CONFIGURE_MINIMUM_TASK_STACK_SIZE
Gedare Bloom
gedare at rtems.org
Wed Dec 7 18:39:20 UTC 2011
Hi,
I was reviewing some of the configure options for specifying stack
sizes and came across some odd-seeming behavior.
CONFIGURE_MINIMUM_TASK_STACK_SIZE can be defined by an application to
increase the size of all of its task stacks (and implicitly the init
task and interrupt stacks). It seems wrong/wasteful to propagate the
user-defined CONFIGURE_MINIMUM_TASK_STACK_SIZE to both the idle and
interrupt stacks, perhaps these should be CPU_STACK_MINIMUM_SIZE
unless defined by the user explicitly?
By the way I don't see CONFIGURE_MINIMUM_TASK_STACK_SIZE in the
documentation, so maybe I'm incorrect in thinking it is a "public"
configure option?
-Gedare
