[PATCH 3/5] xilinx-zynqmp-rpu: Remove URLs from copyrights
Philip Kirkpatrick p.kirkpatrick at reflexaerospace.com
Tue Mar 19 16:49:42 UTC 2024
Sebastian,
Looks good with me.  Stanislav also gave approval.
-Phil
________________________________
From: Stanislav Pankevich <stanislav at reflexaerospace.com>
Sent: Tuesday, March 19, 2024 5:45 PM
To: Philip Kirkpatrick <p.kirkpatrick at reflexaerospace.com>
Subject: WG: [PATCH 3/5] xilinx-zynqmp-rpu: Remove URLs from copyrights
Von: Sebastian Huber <sebastian.huber at embedded-brains.de>
Gesendet: Dienstag, 19. März 2024 16:46
An: Stanislav Pankevich <stanislav at reflexaerospace.com>
Betreff: Fwd: [PATCH 3/5] xilinx-zynqmp-rpu: Remove URLs from copyrights
Hello Stanislav,
it would be nice if you could approve or disapprove this change on the
RTEMS mailing list.
I guess you used our old copyright statement as a template, but we
removed the URL since it was quite uncommon to do this.
-------- Forwarded Message --------
Subject: [PATCH 3/5] xilinx-zynqmp-rpu: Remove URLs from copyrights
Date: Mon, 18 Mar 2024 17:30:04 +0100
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: devel at rtems.org
  spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml            | 2 +-
  spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml  | 2 +-
  spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml       | 2 +-
  spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml | 2 +-
  4 files changed, 4 insertions(+), 4 deletions(-)
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
index ba70c44d7d..06795eb416 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
@@ -5,7 +5,7 @@ actions:
  - env-append: null
  build-type: option
  copyrights:
-- Copyright (C) 2023 Reflex Aerospace GmbH (
https://www.reflexaerospace.com/ )
+- Copyright (C) 2023 Reflex Aerospace GmbH
  default:
  - enabled-by: true
    value:
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
index d08f048060..3fa210d8e7 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml
@@ -4,7 +4,7 @@ bsp: xilinx_zynqmp_mercuryxu5_rpu
  build-type: bsp
  cflags: []
  copyrights:
  cppflags: []
  enabled-by: true
  family: xilinx-zynqmp-rpu
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
index a3654f3f42..9c8a6d1cd6 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml
@@ -38,7 +38,7 @@ content: |
    _stack_end = bsp_section_stack_end;
    __undef_stack = bsp_section_stack_begin;
  copyrights:
  enabled-by: true
  install-path: ${BSP_LIBDIR}
  links: []
diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
index 09a3965906..d684f5a06d 100644
--- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
+++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml
@@ -4,7 +4,7 @@ actions:
  - define-condition: null
  build-type: option
  copyrights:
  default:
  - enabled-by: true
    value: true
2.35.3
devel mailing list
devel at rtems.org
http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20240319/7c048127/attachment.htm>
