Release plan for RTEMS 4.11?
Sebastian Huber
Tue Apr 3 07:58:59 UTC 2012
Hi,
which open points do we have for RTEMS 4.11? Do we have a time line?
From my side there are some file system issues outstanding.
1. The lseek() mechanic should change. We should get rid of the size field in
the rtems_libio_t structure.
2. We should remove the unused sem field in the rtems_libio_t structure. This
reduces per file descriptor overhead by roughly 128 Bytes.
3. lseek() and ftruncate() should be made POSIX conform.
Regarding GCC 4.7 I am not sure if this is the right candidate for the RTEMS
4.11 release. We tested mostly only on GCC 4.6.
Phone : +49 89 18 90 80 79-6
Fax : +49 89 18 90 80 79-9
