dev/clock/xil-ttc.c
> index 2c47684045..5121773a6f 100644
> --- a/bsps/shared/dev/clock/xil-ttc.c
> +++ b/bsps/shared/dev/clock/xil-ttc.c
> @@ -126,7 +126,7 @@ static void
> zynqmp_ttc_clock_driver_support_initialize_hardware(void)
>     /* Setup match register to generate tick IRQ */
>     ttc_clock_instance.irq_match_interval =
> -    (uint32_t) ((frequency * microsec_per_tick) / 1000000);
> +    (uint32_t) (((uint64_t)frequency * microsec_per_tick) / 1000000);
>     XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_MATCH_0_OFFSET,
>                     ttc_clock_instance.irq_match_interval);
>     /* Clear interupts (clear on read) */
> devel mailing list
> devel at rtems.org
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
