Xilinx header files installed by BSP
Bernd Moessner berndmoessner80 at gmail.com
Mon Mar 25 20:36:53 UTC 2024
On 25.03.2024 13:26, Sebastian Huber wrote:
> Hello,
> the BSPs for the Xilinx Zynq/ZynqMP/Versal platforms use code from
> Xilinx. They also install some header files from Xilinx in the
> top-level include directory of the BSP, for example:
> sleep.h  xbasic_types.h  xil_assert.h  xil_cache.h xil_exception.h
> xil_io.h  xil_mem.h  xil_printf.h  xil_smc.h xil_types.h
> xparameters.h  xpseudo_asm_gcc.h  xpseudo_asm.h xreg_cortexa53.h
> xstatus.h
> This can lead to conflicts if I would like to build software from
> https://github.com/Xilinx/embeddedsw
> because now some header files are duplicated and available through
> different include paths. Why do we install these header files? I think
> they should be only used internally to build the BSP provided drivers.
> The RTEMS drivers should expose their interfaces not through the
> Xilinx header files.
> Any objections to remove the installation of the Xilinx header files?
Dear Sebastian,
Zynq 7000 is not using them. Rtems-lwip requires some of the headers. I
provided a patch which added "objxilinxsupport.yml" to the Zynq 7000
configurations. After a discussion on Discord my patch was rolled back
(which I think was a good decision).
Chris and Kinsey, please correct me if I misunderstood something, but as
far as I understood it the headers will be removed from the kernel.
Afaik, there are some drivers for the ZU require them. Thus, it will
require some time / planning to overwork the drivers and move the
required headers to rtems-lwip.
Long story short, Chris and Kinsey should be able to give some more
detailed information on the strategy and timeline.
Regards
