GCC 4.7 Status Report for *-rtems
Joel Sherrill
joel.sherrill at OARcorp.com
Tue Dec 13 19:36:15 UTC 2011
Hi,
From an RTEMS perspective, the head has multiple regressions from the
4.6 branch. avr, bfin, lm32 and m68k have regressions such that they are
incapable of compiling a complete tool chain. This means they fail to
compile gcc, newlib, or RTEMS. These are the PRs for those regressions.
avr - REGRESSION - ICE -
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=50925
bfin - REGRESSION - ICE -
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=51003
lm32 - REGRESSION - ICE -
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=50927
m68k - REGRESSION - Invalid code -
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=51532
Had an ICE and now has assembly that is invalid for CPU32
before it
gets that far.
I know these are not primary GCC targets but at this point 25% of the
RTEMS targets don't build.
Beyond that, Go is our biggest known issue. In spite of compiling on
4.6 and testing well, Go does not compile for RTEMS. A first patch was
posted but there has been no response:
http://gcc.gnu.org/ml/gcc-patches/2011-12/msg00201.html
If a target can build enough to run C/C++ tests, we have run them and
posted test results. After initial compilation problems, Ada and
FORTRAN build on at least one RTEMS target and have reasonable test
results posted.
We have not gotten to GCJ testing yet.
Objective-C compiles but has poor test results until RTEMS has a few
more thread support routines implemented in libgcc. This would make a
nice small project for someone.
I hope the communities will pitch in to help get these resolved.
Thanks.
Joel Sherrill, Ph.D. Director of Research& Development
