[PATCH 3/5] xilinx-zynqmp-rpu: Remove URLs from copyrights
Tue Mar 19 17:28:55 UTC 2024
On 19/3/2024 5:52 pm, Sebastian Huber wrote:
> On 19.03.24 03:20, Chris Johns wrote:
>> On 19/3/2024 3:30 am, Sebastian Huber wrote:
>>>   spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml            | 2 +-
>>>   spec/build/bsps/arm/xilinx-zynqmp-rpu/bspmercuryxu5.yml  | 2 +-
>>>   spec/build/bsps/arm/xilinx-zynqmp-rpu/linkcmds.yml       | 2 +-
>>>   spec/build/bsps/arm/xilinx-zynqmp-rpu/optprocunitrpu.yml | 2 +-
>>>   4 files changed, 4 insertions(+), 4 deletions(-)
>>> diff --git a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
>>> b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
>>> index ba70c44d7d..06795eb416 100644
>>> --- a/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
>>> +++ b/spec/build/bsps/arm/xilinx-zynqmp-rpu/abi.yml
>>> @@ -5,7 +5,7 @@ actions:
>>>   - env-append: null
>>>   build-type: option
>>>   copyrights:
>>> -- Copyright (C) 2023 Reflex Aerospace GmbH (https://www.reflexaerospace.com/  )
>>> +- Copyright (C) 2023 Reflex Aerospace GmbH
>> Why this change?
> When I updated our company name to embedded brains GmbH & Co. KG, I removed the
> URLs from our copyright statements since we were basically the only ones doing
> this. If you don't have an issue with the URLs, then I will discuss internally
> if we would like to add them again to our copyright statements.
This is fine. I was wondering if there was some technical reason which there is not.
