Hello world fails
Tue Jul 11 15:24:37 UTC 2023
On Tue, Jul 11, 2023 at 8:35 AM Brett Sterling <brett.sterling at odysseysr.com>
wrote:
> I've been working my way through the 'Quick Start' and everything was
> going pretty well until
> https://docs.rtems.org/branches/master/user/start/app.html.
> I get to the point where I'm supposed to 'configure', and I get the
> following:
> ~/src/rtems/quick-start/app/hello$ ./waf configure
> --rtems=$HOME/src/rtems/quick-start/rtems/6 --rtems-bsp=sparc/erc32
> Setting top to                           :
> /home/bsterling/src/rtems/quick-start/app/hello
> Setting out to                           :
> /home/bsterling/src/rtems/quick-start/app/hello/build
> RTEMS path is not valid,
> "/home/bsterling/src/rtems/quick-start/rtems/6/share/rtems6" not found.
> (complete log in
> /home/bsterling/src/rtems/quick-start/app/hello/build/config.log)
 I have this in my handy scripts for building rtems-examples:
CPU=powerpc
BSP=psim
./waf configure --rtems=${HOME}/rtems-work/tools/6/bsp-install \
                    --rtems-tools=${HOME}/rtems-work/tools/6 \
                    --rtems-bsps=${CPU}/${BSP}
That --rtems points to the --prefix directory you used when you built and
installed RTEMS.
This is from my install:
$ pwd
/home/joel/rtems-work/tools/6/bsp-install/sparc-rtems6/leon3
$ ls
lib  make  Makefile.inc
--rtems-tools directory should have a bin/TARGET-gcc under it.
--rtems-bsps looks OK
I think you have just pointed to the wrong directories. It should be
similar to
how I build rtems-examples.
--joel
> I have verified that all of the source files contain only what is
> described on that page.
> When I look in the rtems/6/share directory, I have the following:
> ~/src/rtems/quick-start/rtems/6/share$ ls -l
> total 32
> drwxr-xr-x 3 bsterling osr 4096 Jul 10 14:39 doc
> drwxr-xr-x 3 bsterling osr 4096 Jul 10 15:00 gcc-12.3.1
> drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:02 gdb
> drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:01 iconv_data
> drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:02 info
> drwxr-xr-x 2 bsterling osr 4096 Jul 10 14:43 locale
> drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:00 man
> drwxr-xr-x 9 bsterling osr 4096 Jul 10 15:02 rtems
Normally you don't point all the way down to share directory
> I tried renaming 'rtems' to 'rtems6', but that resulted in the following
> errors:
> Setting top to                           :
> Setting out to                           :
> Traceback (most recent call last):
>   File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py",
> line 119, in waf_entry_point
>     run_commands()
>   File
> line 182, in run_commands
>     ctx=run_command(cmd_name)
>   File
> line 173, in run_command
>     ctx.execute()
>   File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Configure.py",
> line 85, in execute
>     super(ConfigurationContext,self).execute()
>   File
> "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py",
> line 92, in execute
>     self.recurse([os.path.dirname(g_module.root_path)])
>   File
> line 133, in recurse
>     user_function(self)
>   File "/home/bsterling/src/rtems/quick-start/app/hello/wscript", line 26,
> in configure
>     rtems.configure(conf, bsp_configure = bsp_configure)
>   File
> "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line
> 190, in configure
>     check_options(conf,
>   File
> 496, in check_options
>     arch_bsps = _check_arch_bsps(rtems_bsps, rtems_config, rtems_path,
>   File
> 851, in _check_arch_bsps
>     installed = _find_installed_arch_bsps(config, path, archs, version)
>   File
> 823, in _find_installed_arch_bsps
>     if _arch_from_arch_bsp(f[:-3]) in archs:
>   File
> 862, in _arch_from_arch_bsp
>     rtems_field_index = next(i for i, field in enumerate(fields) if
> field.startswith('rtems'))
> StopIteration
> Please note that I started with rtems 6 because when I tried to use the
> released rtems 5 'Getting Started', I couldn't get past the first few
> steps.  That being said, I'm glad to go back to any other version if
> necessary, as I'm just trying to get to the point where I can work with
> RTEMS.
> Thanks in advance for any help!
> I'm using Ubuntu 22.04.2 LTS, and have followed the instructions in the
> 'Host Machine' setup section (as I mentioned, everything was working great
> up until this step).  The only way I was able to get things working was to
> clone the git repositories.  I'm on the 'master' branch.
> users mailing list
> users at rtems.org
URL: <http://lists.rtems.org/pipermail/users/attachments/20230711/ccc095b0/attachment-0001.htm>
