Release plan for RTEMS 4.11?
Ralf Corsepius
ralf.corsepius at rtems.org
Tue Apr 3 08:42:33 UTC 2012
On 04/03/2012 09:58 AM, Sebastian Huber wrote:
> Hi,
> which open points do we have for RTEMS 4.11? Do we have a time line?
No. Common sense would be to have
1. A shorter (severals weeks) "no new features", "bug-fix-only", code
consolidation phase.
2. If being satisfied with the results, a fork and subsequently followed
by a deep-freeze, "hard-testing"-only phase would follow.
Experience tells, there are different visions of "being satisfied" with
the code.
[You can already smell it: You seem to be considering RTEMS 4.11 to be
in "close to release shape" - I could not disagree more :( ]
Experience also tells, the RTEMS core devs will not care about the
"production" release code once having forked, because they will consider
this to be "boring", "tedious", "non-interesting" and "duplication of work".
> From my side there are some file system issues outstanding.
> 1. The lseek() mechanic should change. We should get rid of the size
> field in the rtems_libio_t structure.
> 2. We should remove the unused sem field in the rtems_libio_t structure.
> This reduces per file descriptor overhead by roughly 128 Bytes.
> 3. lseek() and ftruncate() should be made POSIX conform.
From my POV, RTEMS-4.11 is far from being in release shape, because too
many changes have found their way into RTEMS, which have significantly
destabilized RTEMS and have broken things.
Just one example: With today's git, ca. 50% of all powerpc bsps do not
even build (for various reasons).
> Regarding GCC 4.7 I am not sure if this is the right candidate for the
> RTEMS 4.11 release. We tested mostly only on GCC 4.6.
I am strongly in favor of switching to GCC-4.7.
However, the sad truth is, GCC-4.7.0 doesn't build for ca. 30% of all
RTEMS targets and is suffering from other open issues on ca. 20% more
[1]. It builds and seems to work flawlessly for the remaining 50% of
targets.
Ralf
[1] avr, m32c and sparc64 ICE.
sparc and sh are having major integration probs, arm and powerpc are
having smaller integration probs.
