Hello world fails
Brett Sterling brett.sterling at odysseysr.com
Tue Jul 11 15:53:46 UTC 2023
Thanks for the response.  However, I think I need a little clarification.
In https://docs.rtems.org/branches/master/user/start/app.html, it says:
./waf configure --rtems=$HOME/quick-start/rtems/6 --rtems-bsp=sparc/erc32
My prefix is: '$HOME/src/rtems', so I used ' ./waf configure --rtems=$HOME/src/rtems/quick-start/rtems/6 --rtems-bsp=sparc/erc32'.
I believe this is equivalent to what you suggested, except that you have '--rtems-bsps' instead of '--rtems-bsp' (I think mine is the correct syntax).
As for "pointing to the share directory', I didn't do that - that was the error message printed when I tried to configure.
I'm not sure what you mean by pointing to the wrong directories - I followed the web page directions specifically.  However, I also admit I may have done something incorrectly, so if you could point to the thing I should change, I'm glad to do so :-)
Thanks again,
Brett
________________________________
Sent: Tuesday, July 11, 2023 9:24 AM
To: Brett Sterling <brett.sterling at odysseysr.com>
Cc: users at rtems.org <users at rtems.org>
Subject: Re: Hello world fails
CAUTION: This email originated from outside of the organization. Do not click links or open attachments unless you recognize the sender and know the content is safe.
On Tue, Jul 11, 2023 at 8:35 AM Brett Sterling <brett.sterling at odysseysr.com<mailto:brett.sterling at odysseysr.com>> wrote:
I've been working my way through the 'Quick Start' and everything was going pretty well until https://docs.rtems.org/branches/master/user/start/app.html<https://usg02.safelinks.protection.office365.us/?url=https%3A%2F%2Fdocs.rtems.org%2Fbranches%2Fmaster%2Fuser%2Fstart%2Fapp.html&data=05%7C01%7C%7C9a9d0447d98344cc537b08db8222f881%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638246858946228580%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=Dtgvw78TAZm5ncZnXGqqzGYs6jVioD%2Bn441t34HP%2F%2Bw%3D&reserved=0>.
I get to the point where I'm supposed to 'configure', and I get the following:
~/src/rtems/quick-start/app/hello$ ./waf configure --rtems=$HOME/src/rtems/quick-start/rtems/6 --rtems-bsp=sparc/erc32
Setting top to                           : /home/bsterling/src/rtems/quick-start/app/hello
Setting out to                           : /home/bsterling/src/rtems/quick-start/app/hello/build
RTEMS path is not valid, "/home/bsterling/src/rtems/quick-start/rtems/6/share/rtems6" not found.
(complete log in /home/bsterling/src/rtems/quick-start/app/hello/build/config.log)
 I have this in my handy scripts for building rtems-examples:
CPU=powerpc
BSP=psim
./waf configure --rtems=${HOME}/rtems-work/tools/6/bsp-install \
                    --rtems-tools=${HOME}/rtems-work/tools/6 \
                    --rtems-bsps=${CPU}/${BSP}
That --rtems points to the --prefix directory you used when you built and installed RTEMS.
This is from my install:
$ pwd
/home/joel/rtems-work/tools/6/bsp-install/sparc-rtems6/leon3
$ ls
lib  make  Makefile.inc
--rtems-tools directory should have a bin/TARGET-gcc under it.
--rtems-bsps looks OK
I think you have just pointed to the wrong directories. It should be similar to
how I build rtems-examples.
--joel
I have verified that all of the source files contain only what is described on that page.
When I look in the rtems/6/share directory, I have the following:
~/src/rtems/quick-start/rtems/6/share$ ls -l
total 32
drwxr-xr-x 3 bsterling osr 4096 Jul 10 14:39 doc
drwxr-xr-x 3 bsterling osr 4096 Jul 10 15:00 gcc-12.3.1
drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:02 gdb
drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:01 iconv_data
drwxr-xr-x 2 bsterling osr 4096 Jul 10 15:02 info
drwxr-xr-x 2 bsterling osr 4096 Jul 10 14:43 locale
drwxr-xr-x 5 bsterling osr 4096 Jul 10 15:00 man
drwxr-xr-x 9 bsterling osr 4096 Jul 10 15:02 rtems
Normally you don't point all the way down to share directory
I tried renaming 'rtems' to 'rtems6', but that resulted in the following errors:
Traceback (most recent call last):
  File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 119, in waf_entry_point
    run_commands()
  File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 182, in run_commands
    ctx=run_command(cmd_name)
  File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Scripting.py", line 173, in run_command
    ctx.execute()
  File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Configure.py", line 85, in execute
    super(ConfigurationContext,self).execute()
  File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py", line 92, in execute
    self.recurse([os.path.dirname(g_module.root_path)])
  File "/home/bsterling/src/rtems/quick-start/app/hello/.waf3-2.0.19-1f3c580272b15a03d2566843c5fe872a/waflib/Context.py", line 133, in recurse
    user_function(self)
  File "/home/bsterling/src/rtems/quick-start/app/hello/wscript", line 26, in configure
    rtems.configure(conf, bsp_configure = bsp_configure)
  File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 190, in configure
    check_options(conf,
  File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 496, in check_options
    arch_bsps = _check_arch_bsps(rtems_bsps, rtems_config, rtems_path,
  File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 851, in _check_arch_bsps
    installed = _find_installed_arch_bsps(config, path, archs, version)
  File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 823, in _find_installed_arch_bsps
    if _arch_from_arch_bsp(f[:-3]) in archs:
  File "/home/bsterling/src/rtems/quick-start/app/hello/rtems_waf/rtems.py", line 862, in _arch_from_arch_bsp
    rtems_field_index = next(i for i, field in enumerate(fields) if field.startswith('rtems'))
StopIteration
Please note that I started with rtems 6 because when I tried to use the released rtems 5 'Getting Started', I couldn't get past the first few steps.  That being said, I'm glad to go back to any other version if necessary, as I'm just trying to get to the point where I can work with RTEMS.
Thanks in advance for any help!
I'm using Ubuntu 22.04.2 LTS, and have followed the instructions in the 'Host Machine' setup section (as I mentioned, everything was working great up until this step).  The only way I was able to get things working was to clone the git repositories.  I'm on the 'master' branch.
users mailing list
users at rtems.org<mailto:users at rtems.org>
http://lists.rtems.org/mailman/listinfo/users<https://usg02.safelinks.protection.office365.us/?url=http%3A%2F%2Flists.rtems.org%2Fmailman%2Flistinfo%2Fusers&data=05%7C01%7C%7C9a9d0447d98344cc537b08db8222f881%7Cd761ffacf6be45b88f6f288a59577095%7C0%7C0%7C638246858946228580%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C3000%7C%7C%7C&sdata=2RYIKaz6I6sGlEaCbrzvemW%2Bmqo65q8%2BVzKPlS5b1kQ%3D&reserved=0>
URL: <http://lists.rtems.org/pipermail/users/attachments/20230711/aa32d557/attachment-0001.htm>
