Can't import GPG key
Ralf Corsepius
ralf.corsepius at rtems.org
Thu Dec 29 17:55:24 UTC 2011
On 12/28/2011 12:59 PM, Peter Dufault wrote:
> I'm following the instructions to setup a new RHEL6.1 system for development. I'm following the "Yum instructions" on http://wiki.rtems.org/wiki/index.php/APT/Yum_Repository. I haven't done this from scratch in quite a while. It fails:
> [root at litho9099 Desktop]# rpm --import gpg-pubkey-69ce4a83-44cc2b30
> error: gpg-pubkey-69ce4a83-44cc2b30: key 1 import failed.
I don't have any explanation for this issue of yours and can't reproduce it.
"rpm --import ..." is supposed to "simply work".
May-be your downloaded copy of the gpg-pubkey file is corrupt (I
verified the master on rtems.org is not corrupted). Can you try other
means of downloading?
Another potential cause could be a corrupt rpm database or a bug in CentOS.
Ralf
