Xilinx header files installed by BSP
Tue Mar 26 07:02:11 UTC 2024
On 25.03.24 21:36, Bernd Moessner wrote:
> On 25.03.2024 13:26, Sebastian Huber wrote:
>> Hello,
>> the BSPs for the Xilinx Zynq/ZynqMP/Versal platforms use code from
>> Xilinx. They also install some header files from Xilinx in the
>> top-level include directory of the BSP, for example:
>> sleep.h  xbasic_types.h  xil_assert.h  xil_cache.h xil_exception.h
>> xil_io.h  xil_mem.h  xil_printf.h  xil_smc.h xil_types.h xparameters.h
>>  xpseudo_asm_gcc.h  xpseudo_asm.h xreg_cortexa53.h xstatus.h
>> This can lead to conflicts if I would like to build software from
>> https://github.com/Xilinx/embeddedsw
>> because now some header files are duplicated and available through
>> different include paths. Why do we install these header files? I think
>> they should be only used internally to build the BSP provided drivers.
>> The RTEMS drivers should expose their interfaces not through the
>> Xilinx header files.
>> Any objections to remove the installation of the Xilinx header files?
> Dear Sebastian,
> Zynq 7000 is not using them. Rtems-lwip requires some of the headers. I
> provided a patch which added "objxilinxsupport.yml" to the Zynq 7000
> configurations. After a discussion on Discord my patch was rolled back
> (which I think was a good decision).
> Chris and Kinsey, please correct me if I misunderstood something, but as
> far as I understood it the headers will be removed from the kernel.
> Afaik, there are some drivers for the ZU require them. Thus, it will
> require some time / planning to overwork the drivers and move the
> required headers to rtems-lwip.
> Long story short, Chris and Kinsey should be able to give some more
> detailed information on the strategy and timeline.
Maybe one option is to install the BSP-provided Xilinx headers in bsp/,
for example:
#include <bsp/xparameters.h>
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
