AW: bsps: xilinx-zynqmp-rpu: fix the integer truncation in Triple Timer Counter clock driver
Stanislav Pankevich stanislav at reflexaerospace.com
Tue Mar 19 12:19:52 UTC 2024
Hello Sebastian,
I have also reviewed the other changes that we now have since the original BSP patch, and it looks like our current queue for Zynq RPU is empty.
We are curious to see which changes/rework for RPU you are preparing.
Thanks,
Stanislav
________________________________
Von: Sebastian Huber <sebastian.huber at embedded-brains.de>
Gesendet: Dienstag, 19. März 2024 11:50
An: Stanislav Pankevich <stanislav at reflexaerospace.com>; devel at rtems.org <devel at rtems.org>
Betreff: Re: bsps: xilinx-zynqmp-rpu: fix the integer truncation in Triple Timer Counter clock driver
[Sie erhalten nicht häufig E-Mails von sebastian.huber at embedded-brains.de. Weitere Informationen, warum dies wichtig ist, finden Sie unter https://aka.ms/LearnAboutSenderIdentification ]
Hello Stanislav,
that is a nice coincidence. I started to work with this BSP last week
and I also fixed this issue, but I had some other patches in the queue.
I reworked this driver a bit. I will check in your patch first.
On 19.03.24 10:54, Stanislav Pankevich wrote:
> Dear RTEMS developers,
> Here is a follow-up patch to our previous work on the Zynq US+ RPU BSP.
> In fact, we had fixed this issue a few months ago but didn't find a good
> time to upstream it since then.
> P.S. It is great to see that the migration to GitLab is happening.
> Thanks,
> Stanislav
> Author: Stanislav Pankevich <stanislav at reflexaerospace.com>
> Date:   Tue Mar 19 10:34:57 2024 +0100
>      We observed a strange behavior of the 1Hz timer when running cFS on
> Zynq RPU. After some investigation, we reduced the error to the
> truncation issue. This patch fixes the issue.
> diff --git a/bsps/shared/dev/clock/xil-ttc.c
> b/bsps/shared/dev/clock/xil-ttc.c
> index 2c47684045..5121773a6f 100644
> --- a/bsps/shared/dev/clock/xil-ttc.c
> +++ b/bsps/shared/dev/clock/xil-ttc.c
> @@ -126,7 +126,7 @@ static void
> zynqmp_ttc_clock_driver_support_initialize_hardware(void)
>     /* Setup match register to generate tick IRQ */
>     ttc_clock_instance.irq_match_interval =
> -    (uint32_t) ((frequency * microsec_per_tick) / 1000000);
> +    (uint32_t) (((uint64_t)frequency * microsec_per_tick) / 1000000);
>     XTtcPs_WriteReg(BSP_SELECTED_TTC_ADDR, XTTCPS_MATCH_0_OFFSET,
>                     ttc_clock_instance.irq_match_interval);
>     /* Clear interupts (clear on read) */
> devel mailing list
> devel at rtems.org
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240319/45f65386/attachment.htm>
