[PATCH 1/4] libblock: Use unprotected chain operations
Wed Apr 11 23:50:42 UTC 2012
This change is ok plus the 2/4 patch.
On 29/03/12 12:30 AM, sebastian.huber at embedded-brains.de wrote:
> From: Sebastian Huber<sebastian.huber at embedded-brains.de>
> The chains are protected by the bdbuf cache lock.
>   cpukit/libblock/src/bdbuf.c |   34 +++++++++++++++++-----------------
>   1 files changed, 17 insertions(+), 17 deletions(-)
> diff --git a/cpukit/libblock/src/bdbuf.c b/cpukit/libblock/src/bdbuf.c
> index a5eaa95..89951f4 100644
> --- a/cpukit/libblock/src/bdbuf.c
> +++ b/cpukit/libblock/src/bdbuf.c
> @@ -1056,14 +1056,14 @@ rtems_bdbuf_remove_from_tree_and_lru_list (rtems_bdbuf_buffer *bd)
>         rtems_bdbuf_fatal (bd->state, RTEMS_BLKDEV_FATAL_BDBUF_STATE_10);
> -  rtems_chain_extract (&bd->link);
> +  rtems_chain_extract_unprotected (&bd->link);
>   static void
>   rtems_bdbuf_make_free_and_add_to_lru_list (rtems_bdbuf_buffer *bd)
>     rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_FREE);
> -  rtems_chain_prepend (&bdbuf_cache.lru,&bd->link);
> +  rtems_chain_prepend_unprotected (&bdbuf_cache.lru,&bd->link);
>   static void
> @@ -1076,7 +1076,7 @@ static void
>   rtems_bdbuf_make_cached_and_add_to_lru_list (rtems_bdbuf_buffer *bd)
>     rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_CACHED);
> -  rtems_chain_append (&bdbuf_cache.lru,&bd->link);
> +  rtems_chain_append_unprotected (&bdbuf_cache.lru,&bd->link);
>   static void
> @@ -1123,7 +1123,7 @@ rtems_bdbuf_add_to_modified_list_after_access (rtems_bdbuf_buffer *bd)
>       bd->hold_timer = bdbuf_config.swap_block_hold;
>     rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_MODIFIED);
> -  rtems_chain_append (&bdbuf_cache.modified,&bd->link);
> +  rtems_chain_append_unprotected (&bdbuf_cache.modified,&bd->link);
>     if (bd->waiters)
>       rtems_bdbuf_wake (&bdbuf_cache.access_waiters);
> @@ -1428,7 +1428,7 @@ rtems_bdbuf_init (void)
>       bd->group  = group;
>       bd->buffer = buffer;
>       if ((b % bdbuf_cache.max_bds_per_group) ==
>           (bdbuf_cache.max_bds_per_group - 1))
> @@ -1525,7 +1525,7 @@ rtems_bdbuf_wait_for_access (rtems_bdbuf_buffer *bd)
>           rtems_bdbuf_group_release (bd);
>           /* Fall through */
>         case RTEMS_BDBUF_STATE_CACHED:
>           /* Fall through */
>         case RTEMS_BDBUF_STATE_EMPTY:
>           return;
> @@ -1550,8 +1550,8 @@ static void
>   rtems_bdbuf_request_sync_for_modified_buffer (rtems_bdbuf_buffer *bd)
>     rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_SYNC);
> -  rtems_chain_append (&bdbuf_cache.sync,&bd->link);
> +  rtems_chain_append_unprotected (&bdbuf_cache.sync,&bd->link);
>     rtems_bdbuf_wake_swapper ();
> @@ -1645,7 +1645,7 @@ rtems_bdbuf_sync_after_access (rtems_bdbuf_buffer *bd)
>     if (bd->waiters)
> @@ -2030,7 +2030,7 @@ rtems_bdbuf_read (const rtems_disk_device *dd,
>       sc = rtems_bdbuf_execute_transfer_request (dd, req, true);
>       if (sc == RTEMS_SUCCESSFUL)
>         rtems_bdbuf_group_obtain (bd);
> @@ -2428,7 +2428,7 @@ rtems_bdbuf_swapout_modified_processing (const rtems_disk_device **dd_ptr,
>           rtems_bdbuf_set_state (bd, RTEMS_BDBUF_STATE_TRANSFER);
> -        rtems_chain_extract (node);
> +        rtems_chain_extract_unprotected (node);
>           tnode = tnode->previous;
> @@ -2498,7 +2498,7 @@ rtems_bdbuf_swapout_processing (unsigned long                 timer_delta,
>     else
>       worker = (rtems_bdbuf_swapout_worker*)
> -      rtems_chain_get (&bdbuf_cache.swapout_workers);
> +      rtems_chain_get_unprotected (&bdbuf_cache.swapout_workers);
>       if (worker)
>         transfer =&worker->transfer;
> @@ -2628,7 +2628,7 @@ rtems_bdbuf_swapout_worker_task (rtems_task_argument arg)
>       rtems_chain_initialize_empty (&worker->transfer.bds);
>       worker->transfer.dd = BDBUF_INVALID_DEV;
> -    rtems_chain_append (&bdbuf_cache.swapout_workers,&worker->link);
> +    rtems_chain_append_unprotected (&bdbuf_cache.swapout_workers,&worker->link);
>       rtems_bdbuf_unlock_cache ();
> @@ -2658,7 +2658,7 @@ rtems_bdbuf_swapout_workers_open (void)
>       if (!worker)
>         rtems_fatal_error_occurred (RTEMS_BLKDEV_FATAL_BDBUF_SO_NOMEM);
>       worker->enabled = true;
>       worker->transfer.write_req = rtems_bdbuf_swapout_writereq_alloc ();
> @@ -2805,7 +2805,7 @@ rtems_bdbuf_purge_list (rtems_chain_control *purge_list)
>     bool wake_buffer_waiters = false;
>     rtems_chain_node *node = NULL;
> -  while ((node = rtems_chain_get (purge_list)) != NULL)
> +  while ((node = rtems_chain_get_unprotected (purge_list)) != NULL)
>       rtems_bdbuf_buffer *bd = (rtems_bdbuf_buffer *) node;
> @@ -2847,8 +2847,8 @@ rtems_bdbuf_gather_for_purge (rtems_chain_control *purge_list,
>             rtems_bdbuf_group_release (cur);
>             /* Fall through */
> -          rtems_chain_extract (&cur->link);
> -          rtems_chain_append (purge_list,&cur->link);
> +          rtems_chain_extract_unprotected (&cur->link);
> +          rtems_chain_append_unprotected (purge_list,&cur->link);
>             break;
>           case RTEMS_BDBUF_STATE_TRANSFER:
>             rtems_bdbuf_set_state (cur, RTEMS_BDBUF_STATE_TRANSFER_PURGED);
