Acessing PL devices of Xilinx Zedboard
Jan.Sommer at dlr.de Jan.Sommer at dlr.de
Wed Nov 18 17:29:29 UTC 2020
Hi Jonathan,
Thank you very much for the tip.
I did overwrite the translation table with an additional entry and can now successfully access the device.
Cheers,
    Jan
From: Jonathan Brandmeyer <jbrandmeyer at planetiq.com>
Sent: Wednesday, November 18, 2020 5:01 PM
To: Sommer, Jan <Jan.Sommer at dlr.de>
Cc: RTEMS <users at rtems.org>
Subject: Re: Acessing PL devices of Xilinx Zedboard
On Wed, Nov 18, 2020 at 8:37 AM <Jan.Sommer at dlr.de<mailto:Jan.Sommer at dlr.de>> wrote:
Hello,
We try to use the xilinx_zynq_zedboard BSP with some devices synthesized to the PL, e.g. a Xilinx NS16550 Uart.
If I try to access any of the AXI registers, I get a fatal error with a vector number 0x04 (undefined instruction).
Accessing the same register address from within a Xilinx standalone hello-world program works as expected.
Could it be that during the RTEMS startup some of the system initialization is reset so that accessing the PL devices fails?
The default memory map does not provide access to any of the PL address range.  You'll have to override the weak symbol zynq_setup_mmu_and_cache to provide your own memory map.  The MMU code only supports 1 MB superpages at this time.
Caveat: My information could be a little out of date.  We're still running on a pre-release version of RTEMS 5.0.  But hopefully this points you in the right direction.  In particular, I know that some work has been done to support 4kB pages, but I don't know if the entry point arm_cp15_start_setup_translation_table_and_enable_mmu_and_cache currently uses that support or not.
Jonathan Brandmeyer
PlanetiQ
URL: <http://lists.rtems.org/pipermail/users/attachments/20201118/f7721289/attachment.html>
