[PATCH v2 2/3] dev/serial: Add ZYNQ_UART_[01]_BASE_ADDR
Thu Mar 28 02:26:06 UTC 2024
On 28/3/2024 6:43 am, Sebastian Huber wrote:
> This helps to provide a shared implementation of the kernel I/O support.
>  bsps/aarch64/xilinx-zynqmp/console/console.c  |  4 +-
>  bsps/aarch64/xilinx-zynqmp/include/bsp.h      |  2 +
>  bsps/arm/xilinx-zynq/console/console-config.c |  5 +-
>  bsps/arm/xilinx-zynq/include/bsp.h            |  1 +
>  .../console/console-config.c                  |  4 +-
>  bsps/arm/xilinx-zynqmp-rpu/include/bsp.h      |  2 +
>  .../xilinx-zynqmp/console/console-config.c    |  4 +-
>  bsps/arm/xilinx-zynqmp/include/bsp.h          |  2 +
>  bsps/include/dev/serial/zynq-uart-zynq.h      | 66 +++++++++++++++++++
>  bsps/include/dev/serial/zynq-uart-zynqmp.h    | 66 +++++++++++++++++++
>  10 files changed, 148 insertions(+), 8 deletions(-)
>  create mode 100644 bsps/include/dev/serial/zynq-uart-zynq.h
>  create mode 100644 bsps/include/dev/serial/zynq-uart-zynqmp.h
> diff --git a/bsps/aarch64/xilinx-zynqmp/console/console.c b/bsps/aarch64/xilinx-zynqmp/console/console.c
> index 1e5df997e8..ce031a914e 100644
> --- a/bsps/aarch64/xilinx-zynqmp/console/console.c
> +++ b/bsps/aarch64/xilinx-zynqmp/console/console.c
> @@ -188,11 +188,11 @@ RTEMS_SYSINIT_ITEM(
>  static zynq_uart_context zynqmp_uart_instances[2] = {
>      .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 0" ),
> -    .regs = (volatile struct zynq_uart *) 0xff000000,
> +    .regs = (volatile zynq_uart *) ZYNQ_UART_0_BASE_ADDR,
>      .irq = ZYNQMP_IRQ_UART_0
>      .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER( "Zynq UART 1" ),
> -    .regs = (volatile struct zynq_uart *) 0xff010000,
> +    .regs = (volatile zynq_uart *) ZYNQ_UART_1_BASE_ADDR,
>      .irq = ZYNQMP_IRQ_UART_1
> diff --git a/bsps/aarch64/xilinx-zynqmp/include/bsp.h b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> index 0ccca8b196..38a9fad768 100644
> --- a/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> +++ b/bsps/aarch64/xilinx-zynqmp/include/bsp.h
> @@ -55,6 +55,8 @@
>  #include <rtems.h>
>  #include <rtems/termiostypes.h>
> +#include <dev/serial/zynq-uart-zynqmp.h>
>  #ifdef __cplusplus
>  extern "C" {
>  #endif /* __cplusplus */
> diff --git a/bsps/arm/xilinx-zynq/console/console-config.c b/bsps/arm/xilinx-zynq/console/console-config.c
> index d22ceb557d..42e64ee4dd 100644
> --- a/bsps/arm/xilinx-zynq/console/console-config.c
> +++ b/bsps/arm/xilinx-zynq/console/console-config.c
> @@ -35,15 +35,16 @@
>  #include <bsp/irq.h>
>  #include <dev/serial/zynq-uart.h>
> +#include <dev/serial/zynq-uart-regs.h>
>  zynq_uart_context zynq_uart_instances[2] = {
> -    .regs = (volatile struct zynq_uart *) 0xe0000000,
>      .irq = ZYNQ_IRQ_UART_0
> -    .regs = (volatile struct zynq_uart *) 0xe0001000,
>      .irq = ZYNQ_IRQ_UART_1
> diff --git a/bsps/arm/xilinx-zynq/include/bsp.h b/bsps/arm/xilinx-zynq/include/bsp.h
> index 3311a99b50..5ffd5f573a 100644
> --- a/bsps/arm/xilinx-zynq/include/bsp.h
> +++ b/bsps/arm/xilinx-zynq/include/bsp.h
> @@ -55,6 +55,7 @@
>  #include <bsp/default-initial-extension.h>
>  #include <bsp/start.h>
> +#include <dev/serial/zynq-uart-zynq.h>
>  #ifdef __cplusplus
>  extern "C" {
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> index eacf6ddcce..13eaa269c5 100644
> --- a/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> +++ b/bsps/arm/xilinx-zynqmp-rpu/console/console-config.c
> @@ -44,11 +44,11 @@
> diff --git a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> index e386bd4b26..d80cedbd0d 100644
> --- a/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> +++ b/bsps/arm/xilinx-zynqmp-rpu/include/bsp.h
> @@ -61,6 +61,8 @@
>  #include <peripheral_maps/xilinx_zynqmp.h>
>  #ifdef __cplusplus
>  extern "C" {
> diff --git a/bsps/arm/xilinx-zynqmp/console/console-config.c b/bsps/arm/xilinx-zynqmp/console/console-config.c
> index ea148836a5..787ee05dd6 100644
> --- a/bsps/arm/xilinx-zynqmp/console/console-config.c
> +++ b/bsps/arm/xilinx-zynqmp/console/console-config.c
> @@ -44,11 +44,11 @@
> +    .regs = (volatile struct zynq_uart *) ZYNQ_UART_0_BASE_ADDR,
> +    .regs = (volatile struct zynq_uart *) ZYNQ_UART_1_BASE_ADDR,
> diff --git a/bsps/arm/xilinx-zynqmp/include/bsp.h b/bsps/arm/xilinx-zynqmp/include/bsp.h
> index a08a5feee9..cdc37b79a4 100644
> --- a/bsps/arm/xilinx-zynqmp/include/bsp.h
> +++ b/bsps/arm/xilinx-zynqmp/include/bsp.h
> @@ -60,6 +60,8 @@
>  #ifdef __cplusplus
>  extern "C" {
> diff --git a/bsps/include/dev/serial/zynq-uart-zynq.h b/bsps/include/dev/serial/zynq-uart-zynq.h
> new file mode 100644
> index 0000000000..169037b33a
> --- /dev/null
> +++ b/bsps/include/dev/serial/zynq-uart-zynq.h
> @@ -0,0 +1,66 @@
> +/* SPDX-License-Identifier: BSD-2-Clause */
> + * @file
> + * @ingroup zynq_uart
> + * @brief This header file provides interfaces with respect to the Zynq
> + *   platform.
> + * Copyright (C) 2024 embedded brains GmbH & Co. KG
> + * Redistribution and use in source and binary forms, with or without
> + * modification, are permitted provided that the following conditions
> + * are met:
> + * 1. Redistributions of source code must retain the above copyright
> + *    notice, this list of conditions and the following disclaimer.
> + * 2. Redistributions in binary form must reproduce the above copyright
> + *    notice, this list of conditions and the following disclaimer in the
> + *    documentation and/or other materials provided with the distribution.
> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR CONTRIBUTORS BE
> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
> + * POSSIBILITY OF SUCH DAMAGE.
> +#ifndef _DEV_SERIAL_ZYNQ_UART_ZYNQ_H
> +#define _DEV_SERIAL_ZYNQ_UART_ZYNQ_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif /* __cplusplus */
> + * @addtogroup zynq_uart
> + * @brief This constant defines the Xilinx Zynq UART 0 base address.
> +#define ZYNQ_UART_0_BASE_ADDR 0xe0000000
> + * @brief This constant defines the Xilinx Zynq UART 1 base address.
> +#define ZYNQ_UART_1_BASE_ADDR 0xe0001000
> +#ifdef __cplusplus
> +#endif /* _DEV_SERIAL_ZYNQ_UART_ZYNQ_H */
> diff --git a/bsps/include/dev/serial/zynq-uart-zynqmp.h b/bsps/include/dev/serial/zynq-uart-zynqmp.h
> index 0000000000..9f29003053
> --- /dev/null
> +++ b/bsps/include/dev/serial/zynq-uart-zynqmp.h
> @@ -0,0 +1,66 @@
> + * @file
> + *   UltraScale+ MPSoC and RFSoC platforms.
> + * are met:
> +#ifndef _DEV_SERIAL_ZYNQ_UART_ZYNQMP_H
> +#define _DEV_SERIAL_ZYNQ_UART_ZYNQMP_H
> +#ifdef __cplusplus
> +extern "C" {
> +#define ZYNQ_UART_0_BASE_ADDR 0xff000000
> +#define ZYNQ_UART_1_BASE_ADDR 0xff010000
This is the same as the Versal so is the name of this file OK for use in the
Versal? I do not have a better name?
