[PATCH 3/4] libblock: Change error status to fatal error
Chris Johns
chrisj at rtems.org
Thu Apr 12 02:52:59 UTC 2012
On 29/03/12 12:30 AM, sebastian.huber at embedded-brains.de wrote:
> From: Sebastian Huber<sebastian.huber at embedded-brains.de>
> Calling the bdbuf API functions in the not configured state is now a
> fatal error.
Moving to a fatal error is fine. I just wonder if a lock not being
obtained is a little abstract and a more concrete fatal error should be
added. The user is left to wonder if they have enough mutex resources or
there is a failure to correctly create the mutex rather than the simpler
problem of not calling the init routine. This could be based on the
result code and not another test in the locking path.
