[PATCH v2 2/3] dev/serial: Add ZYNQ_UART_[01]_BASE_ADDR
Wed Mar 27 19:43:35 UTC 2024
This helps to provide a shared implementation of the kernel I/O support.
 bsps/aarch64/xilinx-zynqmp/console/console.c  |  4 +-
 bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  2 +
 bsps/arm/xilinx-zynq/console/console-config.c |  5 +-
 bsps/arm/xilinx-zynq/include/bsp.h            |  1 +
 .../console/console-config.c                  |  4 +-
 bsps/arm/xilinx-zynqmp-rpu/include/bsp.h      |  2 +
 .../xilinx-zynqmp/console/console-config.c    |  4 +-
 bsps/arm/xilinx-zynqmp/include/bsp.h          |  2 +
 bsps/include/dev/serial/zynq-uart-zynq.h      | 66 +++++++++++++++++++
 bsps/include/dev/serial/zynq-uart-zynqmp.h    | 66 +++++++++++++++++++
 10 files changed, 148 insertions(+), 8 deletions(-)
 create mode 100644 bsps/include/dev/serial/zynq-uart-zynq.h
 create mode 100644 bsps/include/dev/serial/zynq-uart-zynqmp.h
diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
index 1e5df997e8..ce031a914e 100644
--- a/bsps/aarch64/xilinx-zynqmp/console/console.c
+++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
@@ -188,11 +188,11 @@ RTEMS_SYSINIT_ITEM(
 static zynq_uart_context zynqmp_uart_instances[2] = {
     .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
-    .regs = (volatile struct zynq_uart *) 0xff000000,
+    .regs = (volatile zynq_uart *) ZYNQ_UART_0_BASE_ADDR,
     .irq = ZYNQMP_IRQ_UART_0
     .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 1" ),
-    .regs = (volatile struct zynq_uart *) 0xff010000,
+    .regs = (volatile zynq_uart *) ZYNQ_UART_1_BASE_ADDR,
     .irq = ZYNQMP_IRQ_UART_1
diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
index 0ccca8b196..38a9fad768 100644
--- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
+++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
@@ -55,6 +55,8 @@
 #include <rtems/termiostypes.h>
+#include <dev/serial/zynq-uart-zynqmp.h>
 #ifdef __cplusplus
 extern "C" {
 #endif /* __cplusplus */
diff --git a/bsps/arm/xilinx-zynq/console/console-config.c b/bsps/arm/xilinx-zynq/console/console-config.c
index d22ceb557d..42e64ee4dd 100644
--- a/bsps/arm/xilinx-zynq/console/console-config.c
+++ b/bsps/arm/xilinx-zynq/console/console-config.c
@@ -35,15 +35,16 @@
 #include <bsp/irq.h>
 #include <dev/serial/zynq-uart.h>
+#include <dev/serial/zynq-uart-regs.h>
 zynq_uart_context zynq_uart_instances[2] = {
-    .regs = (volatile struct zynq_uart *) 0xe0000000,
     .irq = ZYNQ_IRQ_UART_0
-    .regs = (volatile struct zynq_uart *) 0xe0001000,
     .irq = ZYNQ_IRQ_UART_1
diff --git a/bsps/arm/xilinx-zynq/include/bsp.h b/bsps/arm/xilinx-zynq/include/bsp.h
index 3311a99b50..5ffd5f573a 100644
--- a/bsps/arm/xilinx-zynq/include/bsp.h
+++ b/bsps/arm/xilinx-zynq/include/bsp.h
@@ -55,6 +55,7 @@
 #include <bsp/default-initial-extension.h>
 #include <bsp/start.h>
+#include <dev/serial/zynq-uart-zynq.h>
 #ifdef __cplusplus
 extern "C" {
diff --git a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
index eacf6ddcce..13eaa269c5 100644
--- a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
+++ b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
@@ -44,11 +44,11 @@
diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
index e386bd4b26..d80cedbd0d 100644
--- a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
+++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
@@ -61,6 +61,8 @@
 #include <peripheral_maps/xilinx_zynqmp.h>
 #ifdef __cplusplus
 extern "C" {
diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c b/bsps/arm/xilinx-zynqmp/console/console-config.c
index ea148836a5..787ee05dd6 100644
--- a/bsps/arm/xilinx-zynqmp/console/console-config.c
+++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
@@ -44,11 +44,11 @@
+    .regs = (volatile struct zynq_uart *) ZYNQ_UART_0_BASE_ADDR,
+    .regs = (volatile struct zynq_uart *) ZYNQ_UART_1_BASE_ADDR,
diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h b/bsps/arm/xilinx-zynqmp/include/bsp.h
index a08a5feee9..cdc37b79a4 100644
--- a/bsps/arm/xilinx-zynqmp/include/bsp.h
+++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
@@ -60,6 +60,8 @@
 #ifdef __cplusplus
 extern "C" {
diff --git a/bsps/include/dev/serial/zynq-uart-zynq.h b/bsps/include/dev/serial/zynq-uart-zynq.h
new file mode 100644
index 0000000000..169037b33a
--- /dev/null
+++ b/bsps/include/dev/serial/zynq-uart-zynq.h
@@ -0,0 +1,66 @@
+ * @file
+ * @ingroup zynq_uart
+ * @brief This header file provides interfaces with respect to the Zynq
+ *   platform.
+ * Copyright (C) 2024 embedded brains GmbH & Co. KG
+ * are met:
+#ifndef _DEV_SERIAL_ZYNQ_UART_ZYNQ_H
+#define _DEV_SERIAL_ZYNQ_UART_ZYNQ_H
+#ifdef __cplusplus
+extern "C" {
+#endif /* __cplusplus */
+ * @addtogroup zynq_uart
+ * @brief This constant defines the Xilinx Zynq UART 0 base address.
+#define ZYNQ_UART_0_BASE_ADDR 0xe0000000
+ * @brief This constant defines the Xilinx Zynq UART 1 base address.
+#define ZYNQ_UART_1_BASE_ADDR 0xe0001000
+#ifdef __cplusplus
+#endif /* _DEV_SERIAL_ZYNQ_UART_ZYNQ_H */
diff --git a/bsps/include/dev/serial/zynq-uart-zynqmp.h b/bsps/include/dev/serial/zynq-uart-zynqmp.h
index 0000000000..9f29003053
--- /dev/null
+++ b/bsps/include/dev/serial/zynq-uart-zynqmp.h
@@ -0,0 +1,66 @@
+ * @file
+ *   UltraScale+ MPSoC and RFSoC platforms.
+ * are met:
+#ifndef _DEV_SERIAL_ZYNQ_UART_ZYNQMP_H
+#define _DEV_SERIAL_ZYNQ_UART_ZYNQMP_H
+#ifdef __cplusplus
+extern "C" {
+#define ZYNQ_UART_0_BASE_ADDR 0xff000000
+#define ZYNQ_UART_1_BASE_ADDR 0xff010000
+#ifdef __cplusplus
+#endif /* _DEV_SERIAL_ZYNQ_UART_ZYNQMP_H */
2.35.3
